RFID-Relay-need help
Hello , please i need help in the code below,
I want to keep the relay stay ON position .when Access Granted ,
How I can do that ?? see the attached code I found in website....
#include <EEPROM.h> // We are going to read and write PICC's UIDs from/to EEPROM
#include <SPI.h> // RC522 Module uses SPI protocol
#include <MFRC522.h> // Library for Mifare RC522 Devices
// #include <Servo.h>
#define COMMON_ANODE
#ifdef COMMON_ANODE
#define LED_ON HIGH
#define LED_OFF LOW
#else
#define LED_ON LOW
#define LED_OFF HIGH
#endif
constexpr uint8_t redLed = 7; // Set Led Pins
constexpr uint8_t greenLed = 6;
constexpr uint8_t blueLed = 5;
constexpr uint8_t relay = 2; // Set Relay Pin
constexpr uint8_t wipeB = 4; // Button pin for WipeMode
boolean match = false; // initialize card match to false
boolean programMode = false; // initialize programming mode to false
boolean replaceMaster = false;
uint8_t successRead; // Variable integer to keep if we have Successful Read from Reader
byte storedCard[4]; // Stores an ID read from EEPROM
byte readCard[4]; // Stores scanned ID read from RFID Module
byte masterCard[4]; // Stores master card's ID read from EEPROM
// Create MFRC522 instance.
constexpr uint8_t RST_PIN = 9; // Configurable, see typical pin layout above
constexpr uint8_t SS_PIN = 10; // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN);
///////////////////////////////////////// Setup ///////////////////////////////////
//Arduino Pin Configuration
pinMode(redLed, OUTPUT);
pinMode(greenLed, OUTPUT);
pinMode(blueLed, OUTPUT);
pinMode(wipeB, INPUT_PULLUP); // Enable pin's pull up resistor
pinMode(relay, OUTPUT);
//Be careful how relay circuit behave on while resetting or power-cycling your Arduino
digitalWrite(relay, LOW); // Make sure door is locked
digitalWrite(redLed, LED_OFF); // Make sure led is off
digitalWrite(greenLed, LED_OFF); // Make sure led is off
digitalWrite(blueLed, LED_OFF); // Make sure led is off
//Protocol Configuration
Serial.begin(9600); // Initialize serial communications with PC
SPI.begin(); // MFRC522 Hardware uses SPI protocol
mfrc522.PCD_Init(); // Initialize MFRC522 Hardware
//If you set Antenna Gain to Max it will increase reading distance
//mfrc522.PCD_SetAntennaGain(mfrc522.RxGain_max);
Serial.println(F("Access Control Example v0.1")); // For debugging purposes
ShowReaderDetails(); // Show details of PCD - MFRC522 Card Reader details
//Wipe Code - If the Button (wipeB) Pressed while setup run (powered on) it wipes EEPROM
if (digitalRead(wipeB) == LOW) { // when button pressed pin should get low, button connected to ground
digitalWrite(redLed, LED_ON); // Red Led stays on to inform user we are going to wipe
Serial.println(F("Wipe Button Pressed"));
Serial.println(F("You have 10 seconds to Cancel"));
Serial.println(F("This will be remove all records and cannot be undone"));
bool buttonState = monitorWipeButton(10000); // Give user enough time to cancel operation
if (buttonState == true && digitalRead(wipeB) == LOW) { // If button still be pressed, wipe EEPROM
Serial.println(F("Starting Wiping EEPROM"));
for (uint16_t x = 0; x < EEPROM.length(); x = x + 1) { //Loop end of EEPROM address
if (EEPROM.read(x) == 0) { //If EEPROM address 0
// do nothing, already clear, go to the next address in order to save time and reduce writes to EEPROM
else {
EEPROM.write(x, 0); // if not write 0 to clear, it takes 3.3mS
Serial.println(F("EEPROM Successfully Wiped"));
digitalWrite(redLed, LED_OFF); // visualize a successful wipe
delay(200);
delay(200);
delay(200);
delay(200);
else {
Serial.println(F("Wiping Cancelled")); // Show some feedback that the wipe button did not pressed for 15 seconds
// Check if master card defined, if not let user choose a master card
// This also useful to just redefine the Master Card
// You can keep other EEPROM records just write other than 143 to EEPROM address 1
// EEPROM address 1 should hold magical number which is '143'
if (EEPROM.read(1) != 143) {
Serial.println(F("No Master Card Defined"));
Serial.println(F("Scan A PICC to Define as Master Card"));
do {
successRead = getID(); // sets successRead to 1 when we get read from reader otherwise 0
digitalWrite(blueLed, LED_ON); // Visualize Master Card need to be defined
delay(200);
delay(200);
while (!successRead); // Program will not go further while you not get a successful read
for ( uint8_t j = 0; j < 4; j++ ) { // Loop 4 times
EEPROM.write( 2 + j, readCard[j] ); // Write scanned PICC's UID to EEPROM, start from address 3
EEPROM.write(1, 143); // Write to EEPROM we defined Master Card.
