Receiving unrecognized characters at LoRa receiveing station made using Heltec LoRa V3
Good Evening Guys,
I am working on a project where I'd like to send recorded sensor values using LoRa.
For this purpose, I am using a Seeed Studio Grove LoRa Radio as the transmitter. It uses a RFM95 as its base. To connect the LoRa radio, I have a grove basic shield. LoRa is connected at D6 and D7. As far as I can tell, the transmitter side is working well. I am sending a string.
For receiving the transmission, I am using a Heltec LoRa v3, it uses a SX1262 LoRa chip.
The data displayed on the OLED display and the Serial Monitor is a string of unrecognized characters.
TRANSMITTING SIDE CODE
#include <RH_RF95.h>
#ifdef __AVR__
    #include <SoftwareSerial.h>
    SoftwareSerial SSerial(6, 7); // RX, TX
    #define COMSerial SSerial
    #define ShowSerial Serial
    RH_RF95<SoftwareSerial> rf95(COMSerial);
#endif
    ShowSerial.begin(115200);
    ShowSerial.println("RF95 client test.");
    if (!rf95.init()) {
        ShowSerial.println("init failed");
        while (1);
    // Defaults after init are 434.0MHz, 13dBm, Bw = 125 kHz, Cr = 4/5, Sf = 128chips/symbol, CRC on
    // The default transmitter power is 13dBm, using PA_BOOST.
    // If you are using RFM95/96/97/98 modules which uses the PA_BOOST transmitter pin, then
    // you can set transmitter powers from 5 to 23 dBm:
    //rf95.setTxPower(13, false);
    rf95.setFrequency(433.0);
    rf95.setTxPower(12);
    uint8_t a=1;
    ShowSerial.println("Sending to rf95_server");
    // Send a message to rf95_server
    char someString[15] = "battery: %i";
    char test[30];
    snprintf(test, 30, someString, a);
    ShowSerial.println(test);
    delay(10);
    rf95.send((uint8_t *)test, 30);
    delay(5000);
SERIAL MONITOR OUTPUT
01:06:13.906 -> Sending to rf95_server
01:06:13.906 -> battery: 1
01:06:18.966 -> Sending to rf95_server
01:06:18.966 -> battery: 2
01:06:23.966 -> Sending to rf95_server
01:06:24.001 -> battery: 3
01:06:29.004 -> Sending to rf95_server
01:06:29.037 -> battery: 4
01:12:31.823 -> RF95 client test.
01:12:31.861 -> Sending to rf95_server
01:12:31.861 -> battery: 0
01:12:36.894 -> Sending to rf95_server
01:12:36.894 -> battery: 1
01:12:41.944 -> Sending to rf95_server
01:12:41.944 -> battery: 2
01:12:46.947 -> Sending to rf95_server
01:12:46.985 -> battery: 3
RECEIVER SIDE CODE
// Turns the 'PRG' button into the power button, long press is off
#define HELTEC_POWER_BUTTON   // must be before "#include <heltec_unofficial.h>"
#define PAUSE               300
#define FREQUENCY           433.0
// #define FREQUENCY           905.2       // for US
#define BANDWIDTH           125.0
#define SPREADING_FACTOR    7
#define TRANSMIT_POWER      2
#define LORA_PREAMBLE_LENGTH  8
#define CODING_RATE 5
#define SYNC_WORD 0x12
String rxdata;
volatile bool rxFlag = false;
long counter = 0;
uint64_t last_tx = 0;
uint64_t tx_time;
uint64_t minimum_pause;
// Can't do Serial or display things here, takes too much time for the interrupt
void rx() {
  rxFlag = true;
struct Data {
  int seq;
  float y;
} data;
  heltec_setup();
  both.println("Radio init");
  RADIOLIB_OR_HALT(radio.begin());
  // Set the callback function for received packets
  radio.setDio1Action(rx);
  // Set radio parameters
  both.printf("Frequency: %.2f MHz\n", FREQUENCY);
  RADIOLIB_OR_HALT(radio.setFrequency(FREQUENCY));
  both.printf("Bandwidth: %.1f kHz\n", BANDWIDTH);
  RADIOLIB_OR_HALT(radio.setBandwidth(BANDWIDTH));
  both.printf("Spreading Factor: %i\n", SPREADING_FACTOR);
  RADIOLIB_OR_HALT(radio.setSpreadingFactor(SPREADING_FACTOR));
  both.printf("TX power: %i dBm\n", TRANSMIT_POWER);
  RADIOLIB_OR_HALT(radio.setOutputPower(TRANSMIT_POWER));
  both.printf("Preamble Length: %i \n", LORA_PREAMBLE_LENGTH);
  RADIOLIB_OR_HALT(radio.setPreambleLength(LORA_PREAMBLE_LENGTH));
  both.printf("Coding Rate: %i \n", CODING_RATE);
  RADIOLIB_OR_HALT(radio.setCodingRate(CODING_RATE));
  both.printf("Sync Word: %i \n", SYNC_WORD);
  RADIOLIB_OR_HALT(radio.setSyncWord(SYNC_WORD));
  // Start receiving
  RADIOLIB_OR_HALT(radio.startReceive(RADIOLIB_SX126X_RX_TIMEOUT_INF));
  heltec_loop();
  if (rxFlag) {
    rxFlag = false;
    radio.readData(rxdata);
    if (_radiolib_status == RADIOLIB_ERR_NONE) {
      both.printf("RX [%s]\n", rxdata);
      both.printf("  RSSI: %.2f dBm\n", radio.getRSSI());
      both.printf("  SNR: %.2f dB\n", radio.getSNR());
  delay(5000);
OUTPUT
