Rp2040: can't get SD card reader to initialize
I'm trying to get my SD card module initialized, but no matter what I try, I just can't get it to work.
I've written a simple code:
#include <SPI.h>
#include <SD.h>
// Definition der Pins
const int chipSelect = 1; // GP1 (CSn)
  while (!Serial) {
  SPI.setRX(0); // GP0 als MISO
  SPI.setTX(3); // GP3 als MOSI
  SPI.setSCK(2); // GP2 als SCK
  SPI.begin();
  Serial.print("InitializeSD-Card...");
  if (!SD.begin(chipSelect)) {
    Serial.println("SD-card couldn't be initialized.");
    return;
  Serial.println("succesfull");
I am using a Pimoroni tiny rp2040, here is a photo of the pinout
I can't figure out what I'm doing wrong.
I appreciate any help I can get on this.
Thanks in advance!
Luca
if I run your code on a Raspberry Pi Pico RP2040 it works OK - serial monitor displays
InitializeSD-Card...succesfull
EDIT: if I run File>Examples>SD>CardInfo with the SPI pin definitions
const int _MISO = 0;  // AKA SPI RX
const int _MOSI = 3;  // AKA SPI TX
const int _CS = 1;
const int _SCK = 2;
Initializing SD card...
Wiring is correct and a card is present.
Card type:         Unknown
Cluster size:          16384
Blocks x Cluster:  32
Blocks size:  512
Total Blocks:      247616
Total Cluster:      7738
Volume type is:    FAT16
Volume size (Kb):  126779
Volume size (Mb):  123
Volume size (Gb):  0.12
Card size:  126779.39
Total bytes: 126779392
Used bytes: 147456
System Volume Information/
	IndexerVolumeGuid		76	CREATION: 2023-08-13 16:43:42	LAST WRITE: 2023-08-13 16:43:44
data.txt		486	CREATION: 2021-01-01 00:00:04	LAST WRITE: 2021-01-01 00:00:20
test.txt		77824	CREATION: 1980-01-01 00:00:00	LAST WRITE: 1980-01-01 00:00:00
foo.txt		13	CREATION: 1980-01-01 00:00:00	LAST WRITE: 1980-01-01 00:00:00
Oh thanks for testing it out! I now soldered the contacts directly on to an SD-Micro SD Adapter and this worked! So it must have something to do with my micro SD module.
