@LarryD
Hello Larry, Recently I have seen your post in one of the topic and I need the similar solution but for 12v relay module. I tried few things but not working as expected.
Here is the image I got from one of your post... and I tried the same way but not working.
Am I connected properly or anything missing?
I need to use the same like above but for 12v relay module. Please help me on this.
One more thing I didn't understand why we need to connect 12v DC to the pin A5 through resistors. Is it really required to drive the relay?
jim-p
February 25, 2024, 6:43pm
26
If you have it connected as in post #8 and #16 then you don't need any circuit to drive the relay.
Hi, @chandu-mca06
Can you please post some pictures of your project?
So we can see your component layout.
Do you have a DMM? (Digital MultiMeter)
Thanks.. Tom..
@LarryD Hello Larry, Can you please help me on this?
JCA34F
February 26, 2024, 12:24pm
29
Which Arduino are you using? Is it still working (will it run the blink program)?
JCA34F
February 26, 2024, 1:02pm
30
On the pictures in post # 8, I don't see any terminals or jumper block. Are the opto and transistor in the schematic external to the relay?
I am using Arduino nano. Yes blink sketch is working fine.
I connected the relay as same as in the diagram at post#25. All connections are same except A5 pin. I didn't use A5 in my project but rest of the connections are same.
LarryD
February 26, 2024, 3:43pm
33
Let’s do a reset.
As requested, do you have a Digital Multi Meter ?
Please give us a link to the relay module you have.
We need to see the actual wiring showing good images of all connections.
Measure the 5 and 12 voltages, what are they.
Let's start with this schematic:
JCA34F
February 26, 2024, 4:10pm
34
So, you have a barefoot relay, not the relay module you inferred.
I'm done, good luck.
Yes it is working now as expected. i missed to connect both grounds .
Thank you @LarryD
