Hello,
I hooked up an incremental rotary encoder to Arduino Uno R3 and with the following sketch I manage to make it work repeatably without losing steps.
But the strange thing is when I open the serial monitor there is nothing printed not even a single line. And when I spin the sensor the data show up on the serial. if I zero the position of the encoder with the reset switch and I don't touch the sensor nothing changes, the last printed data just stay in pause, only if I spin again the encoder it shows the zero value and start printing the new value.
The serial monitor acts like in sleep mode. If the sensor doesn't move nothing shows if the sensor move data appear on the serial.
#define ENC_RD PIND //encoder port read
#define A_PIN 2 // pdip 4, associated with INT0 vector; PD2
#define B_PIN 3 // pdip 5, associated with INT1 vector; PD3
#define rstbtn 4 // reset button
long counter = 0;
const float R = 0.15;
float distance = 0;
pinMode(A_PIN, INPUT_PULLUP);
pinMode(B_PIN, INPUT_PULLUP);
pinMode(rstbtn, INPUT_PULLUP);
attachInterrupt(0, evaluateRotary, CHANGE);
attachInterrupt(1, evaluateRotary, CHANGE);
void evaluateRotary() {
/* encoder routine. Expects encoder with four state changes between detents */
/* and both pins open on detent */
static uint8_t old_AB = 3; //lookup table index
static int8_t encval = 0; //encoder value
static const int8_t enc_states[] PROGMEM = { 0, -1, 1, 0, 1, 0, 0, -1, -1, 0, 0, 1, 0, 1, -1, 0 }; //encoder lookup table
old_AB <<= 2; //remember previous state
old_AB |= ((ENC_RD >> 2) & 0x03);
encval += pgm_read_byte(&(enc_states[(old_AB & 0x0f)]));
if (encval > 3) { //four steps forward
counter++;
encval = 0;
} else if (encval < -3) { //four steps backwards
counter--;
encval = 0;
void resetCounter() {
noInterrupts();
counter = 0;
interrupts();
static long lastCounter = 0;
distance = R * counter;
if (counter != lastCounter) {
// Serial.print("Counter value: ");
// Serial.println(counter, DEC);
lastCounter = counter;
//Serial.print("Track: ");
Serial.print(distance);
if (digitalRead(rstbtn) == LOW) {
resetCounter();
Thanks, guys, the suggested changes work but now the reset button doesn't work. I am missing something small again. Would you be able to have a peek?
This is the edited code:
volatile long counter = 0;
float distance = 0;
counter++;
encval = 0;
counter--;
encval = 0;
noInterrupts();
long myCounterCopy = counter;
interrupts();
distance = R * lastCounter;
resetCounter();
This, what I think @cattledog was pointing out, isn't just wrong, it's really wrong.
noInterrupts();
interrupts();
Because myCounterCopy is a local variable, it gets set and then forgotten when the function exits. So the whole function amounts to nothing, well it turns interrupts off, then back on again.
is fine. It protects the access to counter. And will set it to zero. The global variable named counter.
Your loop() does not protect access to counter. See
// this use of 'counter' must be protected from interruption:
noInterrupts();
interrupts();
resetCounter();
Not clear what you are trying to do, just focusing on the interrupt/noInterruot issue.
Thanks alto777, got it now with your explanation. Thanks a lot. Now all is working as it should.
Here is the full working code if someone what to play with it.
float distance = 0;
noInterrupts();
counter = 0;
interrupts();
noInterrupts();
interrupts();
resetCounter();
counter++;
encval = 0;
counter--;
encval = 0;
