Hye Everyone,
Sorry in advance for my English (I'm French so... well you know), I'll make my best to be understood.
I'm doing an alternative version of the "famous" DSO Shell mini oscillator,
I've got a "simple" problem, see below :
The main idea :
On the One Hand I've got a PCB with a 8pins, 3 ways switch. On the other Hand I've got a best 3 ways switch (with a beautifull blue led) but with only 6 pins (+2 but only for the blue led power)
The aim is to replace the 8pin switch by the 6pin switch (all détails will come in time, be confiant)
Technical datas :
New 6 pin Switch :
https://fr.aliexpress.com/item/ONPOW-22mm-3-position-Maintain-2NO2NC-Ring-LED-Square-Plastic-Knob-switch-LAS1-APF-22X-31/32821032514.html?spm=a2g0s.9042311.0.0.DPsx7r
Global Electronical Shem :
https://www.jyetech.com/Products/LcdScope/Schematic_150analog.pdf
All caractéristic and shems are included in the links
Where the swith should be (8 broches => 6+2) : Note, the two big holes are made to fix the switch but are connected to "nothing".
The idea here is to wire the new switch but what are we supposed to do with the to remaining holes ?
Global View of the pcb board… (the switch should be on the upper right):
Link of the object concerned by this procject. :
https://www.jyetech.com/Products/LcdScope/e150.php
To conclude, I know the "new" switch is not really good for my purpose but I definitively want to use it so I'm searching for a way to adapt it
Thank's for your help
Ps : At this time, I thought of wiring it as below :
Switch 1 Switch 2
Pin1 N01
Pin2 Nc1 (defaut)
Com C1 + C2
Pin3 N02
And, for the NC1 concern (wich should be "open" when NO2 is "closed"), I thought to add a mosfet transistor to NC1 pin driven by NO2 pin.
As below (main idea of the shematics) :
