I have create a new project for read four serial ports. I using Serial Port Arduino Mega(Serial 1,2) and MAX232 transceivers (for the conversion RS232 to TTL 5V) like this:http://arduino.cc/en/Tutorial/ArduinoSoftwareRS232
My PC Serial exit with 3 wires (RX,TX and GND)
] have a problem: If I use Arduino serial embedded, the data reading it works only with GND not connect... and if I use the serial connected to MAX232 it works only with GND CONNECTED!!!...
Oof! That page referenced looks like a plate of spaghetti. As G_M says, all the grounds in
such a setup should be common. With spaghetti like that, 99% probably you have something
plugged into the wrong slot on the whiteboard.
The arduino chip (328P) outouts 5V and 0V from the serial output an board. The Max 232 ouptus a more proper +5V and -5V. when you hook the wires up directly WITHOUT GROUND the float on the wires work to have the signals slide around and fall in a voltage range that your PC serial port is able to function with. For Now. re-arrange your desk or add some other circuit somewhere and things may not float the same and it will quit working.
And I reading all data!! .. If connected black wire (GND) on arduino GND the serial data stopped work
This is wrong, it is nt happening like you think,you have another mistake that is making you think it is working OK just because you are reading data. You got lucky with your fault. You need to find the real fault so that connecting the ground does not stop it working.
