Rotary encoder + 7 segment display.
Hello. I have found this topic: Rotary Encoder - Project Guidance - Arduino Forum
I have my own "arduino" with atmega328. Encoder is connected directly to A1,A2.
Code from 11 post works good.
This is my diagram:
(click on image for full size)
It is possible to change code to drive my encoder (connected to PD5 and PD7 (SWA/SWB)) and display?
I need to set values like:
0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21...64 from encoder to display.
Parralel I need to drive relays, like this (for example):
If I get "10" on display then drive I1 and I2 (PD3/PD4). Relays are drive by ULN2003.
Regards,
Mateusz
Please be clear about what you are asking. Are you asking someone to change the code so that it acts as you need for your project? Or are you asking if it is possible or impossible to do?
First I would try by self - with Your little helps/tips what I need to change
gavron04:
Okay, waiting for you to post the code here please. Nobody wants to hunt for it.
Ok. Here You can find:
// rotary encoder demo by 'jurs' for Arduino Forum
// This is the code for the main "sketch"
#include "encoder.h"
#define BAUDRATE 115200L // serial baud rate
  Serial.begin(BAUDRATE);
  Serial.println("Good night and good luck!"); // print some Test-Message at beginning
  beginEncoders();
void printEncoders()
{ // print current count of each encoder to Serial
  for (int i=0; i<NUMENCODERS; i++)
    Serial.print(encoder[i].count);
    Serial.print('\t');
  if (updateEncoders()) printEncoders();
and encoder.h
// rotary encoder include file by 'jurs' for Arduino Forum
// This is the code for a new "Tab" within the sketch with Tab name "encoder.h"
#include <Arduino.h>
struct rotary_t {byte pinA; byte pinB; int count;};
rotary_t encoder[]={
 {A4,A5},
#define NUMENCODERS (sizeof(encoder)/sizeof(encoder[0]))
volatile byte state_ISR[NUMENCODERS];
volatile int8_t count_ISR[NUMENCODERS];
void startTimer2()  // start TIMER2 interrupts
  noInterrupts();
  // Timer 2 CTC mode
  TCCR2B = (1<<WGM22) | (1<<CS22)  | (1<<CS20);
  TCCR2A = (1<<WGM21);
  OCR2A = 124;   // 249==500,  124==1000 interrupts per second
                 // 63 ==2000,  31==4000
                 // 15 ==8000,   7==16000
  TIMSK2 = (1<<OCIE2A); // enable Timer 2 interrupts
  interrupts();
void stopTimer2() // stop TIMER2 interrupts
  noInterrupts();
  TIMSK2 = 0;
  interrupts();
int8_t readEncoder(byte i)
{ // this function is called within timer interrupt to read one encoder!
  int8_t result=0;
  byte state=state_ISR[i];
  state= state<<2 | (byte)digitalRead(encoder[i].pinA)<<1 | (byte)digitalRead(encoder[i].pinB);
  state= state & 0xF;   // keep only the lower 4 bits
  /* // next two lines would be code to read 'quarter steps'
  if (state==0b0001 || state==0b0111 || state==0b1110 || state==0b1000) result= -1;
  else if (state==0b0010 || state==0b1011 || state==0b1101 || state==0b0100) result= 1;
  // next two lines is code to read 'full steps'
  if (state==0b0001) result= -1;
  else if (state==0b0010) result= 1;
  state_ISR[i]= state;
  return result;
void beginEncoders()
{ // active internal pullup resistors on each encoder pin and start timer2
    pinMode(encoder[i].pinA, INPUT_PULLUP);
    pinMode(encoder[i].pinB, INPUT_PULLUP);
    readEncoder(i); // Initialize start condition
  startTimer2();
boolean updateEncoders()
{ // read all the 'volatile' ISR variables and copy them into normal variables
  boolean changeState=false;
    if (count_ISR[i]!=0)
      changeState=true;
      noInterrupts();
      encoder[i].count+= count_ISR[i];
      count_ISR[i]=0;
      interrupts();
  return changeState;
ISR(TIMER2_COMPA_vect)  // handling of TIMER2 interrupts
    count_ISR[i]+= readEncoder(i);
I see encoder code. Where is your 7 segment sketch?
For segment I would like to use this library:
click for link
gavron04:
click for link
Have you tried?
I have this code:
/* SevSeg Counter Example
 Copyright 2017 Dean Reading
 Licensed under the Apache License, Version 2.0 (the "License");
 you may not use this file except in compliance with the License.
