RS485 Modbus Temperature and Humidity sensor
Hey ppl,
I am struggling with two RS485 temperature and humidity sensors and connecting them with my arduino.
  1. Is it possible to use this: DSD TECH SH-U12 RS485 to TTL 5V Brett with MAX13487 Chip?
  2. Can you suggest something else (the senros have 4 wires)?
  3. These are the sensros - RS485 Modbus Water Proof Temperature Humidity Sensor Probe
Given you use a 5V Arduino: yes.
Your forgot the link behind that. Also provide a link to the manual you got. If you didn't get a manual throw it away and buy from a vendor where you get a manual. Accessing a Modbus device without a manual is almost impossible.
This is the only info i got on the sensors.
My main issue is that the rs485 module has only 3 connections for out (GND, B-, A+) while the sensor has 4 wires (Power+, power-, A+, A-)
Thanks for the help =)
This should be sufficient.
Power+ and power- is the power supply of the sensor while A+ connects to A+ and A- connects to B- on the converter.
You still didn't tell us what exact type of Arduino you're using.
