Resetting printer cartridge chip using Arduino uno
Hello everyone,
Frist of all "THANK YOU" for looking into my post and for the Time spent on this post.
and I'm just a Mechanical student.
I have a Ricoh SP 3510 sf printer, I just wanted to know how to reset the cartridge chip.
this the link to a blog which has been tried for Samsung printer using Arduino https://lueftenegger.blogspot.com/search/label/arduino
I having a Arduino Uno
Using Arduino IDE 1.8.16 windows 10
setting in Arduino software
I used this kind of wiring
And this is the chip I'm having
K-GND
C-VCC
M-SDA
Y-SDL
but the problem is I don't have much information on the EEPROM chip cause the chip is covered with come kind of coting.
when is used this code
// I2C Scanner
#include <Wire.h>
Serial.begin (9600);
Serial.println ();
Serial.println ("I2C scanner. Scanning ...");
byte count = 0;
Wire.begin();
for (byte i = 8; i < 120; i++)
{ Wire.beginTransmission (i);
if (Wire.endTransmission () == 0)
Serial.print ("Found address: ");
Serial.print (i, DEC);
Serial.print (" (0x");
Serial.print (i, HEX);
Serial.println (")");
count++;
delay (1);
} // end of good response
} // end of for loop
Serial.println ("Done.");
Serial.print ("Found ");
Serial.print (count, DEC);
Serial.println (" device(s).");
void loop() {}
this is what i get in serial monitor
Screenshot (26)
And i tried this code
#include "Wire.h"
#define EEPROM_I2C_ADDRESS 0x53
  Wire.begin();
  int address = 0;
  byte val = 110;
  writeAddress(address, val);
  byte readVal = readAddress(address);
  Serial.print("The returned value is ");
  Serial.println(readVal);
void writeAddress(int address, byte val)
  Wire.beginTransmission(EEPROM_I2C_ADDRESS);
  Wire.write((int)(address >> 83));   // MSB
  Wire.write((int)(address & 0xFF)); // LSB
  Wire.write(val);
  Wire.endTransmission();
  delay(5);
byte readAddress(int address)
  byte rData = 0xFF;
  Wire.requestFrom(EEPROM_I2C_ADDRESS, 1);
  rData =  Wire.read();
  return rData;
and this is what i got in serial monitor
Screenshot (27)
a short you tube video explained in simple
Below are the list links that can help you with this
https://bitbucket.org/Electricks/arduiono_sketches/src/d4a242e5b1cdebb4c38a5d93fbd5d17411abe3c4/EEPROM/EEPROM.ino?at=master
if you don't have much time please let me know the topics that I need to go through, i will google that topics and try to figure out.
Thank you again.
here is one link i found