 You may obtain a copy of the License at
 http://www.apache.org/licenses/LICENSE-2.0
 Unless required by applicable law or agreed to in writing, software
 distributed under the License is distributed on an "AS IS" BASIS,
 WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 See the License for the specific language governing permissions and
 limitations under the License.
 This example demonstrates a very simple use of the SevSeg library with a 4
 digit display. It displays a counter that counts up, showing deci-seconds.
#include "SevSeg.h"
SevSeg sevseg; //Instantiate a seven segment controller object
  byte numDigits = 2;
  byte digitPins[] = {12,11};
  byte segmentPins[] = {10, 13, A2, A1, A0, 9, A3};
  bool resistorsOnSegments = true; // 'false' means resistors are on digit pins
  byte hardwareConfig = N_TRANSISTORS; // See README.md for options
  bool updateWithDelays = false; // Default. Recommended
  bool leadingZeros = false; // Use 'true' if you'd like to keep the leading zeros
  sevseg.begin(hardwareConfig, numDigits, digitPins, segmentPins, resistorsOnSegments, updateWithDelays, leadingZeros);
  sevseg.setBrightness(90);
  static unsigned long timer = millis();
  static int deciSeconds = 0;
  if (millis() - timer >= 100) {
    timer += 100;
    deciSeconds++; // 100 milliSeconds is equal to 1 deciSecond
    if (deciSeconds == 10000) { // Reset to 0 after counting for 1000 seconds.
      deciSeconds=0;
    sevseg.setNumber(deciSeconds, 1);
  sevseg.refreshDisplay(); // Must run repeatedly
/// END ///
but now I dont know how to:
  • set limit for encoder to read values in range 0...64
  • write readed value from encoder to display
      encoder[i].count = (encoder[i].count + count_ISR[i]) % 64;
How many relays do you want to use, and what type? Are they relay modules or bare relays?
You may run out of pins. One way to avoid that would be to use shift registers to drive the relays and the display. For the displays, use 2 x 74hc595. For the relay modules, use more 74hc595. For bare relays, use tpic6c595. All the shift registers can be daisy chained so only 3 ago pins are needed.
6 relays. All drive by ULN2003 (I1,I2,I3,I4,I5,I6,I7 (I7 additionall relay))
I know about shift registers, I have used them with last projects with 16ch led backlight for potentiometer but now I would like to use standard pins from atmega328p.
All pins from atmega I have used.
PaulRB - today I saw Your code, now works good! I have values from 0..63 > 0..63 > 0..63 > 0..63
but when I go counterclockwise I get values -63..0 > -63..0 > -63..0 > -63..0
I don't know how to change to work as:
clockwise 0 > 63 and stop at 63, You can rotate encoder clockwise after value 63, but it still 63
counterclockwise 63 > 0 and stop at 0, You can rotate encoder counterclockwise after value 0, but is still 0
Have a good weekend!
Regards
Apologies, I used the wrong function.
Instead of "% 64" try "& 63" if you want the value to loop around.
To stop at 0 and 63, try
      encoder[i].count = constrain(encoder[i].count + count_ISR[i], 0, 63);
Now with:
encoder[i].count = (encoder[i].count + count_ISR[i]) & 63;
works ok. I have 0..63 and 63..0
But this code:
I should put this for:
or add as a new line?
Replace, not a new line.
After replace I have 63,63,63... with clockwise and counterclockwise.
That's too bad. Maybe you made a mistake in the code we can't see.
Ok. I have tried second time and .. it works! :smiley:
Code:
  beginEncoders();
    Serial.print('\t');
encoder.h
 {A4,A5},
  noInterrupts();
  // Timer 2 CTC mode
  interrupts();
  noInterrupts();
  TIMSK2 = 0;
  interrupts();
  int8_t result=0;
  return result;
  for (int i=0; i<NUMENCODERS; i=63)
  startTimer2();
      changeState=true;
      noInterrupts();
      count_ISR[i]=0;
      interrupts();
  return changeState;
Now I think it will be easier (maybe not for me... :slight_smile: ). To get actual value I need to write:
encoder[i].count
Right?
( encoder*.count ==> after updateEncoders(); this int will contain the current count value )*
In void loop:
* *if (encoder[i].count = 1) { digitalWrite(Relay1, HIGH) }* *
Perhaps. We still do not understand the purpose of your project. If you have only 6 or 7 relays, what will encoder values 8 to 63 do? How will the relays be switched off?
I'm making passive volume control and I have about 60-64 steps.
In void loop for test I have write this:
And I get this: 'i' was not declared in this scope
