hi, I am using a sensor that gives a peak to peak voltage of 4, i.e -2 to 2 waveform in analog form but I have to take the difference from the reference voltage of 4v, but I found that the Arduino read only positive voltage, can anyone suggest the code to calculate Vrms and V peak to peak? the frequency of the waveform is 5Hz, I used a special circuit to add the DC value to the waveform to shift the Origin.
hope that helps...
i tried this code but in this i didn't find how he took waveform reading from A0 pin, so i didn't got output.
you need to study the code and cct a bit more closely my friend!
calcV(0, 2.34, 5.0, &Vrms, &Vpp);
the '0' here is synomymous of ch A0!
I thought it is a Digital pin! thanks, I will check again...
I checked but it is not showing the output, is there any changes I have to make for the 5hz frequency?
u probably will as that link shared was designed for 50hz
We can't see what you tried - maybe you made just a simple mistake.
You need to remember the minimum and maximum with variables that persist longer than loop() (i.e. static or global), and then take the difference between them.
I have merged your topics @RamaKrishna1703.
In the future, please only create one topic for each distinct subject matter.
Thanks in advance for your cooperation.
Per
Like this? (wouldn't have to guess if we could see your circuit).
I tried the code in #post2 but in thinkercad I got an error at return. and I tried the code: for RMS voltage(didn't get the correct value) but I need Vpp also
int pin = A1;
int Voltage = 0;
double V_square = 0;
double accum = 0;
unsigned long avg = 0;
double V_rms =0;
unsigned int period = 2000;
unsigned long t_start = micros();
unsigned long counts = 0;
while (micros() - t_start < period){
Voltage = (analogRead(pin));
// Serial.println(Voltage);
V_square = VoltageVoltage;
accum += V_square;
counts++;
//Serial.println(Voltage);
} //Serial.println(accum);
avg=accum /counts;
V_rms=sqrt(avg)/10235;
Serial.println( V_rms);
Hopefully looking back at that code, you can see why we ask you to please remember to use code tags when posting code
And the error was . . .?
I got this type of error in tinkercad. but in Arduino ide, it is showing no error, but in simulation software, the code is not working.
In function 'double calcV(int, double, double, double*, double*)':
139:3: error: return-statement with no value, in function returning 'double' [-fpermissive]
exit status 1
See reply #9.
You haven't posted that code
You really need to start using code tags
Created: 12/29/2021 6:47:41 PM
Author: Carlos Balseiro
Adapted from the code of openenergymonitor (https://github.com/openenergymonitor/EmonLib/blob/master/EmonLib.cpp#L114)
#define ADC_COUNTS 1023
double calcV(int ch, double offsetV, double SupplyVoltage, double* Vrms, double* Vpp)
unsigned int crossCount = 0; //Used to measure number of times threshold is crossed.
unsigned int numberOfSamples = 0; //This is now incremented
unsigned int timeout = 500; //mseconds
unsigned int crossings = 10; // sampling 10 trace crossing
double adjustedV;
double sampleV;
double startV;
double sqV;
double sumV = 0;
int sumMin = 0, sumMax = 0, max = 0, min = 1023, Chng = 0, maxCount = 0, minCount = 0, lastSample, onLow = 0, onUp = 0, oldChng = 0, stayCount = 5;
double lastVCross;
double checkVCross;
int maxValue = 0;
int minValue = 1024;
int i = 0;
// Start
crossCount = 0;
adjustedV = 0;
double start = millis();
sumV = 0; //Reset accumulator
startV = analogRead(ch);
lastSample = startV;
// Measurement loop
while (crossCount < crossings && (millis() - start) < timeout) //millis()-start makes sure it doesnt get stuck in the loop if there is an error.
numberOfSamples++; //Count number of times looped.
// Read in raw voltage samples
sampleV = analogRead(ch);
// Voltage calculation corrected by offset
adjustedV = sampleV / ADC_COUNTS * SupplyVoltage;
//Serial.print(adjustedV); Serial.print(" ");
adjustedV -= offsetV;
//Serial.println(adjustedV);
// RMS voltage
sqV = adjustedV * adjustedV;
sumV += sqV;
// Find the number of times the voltage has crossed the initial voltage
// - every 2 crosses we will have sampled 1 wavelength
// - so this method allows us to sample an integer number of half wavelengths which increases accuracy
lastVCross = checkVCross;
if (sampleV > startV) checkVCross = true;
else checkVCross = false;
if (numberOfSamples == 1)
if (lastVCross != checkVCross) {
crossCount++;
// Find max peak and min peak to measure peak to peak voltage
if (lastSample < sampleV) { //trace is going up
if (Chng < 0 && onUp < stayCount) //If minimum was detected we are going to check there is not a false minimum
oldChng = Chng;
if (oldChng < 0 && onUp> stayCount) { //if we found a minimum and after stayCount samples the trace is going up then recorded the minimum and reset
sumMin += min;
min = 1023;
minCount++;
oldChng = 0;
onUp = 0;
onLow = 0;
lastSample = sampleV;
Chng = 1;
onUp++;
if (max < sampleV)
max = sampleV; // get max value
else if (lastSample > sampleV) { //trace is going down
if (Chng > 0 && onLow < stayCount) //If maximum was detected we are going to check there is not a false maximum
oldChng = Chng;
if (oldChng > 0 && onLow > stayCount) { //if we found a maximum and after stayCount samples the trace is going down then recorded the maximum and reset
sumMax += max;
max = 0;
maxCount++;
oldChng = 0;
onLow = 0;
onUp = 0;
Chng = -1;
onLow++;
if (min > sampleV)
min = sampleV; //get min value
// Vrms and Vpp calculations
//Calculation of the root of the mean of the voltage squared (rms)
*Vrms = sqrt(sumV / numberOfSamples);
if (minCount != 0 && maxCount != 0)
*Vpp = (double)(sumMax / maxCount - sumMin / minCount) / ADC_COUNTS * SupplyVoltage;
*Vpp = 0;
if (*Vpp < 0)
*Vpp = 0;
//Serial.println("Vrms: " + String(Vrms) + " Vpp: " + String(Vpp));
//delay(100);
return;
while (!Serial) {};
// Get Voltage pin, offset, VSupply
double Vpp, Vrms;
calcV(1, 2, 5.0, &Vrms, &Vpp);
You promised the compiler that this function would return a value, but it doesn't.
yeah but this code I got from the forum only i checked the code but i didn't understand where to return value.
Using the return statement
