Hi Gents
ive got a uno model and i want to move a encoder around to measure distance.
the code below works well but i need to move the encoder around few times to dim light.(example 10 times.But the anolog out is the same as the anolog in .I need multi anolog in rotation to give out 0 to 5 volts out.
//Controlling led by potentiometer
//Rotate the shaft of the potentiometer and you should see the luminance of the LED change. //Email:info@primerobotics.in
//Website:www.primerobotics.in //2015.5.7
const int analogPin = 0;//the analog input pin attach to
const int ledPin = 9;//the led attach to
int inputValue = 0;//variable to store the value coming from sensor
int outputValue = 0;//variable to store the output value
Serial.begin(9600);//set the serial communication baudrate as 9600
inputValue = analogRead(analogPin);//read the value from the potentiometer
Serial.print("Input: "); //print "Input"
Serial.println(inputValue); //print inputValue
outputValue = map(inputValue, 0, 1023, 0, 255); //Convert from 0-1023 proportional to the number of a number of from 0 to 255
Serial.print("Output: "); //print "Output"
Serial.println(outputValue); //print outputValue
analogWrite(ledPin, outputValue); //turn the LED on depending on the output value
It is unclear, to me, what you want and what you have. You mention a potentiometer and an encoder. Those are not the same things. And you mention that you want to measure distance, but in the code, there is only dimming a light. How do you propose to measure distance with a potentiometer?
A complete schematic of what you have with all connections, power supplies and part numbers (and/or links to data sheets) would help a lot.
Plus a detailed description of the project.
Read the how to use this forum-please read sticky to see how to properly post code and some advice on how to ask a question so that we have the information to be able to help you.
ok what iam trying to do is the analog input must rotate 0 to 5 vdc 10 times because it over laps the voltage.the analog output must read 0 to 5 vdc only.
Looks like a 5k precision pot (with no endstops). If you are giving it multi-turns, then you can count the turns (and direction) by counting when the voltage goes from 0 to 5V (or thereabouts) when it has been more slowly changing from 5V to 0V, and vice versa, but with a bit of effort, a user could fiddle that simple solution. For reliability and longer service life, I reckon a rotary encoder would be better.
