Hello,
this is my first post to this Forum. I hope you could help me with a project. The Idea:
I want to build something like that, but much smaller. I´m gonna use 16 X 3x3x40 cm Plexiglassplates one above the other. To light them up I use RGB LEDs.
My Questions:
Is one LED per side enough to light the whole plate up? So that I have 32 RGB LEDs?
Who is it possible to Control so much pins (96)?
I want to use the "74HC595" register. The project should cost as less as possible. Are four of them enough, when I multiplex the common pin and switch very fast thrue the RGB channels? Is the controller fast enough?
5mm LEDs (assuming that's the type you're describing) are very directional. I'd expect difficulty getting it to spread in a 360 degree pattern in the plexiglass plates (you should probably be using acrylic, btw).
74HC595 will not work well for this, the output current it can support is too low and the LEDs will be too dim.
Find common anode RGB LEDs and use TPIC6B595 instead.
Or use parts with more outputs, like WS2803, 18 I/O, can drive 6 RGB LEDs each.
Where are you located? Update your profile and add geographic information: Planet, Hemispshere, Continent, Country - something that will help us to locate a source.
Otherwise, try e-bay.
