Please help me to solve the problem in this code the problem is it is no recieve calls after register the mobile number properly, but the SMS command work properly. Please help me to shortout the issue.
#include <SoftwareSerial.h>
//MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM
#include <EEPROM.h>
//sender phone number with country code
//const String PHONE = "ENTER_PHONE_HERE";
const int totalPhoneNo = 5;
String phoneNo[totalPhoneNo] = {"","","","",""};
int offsetPhone[totalPhoneNo] = {0,13,26,39,52};
String tempPhone = "";
//GSM Module RX pin to Arduino 3
//GSM Module TX pin to Arduino 2
#define rxPin 2
#define txPin 3
SoftwareSerial sim800(rxPin,txPin);
#define RELAY_1 7
#define RELAY_2 8
#define RELAY_3 9
#define RELAY_4 10
boolean STATE_RELAY_1 = 0;
boolean STATE_RELAY_2 = 0;
boolean STATE_RELAY_3 = 0;
boolean STATE_RELAY_4 = 0;
String smsStatus,senderNumber,receivedDate,msg;
boolean isReply = false;
String dtmf_cmd;
boolean is_call = false;
boolean DEBUG_MODE = 1;
* setup function
Serial.println("Arduino serial initialize");
sim800.begin(9600);
Serial.println("SIM800L software serial initialize");
pinMode(RELAY_1, OUTPUT); //Relay 1
pinMode(RELAY_2, OUTPUT); //Relay 2
pinMode(RELAY_3, OUTPUT); //Relay 3
pinMode(RELAY_4, OUTPUT); //Relay 4
digitalWrite(RELAY_1, LOW);
digitalWrite(RELAY_2, LOW);
digitalWrite(RELAY_3, LOW);
digitalWrite(RELAY_4, LOW);
smsStatus = "";
senderNumber="";
receivedDate="";
msg="";
Serial.println("List of Registered Phone Numbers");
for (int i = 0; i < totalPhoneNo; i++){
phoneNo[i] = readFromEEPROM(offsetPhone[i]);
if(phoneNo[i].length() != 13)
{phoneNo[i] = "";Serial.println(String(i+1)+": empty");}
{Serial.println(String(i+1)+": "+phoneNo[i]);}
delay(7000);
sim800.print("AT+CMGF=1\r"); //SMS text mode
sim800.println("AT"); //send AT
sim800.println("AT+DDET=1"); //Enable DTMF
sim800.println("AT+CLIP=1"); //Enable Caller ID
* Loop Function
while(sim800.available()){
parseData(sim800.readString());
while(Serial.available()) {
sim800.println(Serial.readString());
} //main loop ends
* parseData function:
* this function parse the incomming command such as CMTI or CMGR etc.
* if the sms is received. then this function read that sms and then pass
* that sms to "extractSms" function. Then "extractSms" function divide the
* sms into parts. such as sender_phone, sms_body, received_date etc.
void parseData(String buff){
Serial.println(buff);
//MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM
//HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
if(buff.indexOf("RING") > -1)
boolean flag = 0;
//+CLIP: "03001234567",129,"",0,"",0
if(buff.indexOf("+CLIP:")){
unsigned int index, index1;
index = buff.indexOf("\"");
index1 = buff.indexOf("\"", index+1);
//get phone like this format 3001234567
String temp = buff.substring(index+2, index1);
temp.trim();
debugPrint("meee: "+temp);
//Serial.println(temp.length());
if(temp.length() == 13){
//number formate xxx-yyy-zzzzzzz
//+923001234567
flag = comparePhone(temp);
else if(temp.length() == 10){
//number formate yyyy-zzzzzzz
//3001234567
flag = compareWithoutCountryCode(temp);
if(flag == 1){
//delay(6000);
sim800.println("ATA");
sim800.println("AT+VTD=500;");
is_call = true;
else{
debugPrint("The phone number is not registered.");
//is_call = false;
return;
else if(is_call == true){
if(int index = buff.indexOf("+DTMF:") > -1 )
index = buff.indexOf(":");
dtmf_cmd = buff.substring(index+1, buff.length());
dtmf_cmd.trim();
debugPrint("DTMF Command: "+dtmf_cmd);
controlDTMF(dtmf_cmd);
return;
if(buff.indexOf("NO CARRIER") > -1)
sim800.println("ATH");
is_call = false;
return;
unsigned int len, index;
//Remove sent "AT Command" from the response string.
