consider
#if 0
#define RECIRC_PUMP 30 //motor relay
#define ECO_RELAY_1 31 //relay for polarity switching
#define ECO_RELAY_2 32 //relay for polarity switching
#else
#define RECIRC_PUMP 10
#define ECO_RELAY_1 11
#define ECO_RELAY_2 12
#endif
#define ON LOW
#define OFF HIGH
#define RecircOnHour 16
#define RecircOffHour 17
enum { STOP, POS, NEG };
int state = STOP;
char s [20];
long time = (57L + (15L * 60)) * 60;
int seconds (void) { return time % 60; };
int minutes (void) { return (time / 60) % 60; };
int hour (void) { return (time / 3600 % 24); }
void timeUpdate (void)
time += 15;
sprintf (s, "%2d:%02d:%02d", hour (), minutes (), seconds ());
Serial.println (s);
delay (100);
void relay (
byte pin,
byte state )
digitalWrite (pin, state);
sprintf (s, " relay: %d, %s", pin, ON == state ? "ON" : "OFF");
Serial.println (s);
void plus24V () {
relay (ECO_RELAY_1, ON); // turn on relay 1
relay (ECO_RELAY_2, OFF); // relay 2 is opposite for power
void minus24V () {
relay (ECO_RELAY_1, OFF); // turn off relay 1
relay (ECO_RELAY_2, ON); // relay 2 is opposite for power
void off24V () { // turn off both when both are ON or both are OFF, the electrodes are OFF!
relay (RECIRC_PUMP, OFF);
void loop (void)
timeUpdate ();
switch (state) {
case POS:
// Serial.println (" POS");
if (RecircOffHour <= hour ()) {
off24V ();
state = STOP;
else if (minutes () % 2) {
minus24V ();
state = NEG;
case NEG:
// Serial.println (" NEG");
off24V ();
state = STOP;
else if (! (minutes () % 2)) {
plus24V ();
state = POS;
default:
case STOP:
// Serial.println (" STOP");
if (RecircOnHour <= hour () && hour () < RecircOffHour) {
relay (RECIRC_PUMP, ON);
plus24V ();
state = POS;
void setup (void)
Serial.begin (115200);
digitalWrite (RECIRC_PUMP, OFF);
digitalWrite (ECO_RELAY_1, OFF);
digitalWrite (ECO_RELAY_2, OFF);
pinMode (RECIRC_PUMP, OUTPUT);
pinMode (ECO_RELAY_1, OUTPUT);
pinMode (ECO_RELAY_2, OUTPUT);
results
15:57:15
15:57:30
15:57:45
15:58:00
15:58:15
15:58:30
15:58:45
15:59:00
15:59:15
15:59:30
15:59:45
16:00:00
relay: 10, ON
relay: 11, ON
relay: 12, OFF
16:00:15
16:00:30
16:00:45
16:01:00
relay: 11, OFF
relay: 12, ON
16:01:15
16:01:30
16:01:45
16:02:00
relay: 11, ON
relay: 12, OFF
16:02:15
16:02:30
16:02:45
16:03:00
relay: 11, OFF
relay: 12, ON
16:03:15
16:03:30
16:03:45
16:04:00
relay: 11, ON
relay: 12, OFF
16:04:15
16:04:30
16:04:45
16:05:00
relay: 11, OFF
relay: 12, ON
16:05:15
16:05:30
16:05:45
16:06:00
relay: 11, ON
relay: 12, OFF
16:06:15
16:06:30
16:06:45
16:07:00
relay: 11, OFF
relay: 12, ON
16:07:15
16:07:30
16:07:45
16:08:00
relay: 11, ON
relay: 12, OFF
16:08:15
16:08:30
16:08:45
16:09:00
relay: 11, OFF
relay: 12, ON
16:09:15
16:09:30
16:09:45
16:10:00
relay: 11, ON
relay: 12, OFF
16:10:15
16:10:30
16:10:45
16:11:00
relay: 11, OFF
relay: 12, ON
16:11:15
16:11:30
16:11:45
16:12:00
relay: 11, ON
relay: 12, OFF
16:12:15
16:12:30
16:12:45
16:13:00
relay: 11, OFF
relay: 12, ON
16:13:15
16:13:30
16:13:45
16:14:00
relay: 11, ON
relay: 12, OFF
16:14:15
16:14:30
16:14:45
16:15:00
relay: 11, OFF
