So I have been working trying to measure the velocity of a string attaches using Rfduino microcontroller.
I have downloaded all the library(based on RFDuino Tutorial #1 - Getting Started (Windows and Android) - YouTube) and check the PCB all the connection via multimeter ( i have made the PCB, and assemble via Chineses manufacture). and connect PCB to my laptop via FTDI board as this;
When I compile the code it.It's compiled nicely.But when I try to doenload the code it says
RFduino device required for RFduino hex file.
Does anyone had any experience with this sort of error message?
(this is my first question in this forum. I don't no this belong to hardware or software side)
any help would be appreciated!
Thanks, Heaps!
Hi Pert,
Thanks for the advice!!
I'm trying to program RFD22302 micro using RFD22121 USB shield and USB MicroB Plug Breakout board.
RFD22302: : https://sg.rs-online.com/web/p/bluetooth-modules/8011698/
RFD22121 : https://sg.rs-online.com/web/p/products/8011695/
USB MicroB Plug Breakout board ; SparkFun USB MicroB Plug Breakout - BOB-10031 - SparkFun Electronics
RFD22121 USB shield and USB MicroB circuit: rfddd hosted at ImgBB — ImgBB
and IDE error message shows:
Arduino: 1.8.9 (Windows 10), Board: "RFduino"
Sketch uses 76896 bytes (58%) of program storage space. Maximum is 131072 bytes.
Global variables use 7396 bytes of dynamic memory.
C:\Users\karannch\AppData\Local\Arduino15\packages\RFduino\hardware\RFduino\2.3.3//RFDLoader.exe -q COM19 C:\Users\karannch\AppData\Local\Temp\arduino_build_723934/OBTest.ino.hex
____________________
OBTest.ino.hex
fail.......fail.......fail.......
An error occurred while uploading the sketch
option enabled in File -> Preferences.
any help kindly appreciated!
Can anyone haplll please!!
