I'm using sets of these sainsmart relays to switch some 12v, 24v, and 120v. 4 Channel 5v Relay
While I understand the amount and frequency of switching plays a big role in the lifespan of the relays, in some cases they will be needed to have the circuit connected for the vast majority of the time. Is there any difference in lifespan if that happens over the normally open vs normally closed sides?
Would the answer be different for solid state relays?
The mechanical movement of the armature is of consideration. example 50 million operations can be easily achieved.
The load current you are switching and the type, resistive vs inductive, is important for contact life. Adding contact snubbing will prolong their life.
Using N.O. may be of importance if there is a power fail as you can imagine.
No matter which type of relay you use, you should design against possible failures and consider having a manual fall back circuit.
Just realized I missed adding the link to my relays (added to original post now). Do I benefit from adding snubbing to these for contact arching? If so, what would be the recommending approach to snub?
Designing against failures is a point well taken.
If contacts fuse though, I have a failure whether open or closed on these SPDTs. I am only using one side though essentially as on/off switch so curious if there would be a difference, all other things equal, in lifespan from using NO vs NC
In the real world, a bit of relay contact arcing is necessary to keep oxides and other contamination cleaned off the contacts. On the other side of the problem, running DC through normally closed contacts for months or longer, with no relay operation to ever open the contacts, will fuse the contacts due to metal migration caused by the continuous DC.
And .... you get what you pay for .. Those are fairly low cost “hobby” relays and doubt they would last as long as a good quality “Industrial “ type relay:
If you put the snubber circuit across the load, not the relay, then you won't have leakage currents
when the relay is off, and the snubber component values are specific to the load they really belong with
it.