index = buff.indexOf("\r");
buff.remove(0, index+2);
buff.trim();
if(buff != "OK"){
String cmd = buff.substring(0, index);
cmd.trim();
if(cmd == "+CMTI"){
//get newly arrived memory location and store it in temp
index = buff.indexOf(",");
String temp = buff.substring(index+1, buff.length());
temp = "AT+CMGR=" + temp + "\r";
//get the message stored at memory location "temp"
sim800.println(temp);
else if(cmd == "+CMGR"){
extractSms(buff);
if(msg.equals("r") && phoneNo[0].length() != 13) {
writeToEEPROM(offsetPhone[0],senderNumber);
phoneNo[0] = senderNumber;
String text = "Number is Registered: ";
text = text + senderNumber;
debugPrint(text);
Reply("Number is Registered", senderNumber);
if(comparePhone(senderNumber)){
doAction(senderNumber);
//delete all sms
sim800.println("AT+CMGD=1,4");
sim800.println("AT+CMGDA= \"DEL ALL\"");
else{
//The result of AT Command is "OK"
* extractSms function:
* This function divide the sms into parts. such as sender_phone, sms_body,
* received_date etc.
void extractSms(String buff){
unsigned int index;
smsStatus = buff.substring(1, index-1);
senderNumber = buff.substring(0, 13);
buff.remove(0,19);
receivedDate = buff.substring(0, 20);
buff.remove(0,buff.indexOf("\r"));
buff.trim();
index =buff.indexOf("\n\r");
buff = buff.substring(0, index);
buff.trim();
msg = buff;
buff = "";
msg.toLowerCase();
//NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN
String tempcmd = msg.substring(0, 3);
if(tempcmd.equals("r1=") || tempcmd.equals("r2=") ||
tempcmd.equals("r3=") || tempcmd.equals("r4=") ||
tempcmd.equals("r5=")){
tempPhone = msg.substring(3, 16);
msg = tempcmd;
//debugPrint(msg);
//debugPrint(tempPhone);
* doAction function:
* Performs action according to the received sms
void doAction(String phoneNumber){
if(msg == "a1"){
digitalWrite(RELAY_1, HIGH);
STATE_RELAY_1 = 1;
debugPrint("Relay 1 is ON");
Reply("Relay 1 is ON", phoneNumber);
else if(msg == "a0"){
STATE_RELAY_1 = 0;
debugPrint("Relay 1 is OFF");
Reply("Relay 1 is OFF", phoneNumber);
else if(msg == "b1"){
digitalWrite(RELAY_2, HIGH);
STATE_RELAY_2 = 1;
debugPrint("Relay 2 is ON");
Reply("Relay 2 is ON", phoneNumber);
else if(msg == "b0"){
STATE_RELAY_2 = 0;
debugPrint("Relay 2 is OFF");
Reply("Relay 2 is OFF", phoneNumber);
else if(msg == "c1"){
digitalWrite(RELAY_3, HIGH);
STATE_RELAY_3 = 1;
debugPrint("Relay 3 is ON");
Reply("Relay 3 is ON", phoneNumber);
else if(msg == "c0"){
STATE_RELAY_3 = 0;
debugPrint("Relay 3 is OFF");
Reply("Relay 3 is OFF", phoneNumber);
else if(msg == "d1"){
digitalWrite(RELAY_4, HIGH);
STATE_RELAY_4 = 1;
debugPrint("Relay 4 is ON");
Reply("Relay 4 is ON", phoneNumber);
else if(msg == "d0"){
STATE_RELAY_4 = 0;
debugPrint("Relay 4 is OFF");
Reply("Relay 4 is OFF", phoneNumber);
else if(msg == "stat=1"){
String text = (STATE_RELAY_1)? "ON" : "OFF";
debugPrint("Relay 1 is "+text);
Reply("Relay 1 is "+text, phoneNumber);
else if(msg == "stat=2"){
String text = (STATE_RELAY_2)? "ON" : "OFF";
debugPrint("Relay 2 is "+text);
Reply("Relay 2 is "+text, phoneNumber);
else if(msg == "stat=3"){
String text = (STATE_RELAY_3)? "ON" : "OFF";
debugPrint("Relay 3 is "+text);
Reply("Relay 3 is "+text, phoneNumber);
else if(msg == "stat=4"){
String text = (STATE_RELAY_4)? "ON" : "OFF";
debugPrint("Relay 4 is "+text);
Reply("Relay 4 is "+text, phoneNumber);
else if(msg == "r2="){
writeToEEPROM(offsetPhone[1],tempPhone);
phoneNo[1] = tempPhone;
String text = "Phone2 is Registered: ";
text = text + tempPhone;
debugPrint(text);
Reply(text, phoneNumber);
else if(msg == "r3="){
writeToEEPROM(offsetPhone[2],tempPhone);
phoneNo[2] = tempPhone;
String text = "Phone3 is Registered: ";
else if(msg == "r4="){
writeToEEPROM(offsetPhone[3],tempPhone);
phoneNo[3] = tempPhone;
String text = "Phone4 is Registered: ";
else if(msg == "r5="){
writeToEEPROM(offsetPhone[4],tempPhone);
