It would be very good if i was able to write input parameters to the serial, which are read by an external program on a computer which performs an integration/differentiation operation the output of which is read by the original MC sketch that sent the initial parameter values, for a subsequent step.
Has anyone ever encountered a need for this? I'm quite sure i can make a maplet using maple and build an interface for sending it parameters via a VB form interface but im just having trouble with things because i am self taught hence i rely on you guys.
Serial.print() or Serial.println().
Serial.available(), Serial.read(), atoi() and atof().
but they taught me to use maple in uni for the first 3 yrs so yep i use it as much as possible.
I just finished turning a 20" bowl from a maple burl. So, seeing maple just made me need to yank your chain a little.
why isnt atoi() & atof() in arduino ref
There is a lot of stuff that isn't in the Arduino reference documentation, because it is not Arduino-specific. sprintf(), strcmp(), atoi(), atof(), memset(), memcmp(), sscanf() just to name a few commonly used C functions that are not documented there.
