Hi everyone, I was using python. Now I want to use Arduino Code. RFID reader is working with UART. RFID reader has only tx pin for communication. RFID reader has reset pin and I need to use it.
RFID reader has low level reset. I was using it like this;
I tried another sleep situations for example like this;
digitalWrite(resetrfid, LOW);
while (Serial1.available())
b = Serial1.read();
Serial.print(b);
digitalWrite(resetrfid, HIGH);
But I couldn't do this. With this code, RFID is only reading one time, that's it. I want to read more if RFID tag is still in RFID reader range. What is the problem ?
This is arduinoforum I post this question in a topic but as I said I was using micropython so I manage to do my problem. I couldn't do the same with arduino.
You need to send that reader a LOW (I think, otherwise try HIGH) pulse.
Try
digitalWrite(resetrfid, HIGH); // Set high to start with
delay(200); // Keep high for a while
digitalWrite(resetrfid, LOW); // Set LOW for x ms
delay(50); // You might need to vary this time... start with 50ms and increase
digitalWrite(resetrfid, HIGH); // Set high again
And you only need do this after you find a card... so you can immediately read again.
b = Serial1.read();
Serial.print(b);
delay(50);
b = Serial1.read();
Serial.print(b);
Serial.begin (9600);
Serial1.begin (9600);
pinMode(resetrfid, OUTPUT);
b = Serial1.read();
Serial.print(b);
delay(50);
I am trying like this but it doesn't work. I tried to change HIGH to LOW this didn't work too.
Don't do it every loop... ONLY do it once you have read a card.
Put the reset code in a routine, and only call it when you need to. The end of the while loop does not necessarily mean you have finished reading a card... at 9600 baud the processor is way faster than the data is coming in.
Where's your actual code that reads the cards? ... the above code is really just displaying bytes as they come in.
#include <Arduino.h>
byte b;
byte buffer[30];
uint8_t idx;
boolean started = false;
byte XOR;
byte inverted;
char receivedChar;
uint64_t value;
unsigned long startTimeGet = 0;
String i, z;
int resetrfid = 13;
char *uint64_to_string(uint64_t input)
static char result[21] = "";
// Clear result from any leftover digits from previous function call.
memset(&result[0], 0, sizeof(result));
// temp is used as a temporary result storage to prevent sprintf bugs.
char temp[21] = "";
char c;
uint8_t base = 10;
while (input)
int num = input % base;
input /= base;
c = '0' + num;
sprintf(temp, "%c%s", c, result);
strcpy(result, temp);
return result;
void print_uint64_t(uint64_t num)
char rev[128];
char *p = rev + 1;
while (num > 0)
*p++ = '0' + (num % 10);
num /= 10;
p--;
/*Print the number which is now in reverse*/
while (p > rev)
Serial.print(*p--);
if (Serial1.available())
b = Serial1.read();
if (b == 0x02) // Start byte
idx = 0;
started = true;
if (started) // Ignore anything received until we get a start byte.
buffer[idx++] = b;
if (b == 0x03) // End byte
delay(50);
started = false;
// Extract the card number from bytes 01 (LSB) - 10 (MSB).
value = 0;
for (int x = 10; x >= 1; x--)
if (buffer[x] <= '9')
value = (value << 4) + buffer[x] - '0';
value = (value << 4) + buffer[x] - '7';
Serial.print("Card number: ");
i = uint64_to_string(value);
Serial.println(value);
// Extract the country number from bytes 11 (LSB) - 14 (MSB).
value = 0;
for (int x = 14; x >= 11; x--)
Serial.print("Country number: ");
z = uint64_to_string(value);
if (z == NULL)
z = "0";
Serial.println(z);
Serial.println(z + i);
byte b;
byte buffer[30];
uint8_t idx;
byte XOR;
byte inverted;
char receivedChar;
uint64_t value;
String i, z;
int resetrfid = 13;
char temp[21] = "";
char c;
uint8_t base = 10;
while (input)
input /= base;
c = '0' + num;
return result;
char rev[128];
char *p = rev + 1;
while (num > 0)
num /= 10;
p--;
while (p > rev)
Serial.print(*p--);
delay(50);
b = Serial1.read();
idx = 0;
started = true;
buffer[idx++] = b;
started = false;
value = 0;
value = 0;
if (z == NULL)
z = "0";
Serial.println(z);
delay(200);
digitalWrite(resetrfid, LOW); // Set high again
delay(50);
idx = 0;
started = true;
buffer[idx++] = b;
delay(200);
delay(50);
started = false;
How long a pulse is it expecting.. again you will need to try.
In micropython, I can use it with 0.1 second.
uart1 = UART(0, rx=Pin(1), tx=Pin(0), baudrate=9600)
reset=Pin(13,Pin.OUT)
while True:
time.sleep(0.1);
reset.low()
data=uart1.read()
if data!=None:
data = "".join([chr(c) for c in data])
txt = data[0:11]
reverse = "".join(reversed(txt)).strip()
country = data[11:14]
reverse2 = "".join(reversed(country)).strip()
i = int(reverse[0:10],16)
z= int(reverse2[0:3],16)
print(z,i,sep="")
reset.high()
In python, If I use only reset.high(), rfid is not working because reset pin is high (this reset pin low level triggered), but in Arduino Code, if I only write high or low , it doesn't change anything. It reads one time in range. I really don't understand why.
I tried with 100,200,500,1000 doesn't change anything. I still don't understand what is the problem. In micropython if I only write reset.high(), rfid don't work. In Arduino, it doesn't change anything, It reads one time in range.
