I have written this code to have a simple head move when someone enters the room. The concept is PIR senses movement in the room, so a simple head with 4 servos (1-Neck horizontal, 2-neck vertical, 3-eye horizontal, and 4- eyelid )
But unfortunately it is not responding. code compiles and loads, but nothing happens.
here is the code, any advice please ?
/*simple ROBOT initial sketch
created by quazimodo
#include <Servo.h>
Servo serv1; // create servo object to control a servo neck L-R
Servo serv2; // neck up-down
Servo serv3; // eyeball
Servo serv4; // eyelid
int PirPin = 2; // Arduino pin 2 tied to PIR.
boolean state = false, state1 = false, state2 = false, state3 = false, state4 = false;
unsigned int uS, randTime, angle1 = 20, angle2 = 30, angle3 = 30, angle4 = 30;
unsigned long current=0, start1=0, start2 = 0, start3 = 0, start4 = 0;
Serial.begin(9600); // Open serial monitor at 115200 baud to see ping results.
serv1.attach(5);
serv2.attach(6);
serv3.attach(9);
serv4.attach(10);
pinMode(PirPin, INPUT);
if(PirPin == HIGH )
state = true;
while(state)
current = millis();
if(current - start1 > 200)
start1 = current;
if(angle1 < 150 && state1 == false)
angle1++;
if(angle1 == 150) state1 = true;
serv1.write(angle1);
else if(angle1 > 30 && state1 == true)
angle1--;
if(angle1 == 30)
state1 = false;
state = false;
if(current - start2 > 100)
start2 = current;
if(angle2 < 90 && state2 == false)
angle2++;
if(angle2 == 90) state2 = true;
serv2.write(angle2);
else if(angle2 > 30 && state2 == true)
angle2--;
if(angle2 == 30) state2 = false;
if(current - start3 > 50)
start3 = current;
if(angle3 < 60 && state3 == false)
angle3++;
if(angle3 == 60) state3 = true;
serv3.write(angle3);
else if(angle3 > 30 && state3 == true)
angle3--;
if(angle3 == 30) state3 = false;
if(current - start4 > 1000*randTime)
start4 = current;
randTime = random(1,4);
if(state4 == false)
angle4 = 60;
state4 = true;
serv4.write(angle4);
angle4 = 30;
state4 = false;
Serial.println(angle1);
Serial.println(angle2);
Serial.println(angle3);
Serial.println(angle4);
serv4.write(30);
delay(50); // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
