Hello, I'm trying to measure RPM for a Rotax aircraft engine. The signal you get from the engine is described in the attached picture below. Can anyone help me with that? Do i have to limit the voltage? i beleive i have to connect it to a digital port and mesure the pulses somehow, 1 pulse is one rotation of the engine.
Thank you for the reply MarkT, I just got the LM339 , the resistor, etc... and i'm trying to find out the connection diagram.
I have very basic knowledge on electronics and i'm prety lost trying to understand how to connect them.
I got the mainidea which i believe is to convert the analog signal to a square digital signal for the arduino digital port to be able to recognise it. I beleive we have to use one of the 4 inputs of LM339 and get an output for the arduino port. I its not to much trouble can you please upload a conection diagram?
I am quite new to electronics and arduino and i am facing exactly this problem. Please did you eventually get this to work and what circuit diagram did you use.