01:12:25.969 -> ESP-ROM:esp32s3-20210327
01:12:25.969 -> Build:Mar 27 2021
01:12:25.969 -> rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT)
01:12:25.969 -> SPIWP:0xee
01:12:25.969 -> mode:DIO, clock div:1
01:12:25.969 -> load:0x3fce3808,len:0x4bc
01:12:25.969 -> load:0x403c9700,len:0xbd8
01:12:25.969 -> load:0x403cc700,len:0x2a0c
01:12:25.969 -> entry 0x403c98d0
01:12:26.097 -> Radio init
01:12:26.176 -> [RadioLib] radio.begin() returned 0 (ERR_NONE)
01:12:26.176 -> Frequency: 433.00 MHz
01:12:26.208 -> [RadioLib] radio.setFrequency(433.0) returned 0 (ERR_NONE)
01:12:26.208 -> Bandwidth: 125.0 kHz
01:12:26.274 -> [RadioLib] radio.setBandwidth(125.0) returned 0 (ERR_NONE)
01:12:26.274 -> Spreading Factor: 7
01:12:26.306 -> [RadioLib] radio.setSpreadingFactor(7) returned 0 (ERR_NONE)
01:12:26.338 -> TX power: 2 dBm
01:12:26.377 -> [RadioLib] radio.setOutputPower(2) returned 0 (ERR_NONE)
01:12:26.408 -> Preamble Length: 8
01:12:26.482 -> [RadioLib] radio.setPreambleLength(8) returned 0 (ERR_NONE)
01:12:26.517 -> Coding Rate: 5
01:12:26.582 -> [RadioLib] radio.setCodingRate(5) returned 0 (ERR_NONE)
01:12:26.582 -> Sync Word: 18
01:12:26.647 -> [RadioLib] radio.setSyncWord(0x12) returned 0 (ERR_NONE)
01:12:26.648 -> [RadioLib] radio.startReceive(0xFFFFFF) returned 0 (ERR_NONE)
01:12:31.688 -> RX [��]
01:12:31.688 ->   RSSI: -17.00 dBm
01:12:31.762 ->   SNR: 12.75 dB
01:12:31.826 -> [RadioLib] radio.startReceive(0xFFFFFF) returned 0 (ERR_NONE)
01:12:36.862 -> RX [��]
01:12:36.912 ->   RSSI: -13.00 dBm
01:12:36.928 ->   SNR: 12.75 dB
01:12:36.993 -> [RadioLib] radio.startReceive(0xFFFFFF) returned 0 (ERR_NONE)
This is the library I am using for the Heltec board. The only library I could get this working with.
Solutions I have tried after going through the forums:
I have increased the transmitting power. People said low power could result in such issues.
I have tried sending a struct from one of the solutions, but again, at the receiving side, I did not get the values I was hoping. But this time atleast I didn't get those unrecognizable characters.
People have also suggested that we should use a proper antenna. Currently I am using a wire as an antenna on the transmitter side, which I will replace with an antenna tomorrow to see if that makes a difference.
I am an absolute novice, both when it comes to using these forums and Arduino/LoRa stuff. Please help me out.
I would recommend that for transmitter and receiver you use the same LoRa module, Arduino and interface type so that the LoRa library used is exactly the same for both transmitter and receiver. Its then heaps and heaps easier to be sure the transmitter and receiver LoRa settings are compatible.
Yeah, I kinda shoot myself in the foot by overlooking this fact. But now we are here..
I don't think I'll be able to get a new module rightaway
Still quicker than mucking with your current choices and later determining there is no fix.
Given the reported RSSI its highly unlikley the 'corrupt' packets are caused by lack of transmitting power or poor antennas. In fact you should reduce TX power a bit and move the TX and RX further apart, you running the risk of overloading the RX side.
Send a packet that contains just 0x00s or 0x55 and then check what was received, that might give you a clue.
And here is another problem. The SEEED Grove appears to use a serial UART from end for the LoRa module itself, so it may not be clear what internal changes to the LoRa setup or packet data its microcontroller is making. This is not an unkown issue there are several UART front ended LoRa modules and their use protocols are all different. These UART front ended LoRa modules are really intended to be used as TX and RX pairs.
There are other libraries for that board.
However unless your experienced in using and configuring LoRa mixing between the SX126x and SX127x types is not such a good idea. There are quite a few libraries that support the standard SX127x\RFM9x LoRa modules but not so many that support the SX126x.
there are LoRa libraries which support different LoRa modules
  1. Sandeep Mistry's LoRa library supports RFM95 and SX1276 modules but no mention of the SX1262
  2. the SX12XX Library supports a range of Semtech LoRa devices SX1262,SX1262,SX1268,SX1272,SX1276,SX1277,SX1278,SX1279,SX1280,SX1281
    however, no mention of the RFM95
you can always experiment or implement your own library??
however, the advice of @srnet to use identical modules is worth taking
