freaklabs:
When you have code, its best to post it directly in your question as so:
#include <Servo.h>
#include<SPI.h>
#include<MFRC522.h>
#include<SoftwareSerial.h>
#include <Ethernet.h>
#include <HttpClient.h>
#define SS_PIN 5 //FOR RFID SS PIN BECASUSE WE ARE USING BOTH ETHERNET SHIELD AND RS-522
#define RST_PIN 9
#define No_Of_Card 3
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
Servo myservo;
int pos = 0;
int buzzerPin = 2;
char server[] = "www.kodlamaegitimi.biz"; //YOUR SERVER
IPAddress ip(192, 168, 137, 1);
EthernetClient client;
SoftwareSerial mySerial(6,7);
MFRC522 rfid(SS_PIN,RST_PIN);
MFRC522::MIFARE_Key key;
byte id[No_Of_Card][4]={
{240,135,55,166}, //RFID NO-1
{252,41,131,99}, //RFID NO-2
{151,94,80,84} //RFID NO-3
byte id_temp[3][3];
byte i;
int j=0;
mySerial.begin(9600);
SPI.begin();
rfid.PCD_Init();
for(byte i=0;i<6;i++)
key.keyByte[i]=0xFF;
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
Ethernet.begin(mac, ip);
Serial.println("connecting...");
myservo.attach(8);
{int m=0;
if(!rfid.PICC_IsNewCardPresent())
return;
if(!rfid.PICC_ReadCardSerial())
return;
for(i=0;i<4;i++)
id_temp[0][i]=rfid.uid.uidByte[i];
delay(50);
for(i=0;i<No_Of_Card;i++)
if(id[i][0]==id_temp[0][0])
if(id[i][1]==id_temp[0][1])
if(id[i][2]==id_temp[0][2])
if(id[i][3]==id_temp[0][3])
Serial.print("your card no :");
for(int s=0;s<4;s++)
Serial.print(rfid.uid.uidByte[s]);
Serial.print(" ");
Serial.println("\nVALID");
Sending_To_DB();
girisSes();
ac();
j=0;
rfid.PICC_HaltA();
rfid.PCD_StopCrypto1();
return;
{j++;
if(j==No_Of_Card)
Serial.println("inVALID");
Sending_To_DB();
engellendiSes();
Serial.print(" ");
j=0;
// Halt PICC
rfid.PICC_HaltA();
// Stop encryption on PCD
void ac() {
for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(3); // waits 15ms for the servo to reach the position
for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
void girisSes()
tone(2, 494);
delay(40);
noTone(buzzerPin);
delay(20);
void engellendiSes()
for (int i=0;i<2;i++)
tone(2, 494);
delay(20);
noTone(buzzerPin);
delay(20); }
void Sending_To_DB() //CONNECTING WITH MYSQL
if (client.connect(server, 80)) {
//Serial.println("connected");
// Make a HTTP request:
client.print("GET /rfid/rfid_read.php?allow="); //YOUR URL
if(j!=No_Of_Card)
client.print('1');
client.print('0');
client.print("&id=");
client.print(rfid.uid.uidByte[s]);
client.print(" "); //SPACE BEFORE HTTP/1.1
client.print("HTTP/1.1");
client.println();
client.println("Host: www.kodlamaegitimi.biz");
client.println("Connection: close");
client.println();
printDec(rfid.uid.uidByte,rfid.uid.size);
if (client.connected()) {
client.stop();
// if you didn't get a connection to the server:
// Serial.println("connection failed");
client.stop();
void printDec(byte *buffer, byte bufferSize) {
for (byte i = 0; i < bufferSize; i++) {
Serial.print(buffer[i] < 0x10 ? " 0" : " ");
Serial.print(buffer[i], DEC);
Thanks. I couldn' t find it yesterday.
