RFID Reader to turn on LED
Ive seen lots of tutorials online and tried to follow along with them. I can get this project working when i use the example codes and modify them. However this code i wrote from scratch and cant seem to get it to work.
My serial monitor just show "GO" and then nothing after that. Any ideas how to fix this?
Im also getting an error when verifying "warning: invalid conversion from 'byte* {aka unsigned char*}' to 'byte {aka unsigned char}' [-fpermissive]
byte correcttag = taga;
C:\Users\Escape Artist AZ\Documents\Sketches\RFID_Read_1-18-21\RFID_Read_1-18-21.ino: In function 'void checkcorrect()':
RFID_Read_1-18-21:69:33: error: invalid types 'byte {aka unsigned char}[int]' for array subscript
if (lasttag[0] == correcttag[0] ||
RFID_Read_1-18-21:70:33: error: invalid types 'byte {aka unsigned char}[int]' for array subscript
lasttag[1] == correcttag[1] ||
RFID_Read_1-18-21:71:33: error: invalid types 'byte {aka unsigned char}[int]' for array subscript
lasttag[2] == correcttag[2] ||
RFID_Read_1-18-21:72:33: error: invalid types 'byte {aka unsigned char}[int]' for array subscript
lasttag[3] == correcttag[3] )
exit status 1
option enabled in File -> Preferences.
FULL CODE BELOW
#include <SPI.h>
#include <MFRC522.h>
//define used pins
byte sdapin = 53;
byte resetpin = 5;
byte greenpin = 8;
byte redpin = 9;
//begin scanning
MFRC522 scannerone(sdapin, resetpin);
MFRC522::MIFARE_Key structure;
//UIDs of each tag
byte taga[4] = {167, 195, 90, 214};
byte tagb[4] = {103, 218, 138, 198};
byte tagc[4] = {167, 98, 177, 199};
byte tagd[4] = {51, 231, 169, 61};
byte tage[4] = {32, 154, 91, 47};
byte tagf[4] = {32, 208, 250, 47};
//stores the UID of the last tag scanned
byte lasttag[4] = {00, 00, 00, 00};
  SPI.begin(); // Init SPI bus
  scannerone.PCD_Init(); // Init MFRC522
  for (byte i = 0; i < 6; i++) {
    structure.keyByte[i] = 0xFF;
  pinMode(greenpin, OUTPUT);
  pinMode(redpin, OUTPUT);
  Serial.println("GO");
  if (scannerone.PICC_ReadCardSerial() == 1)
    Serial.println("Good");
    if (scannerone.uid.uidByte[0] != lasttag[0] ||
        scannerone.uid.uidByte[1] != lasttag[1] ||
        scannerone.uid.uidByte[2] != lasttag[2] ||
        scannerone.uid.uidByte[3] != lasttag[3] )
      Serial.println("A new card has been detected.");
      // Store NUID into lasttag array
      for (byte i = 0; i < 4; i++)
        lasttag[i] = scannerone.uid.uidByte[i];
        Serial.println(scannerone.uid.uidByte[i]);
      Serial.println(lasttag[1]);
      checkcorrect();
void checkcorrect()
    digitalWrite(greenpin, HIGH);
True. You declare 'correcttag' as a byte, then try to use it as an array, 'correcttag[0]'. See?
How can i set correcttag to taga? Do i have to do a for statement and set each part individually?
Bump
Change:
to:
byte *correcttag = taga;
What is the purpose of the asterisk? I’ve seen it in a couple codes but I don’t know what it’s for.
escapeartistaz:
Pointer. You can review C/C++ tutorials. Here is one:
C Pointers
Ive changed correct tag to a pointer. Still when i run my program i get "go" during my setup. Then nothing after that.
Still need answers on this. My reader is not sending anything to the serial monitor
bump
Can anyone answer this?
Im still hard stuck in the same spot if anyone can help please
SOMEONE PLEASE PLEASE PLEASE HELP ME
Please
help
Post your latest sketch and I will try to help.
This is the most up to date version. It just says go then nothing.
#include <SPI.h>
//define used pins
byte sdapin = 53;
byte resetpin = 5;
byte greenpin = 8;
byte redpin = 9;
//begin scanning
//UIDs of each tag
byte *correcttag = tagf;
//  I DONT REMEMBER WRITING THIS CAN ANYONE TELL ME WHAT ITS FOR???
  digitalWrite(redpin, HIGH);
      checkcorrect();
void checkcorrect()
Have you added some Serial.println statements into the loop() function to see if it is running? Try the loop() function I have below and see what prints.
Like this:
  Serial.println("Enter loop()");
      checkcorrect();
       Serial.println("Same card");
     Serial.println("PICC_ReadCardSerial() failed");
  Serial.println("Exit loop()");
