Hey!
I need to use a RTC in my project, so Ibought a ds3231 i2c-breakout. It's working and I was able to set the time, but the serial printed time is always incorrect. Specifically the seconds are jumping like 10:22:00 - 10:22:01 - 10:22:00 - 10:22:02 - 10:22:10 -10:22:11 -10:22:10 -10:22:20 (more or less) ...
I used the example code
DS3231_test.pde
Eric Ayars
4/11
Test/demo of read routines for a DS3231 RTC.
Turn on the serial monitor after loading this to check if things are
working as they should.
#include <DS3231.h>
#include <Wire.h>
DS3231 Clock;
bool Century=false;
bool h12;
bool PM;
byte ADay, AHour, AMinute, ASecond, ABits;
bool ADy, A12h, Apm;
// Start the I2C interface
Wire.begin();
// Start the serial interface
// send what's going on to the serial monitor.
// Start with the year
Serial.print("2");
if (Century) { // Won't need this for 89 years.
Serial.print("1");
Serial.print("0");
Serial.print(Clock.getYear(), DEC);
Serial.print(' ');
// then the month
Serial.print(Clock.getMonth(Century), DEC);
Serial.print(' ');
// then the date
Serial.print(Clock.getDate(), DEC);
Serial.print(' ');
// and the day of the week
Serial.print(Clock.getDoW(), DEC);
Serial.print(' ');
// Finally the hour, minute, and second
Serial.print(Clock.getHour(h12, PM), DEC);
Serial.print(' ');
Serial.print(Clock.getMinute(), DEC);
Serial.print(' ');
Serial.print(Clock.getSecond(), DEC);
// Add AM/PM indicator
if (h12) {
if (PM) {
Serial.print(" PM ");
Serial.print(" AM ");
Serial.print(" 24h ");
// Display the temperature
Serial.print("T=");
Serial.print(Clock.getTemperature(), 2);
// Tell whether the time is (likely to be) valid
if (Clock.oscillatorCheck()) {
Serial.print(" O+");
Serial.print(" O-");
// Indicate whether an alarm went off
if (Clock.checkIfAlarm(1)) {
Serial.print(" A1!");
if (Clock.checkIfAlarm(2)) {
Serial.print(" A2!");
// New line on display
Serial.print('\n');
// Display Alarm 1 information
Serial.print("Alarm 1: ");
Clock.getA1Time(ADay, AHour, AMinute, ASecond, ABits, ADy, A12h, Apm);
Serial.print(ADay, DEC);
if (ADy) {
Serial.print(" DoW");
Serial.print(" Date");
Serial.print(' ');
Serial.print(AHour, DEC);
Serial.print(' ');
Serial.print(AMinute, DEC);
Serial.print(' ');
Serial.print(ASecond, DEC);
Serial.print(' ');
if (A12h) {
if (Apm) {
Serial.print('pm ');
Serial.print('am ');
if (Clock.checkAlarmEnabled(1)) {
Serial.print("enabled");
Serial.print('\n');
// Display Alarm 2 information
Serial.print("Alarm 2: ");
Clock.getA2Time(ADay, AHour, AMinute, ABits, ADy, A12h, Apm);
if (ADy) {
Serial.print(' ');
Serial.print(' ');
Serial.print(' ');
if (A12h) {
if (Apm) {
Serial.print('pm');
Serial.print('am');
if (Clock.checkAlarmEnabled(2)) {
// display alarm bits
Serial.print('\nAlarm bits: ');
Serial.print(ABits, BIN);
Serial.print('\n');
Serial.print('\n');
and tried also some other codes, always with the same result.