Serial.println(F("Master Card Defined"));
Serial.println(F("-------------------"));
Serial.println(F("Master Card's UID"));
for ( uint8_t i = 0; i < 4; i++ ) { // Read Master Card's UID from EEPROM
masterCard[i] = EEPROM.read(2 + i); // Write it to masterCard
Serial.print(masterCard[i], HEX);
Serial.println("");
Serial.println(F("Everything is ready"));
Serial.println(F("Waiting PICCs to be scanned"));
cycleLeds(); // Everything ready lets give user some feedback by cycling leds
///////////////////////////////////////// Main Loop ///////////////////////////////////
void loop () {
do {
// When device is in use if wipe button pressed for 10 seconds initialize Master Card wiping
if (digitalRead(wipeB) == LOW) { // Check if button is pressed
// Visualize normal operation is iterrupted by pressing wipe button Red is like more Warning to user
digitalWrite(redLed, LED_ON); // Make sure led is off
// Give some feedback
Serial.println(F("Master Card will be Erased! in 10 seconds"));
EEPROM.write(1, 0); // Reset Magic Number.
Serial.println(F("Master Card Erased from device"));
Serial.println(F("Please reset to re-program Master Card"));
while (1);
Serial.println(F("Master Card Erase Cancelled"));
if (programMode) {
cycleLeds(); // Program Mode cycles through Red Green Blue waiting to read a new card
else {
normalModeOn(); // Normal mode, blue Power LED is on, all others are off
while (!successRead); //the program will not go further while you are not getting a successful read
if (programMode) {
if ( isMaster(readCard) ) { //When in program mode check First If master card scanned again to exit program mode
Serial.println(F("Master Card Scanned"));
Serial.println(F("Exiting Program Mode"));
Serial.println(F("-----------------------------"));
return;
else {
if ( findID(readCard) ) { // If scanned card is known delete it
Serial.println(F("I know this PICC, removing..."));
deleteID(readCard);
Serial.println("-----------------------------");
Serial.println(F("Scan a PICC to ADD or REMOVE to EEPROM"));
else { // If scanned card is not known add it
Serial.println(F("I do not know this PICC, adding..."));
writeID(readCard);
else {
if ( isMaster(readCard)) { // If scanned card's ID matches Master Card's ID - enter program mode
programMode = true;
Serial.println(F("Hello Master - Entered Program Mode"));
uint8_t count = EEPROM.read(0); // Read the first Byte of EEPROM that
Serial.print(F("I have ")); // stores the number of ID's in EEPROM
Serial.print(count);
Serial.print(F(" record(s) on EEPROM"));
Serial.println("");
Serial.println(F("Scan Master Card again to Exit Program Mode"));
else {
if ( findID(readCard) ) { // If not, see if the card is in the EEPROM
Serial.println(F("Welcome, You shall pass"));
granted(300); // Open the door lock for 300 ms
else { // If not, show that the ID was not valid
Serial.println(F("You shall not pass"));
denied();
///////////////////////////////////////// Access Granted ///////////////////////////////////
void granted ( uint16_t setDelay) {
digitalWrite(blueLed, LED_OFF); // Turn off blue LED
digitalWrite(redLed, LED_OFF); // Turn off red LED
digitalWrite(greenLed, LED_ON); // Turn on green LED
digitalWrite(relay, LOW); // Unlock door!
