sketch_feb11a:4: error: 'RF24' does not name a type sketch_feb11a:5: error: 'RF24Audio' does not name a type sketch_feb11a.ino: In function 'void setup()': sketch_feb11a:9: error: 'rfAudio' was not declared in this scope
I have found in my experience that this can be caused by a few things.
Firstly, have you made sure to include the RF24 library at the beginning of your sketch?
If you have that, then you need to make sure that the RF24 library is actually in your Arduino libraries folder.
If that is also present, make sure that it is at the right level. When importing new libraries, I have often made the mistake of nesting the folder too deep.
You should have it as such: C:\Program Files (x86)\Arduino\libraries\RF24
This folder then needs to contain the .h and .cpp files.
If you had C:\Program Files (x86)\Arduino\libraries\RF24\RF24
which contained the .h and .cpp files, it will not work as it is one level too deep.
I'm assuming you're on Windows here but I think it applies to all OSs.
Ok, it was one level too deep in the RF24 Folder, but now the Minimal Sketch from TMRH20 is giving me this error. No idea what it means, I've only changed the numbers.
Minimal:37: error: variable 'RF24 radio' has initializer but incomplete type
CODE:
/* RF24 Audio Library TMRh20 2014 This sketch is intended to demonstrate the most basic functionality of the audio library. Requirements: 2 Arduinos (Uno,Nano,Mega, etc supported) 2 NRF24LO1 Radio Modules 1 or more input devices (microphone, ipod, etc) 1 or more output devices (speaker, amplifier, etc) 1 or more external buttons or switches to control recording/volume/etc. Setup: 1. Change the CE,CS pins below to match your chosen pins (I use 7,8 on 328 boards, and 48,49 on Mega boards) 2. Connect buttons as desired to the button pins listed below. 2. Upload this sketch to two or more devices 3. Use external buttons to control all devices Default Pin Selections: Speaker: pins 9,10 on UNO, Nano, pins 11,12 on Mega 2560 Input/Microphone: Analog pin A0 on all boards Transmit button: Pin A1 VolumeUp button: Pin A2 VolumeDn button: Pin A3 Remote Transmission: Pin A4 Note: See http://arduino.cc/en/Tutorial/InputPullupSerial for info on how to wire the buttons to the pins Note: Pin selections can be overridden by modifying the userConfig.h file included with the library */ #include <RF24.h> #include <SPI.h> #include <RF24Audio.h> RF24 radio(9,10); // Set radio up using pins 7 (CE) 8 (CS) RF24Audio rfAudio(radio,1); // Set up the audio using the radio, and set to radio number 0.
** // Setting the radio number is only important if one-to-one communication is desired**
** // in a multi-node radio group. See the privateBroadcast() function.** void setup() { **
** rfAudio.begin(); // The only thing to do is initialize the library. } void loop() {
** // Audio playback and button handling is all managed internally.**
** // In this example, the radio is controlled by external buttons, so there is nothing to do here**