phoneNo[4] = tempPhone;
String text = "Phone5 is Registered: ";
else if(msg == "list"){
String text = "";
if(phoneNo[0])
text = text + phoneNo[0]+"\r\n";
if(phoneNo[1])
text = text + phoneNo[1]+"\r\n";
if(phoneNo[2])
text = text + phoneNo[2]+"\r\n";
if(phoneNo[3])
text = text + phoneNo[3]+"\r\n";
if(phoneNo[4])
text = text + phoneNo[4]+"\r\n";
debugPrint("List of Registered Phone Numbers: \r\n"+text);
else if(msg == "del=1"){
writeToEEPROM(offsetPhone[0],"");
phoneNo[0] = "";
Reply("Phone1 is deleted.", phoneNumber);
else if(msg == "del=2"){
writeToEEPROM(offsetPhone[1],"");
phoneNo[1] = "";
debugPrint("Phone2 is deleted.");
Reply("Phone2 is deleted.", phoneNumber);
else if(msg == "del=3"){
writeToEEPROM(offsetPhone[2],"");
phoneNo[2] = "";
debugPrint("Phone3 is deleted.");
Reply("Phone3 is deleted.", phoneNumber);
else if(msg == "del=4"){
writeToEEPROM(offsetPhone[3],"");
phoneNo[3] = "";
debugPrint("Phone4 is deleted.");
Reply("Phone4 is deleted.", phoneNumber);
else if(msg == "del=5"){
writeToEEPROM(offsetPhone[4],"");
phoneNo[4] = "";
debugPrint("Phone5 is deleted.");
Reply("Phone5 is deleted.", phoneNumber);
if(msg == "del=all"){
phoneNo[0] = "";
phoneNo[1] = "";
phoneNo[2] = "";
phoneNo[3] = "";
phoneNo[4] = "";
debugPrint("All phone numbers are deleted.");
Reply("All phone numbers are deleted.", phoneNumber);
smsStatus = "";
senderNumber="";
receivedDate="";
msg="";
tempPhone = "";
* Reply function
* Send an sms
void Reply(String text, String Phone)
sim800.print("AT+CMGS=\""+Phone+"\"\r");
sim800.print(text);
delay(100);
sim800.write(0x1A); //ascii code for ctrl-26 //sim800.println((char)26); //ascii code for ctrl-26
Serial.println("SMS Sent Successfully.");
* only upto 70 messages can be stored in sim800l memory
* after the memory is full, then no new sms will be received
* until you free up the sms memory by deleting some sms.
* that's why the below written command deletes all the sms
* from the memory automatically.
* writeToEEPROM function:
* Store registered phone numbers in EEPROM
void writeToEEPROM(int addrOffset, const String &strToWrite)
byte len = 13; //strToWrite.length();
//EEPROM.write(addrOffset, len);
for (int i = 0; i < len; i++)
EEPROM.write(addrOffset + i, strToWrite[i]);
* readFromEEPROM function:
* Store phone numbers in EEPROM
String readFromEEPROM(int addrOffset)
int len = 13;
char data[len + 1];
data[i] = EEPROM.read(addrOffset + i);
data[len] = '\0';
return String(data);
* comparePhone function:
* compare phone numbers stored in EEPROM
boolean comparePhone(String number)
boolean flag = 0;
if(phoneNo[i].equals(number)){
flag = 1;
return flag;
* compareWithoutCountryCode function:
boolean compareWithoutCountryCode(String number)
boolean flag = 0;
//remove first 3 digits (country code)
phoneNo[i].remove(0,3);
Serial.println("meee1: "+phoneNo[i]);
//Serial.println(phoneNo[i]);
flag = 1;
return flag;
* dtmfControl function:
void controlDTMF(String dtmf_code){
if(dtmf_code == "1"){
STATE_RELAY_1 = !STATE_RELAY_1;
digitalWrite(RELAY_1, STATE_RELAY_1);
if(STATE_RELAY_1 == true){
sim800.println("AT+VTS=0;");
else{
else if(dtmf_code == "2"){
STATE_RELAY_2 = !STATE_RELAY_2;
digitalWrite(RELAY_2, STATE_RELAY_2);
if(STATE_RELAY_2 == true){
else{
else if(dtmf_code == "3"){
STATE_RELAY_3 = !STATE_RELAY_3;
digitalWrite(RELAY_3, STATE_RELAY_3);
if(STATE_RELAY_3 == true){
else{
else if(dtmf_code == "4"){
STATE_RELAY_4 = !STATE_RELAY_4;
digitalWrite(RELAY_4, STATE_RELAY_4);
if(STATE_RELAY_4 == true){
else{
else if(dtmf_code == "5"){
STATE_RELAY_1 == 1;
STATE_RELAY_2 == 1;
STATE_RELAY_3 == 1;
STATE_RELAY_4 == 1;
debugPrint("All relays are ON");
else if(dtmf_code == "6"){
STATE_RELAY_1 == 0;
STATE_RELAY_2 == 0;
STATE_RELAY_3 == 0;
STATE_RELAY_4 == 0;
debugPrint("All relays are OFF");
* debugPrint function:
void debugPrint(String text){
if(DEBUG_MODE == 1)
Serial.println(text);