delay(100); // Hold door lock open for given seconds
digitalWrite(relay, HIGH); // Relock door
delay(1000); // Hold green LED on for a second
///////////////////////////////////////// Access Denied ///////////////////////////////////
void denied() {
digitalWrite(greenLed, LED_OFF); // Make sure green LED is off
digitalWrite(blueLed, LED_OFF); // Make sure blue LED is off
digitalWrite(redLed, LED_ON); // Turn on red LED
///////////////////////////////////////// Get PICC's UID ///////////////////////////////////
uint8_t getID() {
// Getting ready for Reading PICCs
if ( ! mfrc522.PICC_IsNewCardPresent()) { //If a new PICC placed to RFID reader continue
return 0;
if ( ! mfrc522.PICC_ReadCardSerial()) { //Since a PICC placed get Serial and continue
return 0;
// There are Mifare PICCs which have 4 byte or 7 byte UID care if you use 7 byte PICC
// I think we should assume every PICC as they have 4 byte UID
// Until we support 7 byte PICCs
Serial.println(F("Scanned PICC's UID:"));
for ( uint8_t i = 0; i < 4; i++) { //
readCard[i] = mfrc522.uid.uidByte[i];
Serial.print(readCard[i], HEX);
Serial.println("");
mfrc522.PICC_HaltA(); // Stop reading
return 1;
void ShowReaderDetails() {
// Get the MFRC522 software version
byte v = mfrc522.PCD_ReadRegister(mfrc522.VersionReg);
Serial.print(F("MFRC522 Software Version: 0x"));
Serial.print(v, HEX);
if (v == 0x91)
Serial.print(F(" = v1.0"));
else if (v == 0x92)
Serial.print(F(" = v2.0"));
Serial.print(F(" (unknown),probably a chinese clone?"));
Serial.println("");
// When 0x00 or 0xFF is returned, communication probably failed
if ((v == 0x00) || (v == 0xFF)) {
Serial.println(F("WARNING: Communication failure, is the MFRC522 properly connected?"));
Serial.println(F("SYSTEM HALTED: Check connections."));
// Visualize system is halted
while (true); // do not go further
///////////////////////////////////////// Cycle Leds (Program Mode) ///////////////////////////////////
void cycleLeds() {
digitalWrite(redLed, LED_OFF); // Make sure red LED is off
digitalWrite(greenLed, LED_ON); // Make sure green LED is on
delay(50);
digitalWrite(blueLed, LED_ON); // Make sure blue LED is on
delay(50);
digitalWrite(redLed, LED_ON); // Make sure red LED is on
delay(50);
//////////////////////////////////////// Normal Mode Led ///////////////////////////////////
void normalModeOn () {
digitalWrite(blueLed, LED_ON); // Blue LED ON and ready to read card
digitalWrite(redLed, LED_OFF); // Make sure Red LED is off
digitalWrite(greenLed, LED_OFF); // Make sure Green LED is off
digitalWrite(relay, LOW); // Make sure Door is Locked
//////////////////////////////////////// Read an ID from EEPROM //////////////////////////////
void readID( uint8_t number ) {
uint8_t start = (number * 4 ) + 2; // Figure out starting position
for ( uint8_t i = 0; i < 4; i++ ) { // Loop 4 times to get the 4 Bytes
storedCard[i] = EEPROM.read(start + i); // Assign values read from EEPROM to array
///////////////////////////////////////// Add ID to EEPROM ///////////////////////////////////
void writeID( byte a[] ) {
if ( !findID( a ) ) { // Before we write to the EEPROM, check to see if we have seen this card before!
uint8_t num = EEPROM.read(0); // Get the numer of used spaces, position 0 stores the number of ID cards
uint8_t start = ( num * 4 ) + 6; // Figure out where the next slot starts
num++; // Increment the counter by one
EEPROM.write( 0, num ); // Write the new count to the counter
EEPROM.write( start + j, a[j] ); // Write the array values to EEPROM in the right position
successWrite();
Serial.println(F("Succesfully added ID record to EEPROM"));
else {
failedWrite();
Serial.println(F("Failed! There is something wrong with ID or bad EEPROM"));
///////////////////////////////////////// Remove ID from EEPROM ///////////////////////////////////
void deleteID( byte a[] ) {
if ( !findID( a ) ) { // Before we delete from the EEPROM, check to see if we have this card!
