In the final of building a project and can´t get the RGB LEDs to turn on. Can´t find any errors in the code and of course the LEDs are OK.
In my case I chenged from DHT 11 to DHT 22 and the Temp and Humidity works well on the LCD. The code below.
#include "DHT.h"
#define DHTPIN 4
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
float temp = 0;
float humi = 0;
int lcdColumns = 16;
int lcdRows = 2;
//If 0x3f address is not work, then change the address to 0x27
LiquidCrystal_I2C lcd (0x3f, lcdColumns, lcdRows);
int buzzer = 5;
int fan = 6;
int heater = 7;
int rgb[3] = {9, 10, 11};
uint8_t buzz[8] = {B00001, B00011, B00111, B11111, B11111, B00111, B00011, B00001};
uint8_t degree[8] = {B00000, B11000, B11000, B00000, B00000, B00000, B00000, B00000};
uint8_t tem[8] = {B00100, B01010, B01010, B01110, B01110, B11111, B11111, B01110};
uint8_t hum[8] = {B00100, B00100, B01010, B01010, B10001, B10001, B10001, B01110};
uint8_t fanEmoji[8] = {B00000, B11011, B11011, B00100, B11011, B11011, B00000, B00000};
uint8_t heaterEmoji[8] = {B00000, B10001, B10001, B11111, B10001, B10001, B10001, B00000};
dht.begin();
lcd.init();
lcd.backlight();
lcd.createChar(0, buzz);
lcd.createChar(1, degree);
lcd.createChar(2, tem);
lcd.createChar(3, hum);
lcd.createChar(4, fanEmoji);
lcd.createChar(5, heaterEmoji);
pinMode(fan, OUTPUT);
pinMode(heater, OUTPUT);
pinMode(buzzer, OUTPUT);
for (int i = 0; i < 3; i++) {
pinMode(rgb[i], OUTPUT);
int t = 100;
for (int r = 0; r < 3; r++) {
setColor(148, 0, 211);
delay(t);
setColor(0, 0, 255);
delay(t);
setColor(0, 191, 255);
delay(t);
setColor(0, 255, 0);
delay(t);
setColor(255, 255, 0);
delay(t);
setColor(255, 127, 0);
delay(t);
setColor(255, 0, 0);
delay(t);
printData();
if (temp < 15 ) {
analogWrite(fan, 0);
digitalWrite(heater, HIGH);
lcd.setCursor(14, 0);
lcd.write(0);
lcd.setCursor(15, 0);
lcd.write(5);
tone(buzzer, 1000);
delay(400);
noTone(buzzer);
delay(400);
else if (temp > 20 && temp < 25) {
setColor(255, 255, 255);
analogWrite(fan, 51);
lcd.write(4);
noTone(buzzer);
else if (temp > 25 && temp < 30) {
analogWrite(fan, 102);
lcd.write(4);
noTone(buzzer);
else if (temp > 30 && temp < 35) {
analogWrite(fan, 153);
lcd.write(4);
noTone(buzzer);
else if (temp > 35 && temp < 40) {
setColor(255, 90, 0);
analogWrite(fan, 204);
lcd.write(4);
noTone(buzzer);
else if (temp > 40 && temp < 50) {
analogWrite(fan, 255);
lcd.write(0);
lcd.write(4);
tone(buzzer, 1000);
void printData() {
delay(2000);
lcd.clear();
temp = dht.readTemperature();
humi = dht.readHumidity();
if (isnan(temp) || isnan(humi)) {
Serial.println(F("Failed to read from DHT sensor!"));
return;
Serial.print(F("TEMP: "));
Serial.print(temp);
Serial.print(" ");
Serial.print(F("HUMI: "));
Serial.print(humi);
Serial.println(F(" %"));
lcd.setCursor(0, 0);
lcd.print(F("Temp: "));
lcd.print(temp);
lcd.write(1);
lcd.print(F("C"));
lcd.setCursor(0, 1);
lcd.print(F("Hum : "));
lcd.print(humi);
lcd.print(F(" %"));
void setColor(int r, int g, int b) {
analogWrite(rgb[0], r);
analogWrite(rgb[1], g);
analogWrite(rgb[2], b);