relay: 12, ON
16:15:15
16:15:30
16:15:45
16:16:00
relay: 11, ON
relay: 12, OFF
16:16:15
16:16:30
16:16:45
16:17:00
relay: 11, OFF
relay: 12, ON
16:17:15
16:17:30
16:17:45
16:18:00
relay: 11, ON
relay: 12, OFF
16:18:15
16:18:30
16:18:45
16:19:00
relay: 11, OFF
relay: 12, ON
16:19:15
16:19:30
16:19:45
16:20:00
relay: 11, ON
relay: 12, OFF
16:20:15
16:20:30
16:20:45
16:21:00
relay: 11, OFF
relay: 12, ON
16:21:15
16:21:30
16:21:45
16:22:00
relay: 11, ON
relay: 12, OFF
16:22:15
16:22:30
16:22:45
16:23:00
relay: 11, OFF
relay: 12, ON
16:23:15
16:23:30
16:23:45
16:24:00
relay: 11, ON
relay: 12, OFF
16:24:15
16:24:30
16:24:45
16:25:00
relay: 11, OFF
relay: 12, ON
16:25:15
16:25:30
16:25:45
16:26:00
relay: 11, ON
relay: 12, OFF
16:26:15
16:26:30
16:26:45
16:27:00
relay: 11, OFF
relay: 12, ON
16:27:15
16:27:30
16:27:45
16:28:00
relay: 11, ON
relay: 12, OFF
16:28:15
16:28:30
16:28:45
16:29:00
relay: 11, OFF
relay: 12, ON
16:29:15
16:29:30
16:29:45
16:30:00
relay: 11, ON
relay: 12, OFF
16:30:15
16:30:30
16:30:45
16:31:00
relay: 11, OFF
relay: 12, ON
16:31:15
16:31:30
16:31:45
16:32:00
relay: 11, ON
relay: 12, OFF
16:32:15
16:32:30
16:32:45
16:33:00
relay: 11, OFF
relay: 12, ON
16:33:15
16:33:30
16:33:45
16:34:00
relay: 11, ON
relay: 12, OFF
16:34:15
16:34:30
16:34:45
16:35:00
relay: 11, OFF
relay: 12, ON
16:35:15
16:35:30
16:35:45
16:36:00
relay: 11, ON
relay: 12, OFF
16:36:15
16:36:30
16:36:45
16:37:00
relay: 11, OFF
relay: 12, ON
16:37:15
16:37:30
16:37:45
16:38:00
relay: 11, ON
relay: 12, OFF
16:38:15
16:38:30
16:38:45
16:39:00
relay: 11, OFF
relay: 12, ON
16:39:15
16:39:30
16:39:45
16:40:00
relay: 11, ON
relay: 12, OFF
16:40:15
16:40:30
16:40:45
16:41:00
relay: 11, OFF
relay: 12, ON
16:41:15
16:41:30
16:41:45
16:42:00
relay: 11, ON
relay: 12, OFF
16:42:15
16:42:30
16:42:45
16:43:00
relay: 11, OFF
relay: 12, ON
16:43:15
16:43:30
16:43:45
16:44:00
relay: 11, ON
relay: 12, OFF
16:44:15
16:44:30
16:44:45
16:45:00
relay: 11, OFF
relay: 12, ON
16:45:15
16:45:30
16:45:45
16:46:00
relay: 11, ON
relay: 12, OFF
16:46:15
16:46:30
16:46:45
16:47:00
relay: 11, OFF
relay: 12, ON
16:47:15
16:47:30
16:47:45
16:48:00
relay: 11, ON
relay: 12, OFF
16:48:15
16:48:30
16:48:45
16:49:00
relay: 11, OFF
relay: 12, ON
16:49:15
16:49:30
16:49:45
16:50:00
relay: 11, ON
relay: 12, OFF
16:50:15
16:50:30
16:50:45
16:51:00
relay: 11, OFF
relay: 12, ON
16:51:15
16:51:30
16:51:45
16:52:00
relay: 11, ON
relay: 12, OFF
16:52:15
16:52:30
16:52:45
16:53:00
relay: 11, OFF
relay: 12, ON
16:53:15
16:53:30
16:53:45
16:54:00
relay: 11, ON
relay: 12, OFF
16:54:15
16:54:30
16:54:45
16:55:00
relay: 11, OFF
relay: 12, ON
16:55:15
16:55:30
16:55:45
16:56:00
relay: 11, ON
relay: 12, OFF
16:56:15
16:56:30
16:56:45
16:57:00
relay: 11, OFF
relay: 12, ON
16:57:15
16:57:30
16:57:45
16:58:00
relay: 11, ON
relay: 12, OFF
16:58:15
16:58:30
16:58:45
16:59:00
relay: 11, OFF
relay: 12, ON
16:59:15
16:59:30
16:59:45
17:00:00
relay: 11, OFF
relay: 12, OFF
relay: 10, OFF
17:00:15
17:00:30
17:00:45
17:01:00
17:01:15
17:01:30
17:01:45