failedWrite(); // If not
else {
uint8_t slot; // Figure out the slot number of the card
uint8_t start; // = ( num * 4 ) + 6; // Figure out where the next slot starts
uint8_t looping; // The number of times the loop repeats
uint8_t j;
uint8_t count = EEPROM.read(0); // Read the first Byte of EEPROM that stores number of cards
slot = findIDSLOT( a ); // Figure out the slot number of the card to delete
start = (slot * 4) + 2;
looping = ((num - slot) * 4);
num--; // Decrement the counter by one
for ( j = 0; j < looping; j++ ) { // Loop the card shift times
EEPROM.write( start + j, EEPROM.read(start + 4 + j)); // Shift the array values to 4 places earlier in the EEPROM
for ( uint8_t k = 0; k < 4; k++ ) { // Shifting loop
EEPROM.write( start + j + k, 0);
successDelete();
Serial.println(F("Succesfully removed ID record from EEPROM"));
///////////////////////////////////////// Check Bytes ///////////////////////////////////
boolean checkTwo ( byte a[], byte b[] ) {
if ( a[0] != 0 ) // Make sure there is something in the array first
match = true; // Assume they match at first
for ( uint8_t k = 0; k < 4; k++ ) { // Loop 4 times
if ( a[k] != b[k] ) // IF a != b then set match = false, one fails, all fail
match = false;
if ( match ) { // Check to see if if match is still true
return true; // Return true
else {
return false; // Return false
///////////////////////////////////////// Find Slot ///////////////////////////////////
uint8_t findIDSLOT( byte find[] ) {
for ( uint8_t i = 1; i <= count; i++ ) { // Loop once for each EEPROM entry
readID(i); // Read an ID from EEPROM, it is stored in storedCard[4]
if ( checkTwo( find, storedCard ) ) { // Check to see if the storedCard read from EEPROM
// is the same as the find[] ID card passed
return i; // The slot number of the card
break; // Stop looking we found it
///////////////////////////////////////// Find ID From EEPROM ///////////////////////////////////
boolean findID( byte find[] ) {
return true;
else { // If not, return false
return false;
///////////////////////////////////////// Write Success to EEPROM ///////////////////////////////////
// Flashes the green LED 3 times to indicate a successful write to EEPROM
void successWrite() {
digitalWrite(greenLed, LED_OFF); // Make sure green LED is on
delay(200);
delay(200);
delay(200);
delay(200);
delay(200);
delay(200);
///////////////////////////////////////// Write Failed to EEPROM ///////////////////////////////////
// Flashes the red LED 3 times to indicate a failed write to EEPROM
void failedWrite() {
delay(200);
delay(200);
delay(200);
delay(200);
delay(200);
delay(200);
///////////////////////////////////////// Success Remove UID From EEPROM ///////////////////////////////////
// Flashes the blue LED 3 times to indicate a success delete to EEPROM
void successDelete() {
delay(200);
delay(200);
delay(200);
delay(200);
delay(200);
delay(200);
////////////////////// Check readCard IF is masterCard ///////////////////////////////////
// Check to see if the ID passed is the master programing card
boolean isMaster( byte test[] ) {
if ( checkTwo( test, masterCard ) )
return true;
return false;
bool monitorWipeButton(uint32_t interval) {
uint32_t now = (uint32_t)millis();
while ((uint32_t)millis() - now < interval) {
// check on every half a second
if (((uint32_t)millis() % 500) == 0) {
if (digitalRead(wipeB) != LOW)
return false;
return true;
do you know where the code turns on the relay?
welcome to the forum. take a few minutes and read this: How to get the best out of this forum - Using Arduino / Installation & Troubleshooting - Arduino Forum
It will help others help you. After reading, edit your post and use code tags on your code. Also, what have you tried? Simply grabbing random code you don't understand and asking people to change it is not what this forum is about.
Comment out the line that says "Relock door".
//digitalWrite(relay, HIGH); // Relock door
hi Benjamin , unfortunately didnt work for me ,,it turn the relay off again , )-:
I want the relay stay ON after scan the RFID Granted .
Are you getting serial output in the monitor?
Also, it looks like from the code that when access is granted, it sets the relay pin to LOW. I don't know how your door lock is setup, but I would think that LOW is locked and HIGH activates the relay and unlocks the door?
