RTC program help with LED
Here is my code for my RTC, which is a DS3231
i want my LED to flash every 30 seconds by the time of day. HELP
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
#include <Wire.h>
#include "RTClib.h"
RTC_PCF8523 rtc;
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
void setup () {
while (!Serial) {
delay(1);
Serial.begin(57600);
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
while (1);
if (! rtc.initialized()) {
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
// rtc.adjust(DateTime(F(DATE), F(TIME)));
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call:
// rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
void loop () {
DateTime now = rtc.now();
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(" (");
Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);
Serial.print(") ");
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
Serial.print(" since midnight 1/1/1970 = ");
Serial.print(now.unixtime());
Serial.print("s = ");
Serial.print(now.unixtime() / 86400L);
Serial.println("d");
// calculate a date which is 7 days, 12 hours and 30 seconds into the future
DateTime future (now + TimeSpan(7,12,30,6));
Serial.print(" now + 7d + 30s: ");
Serial.print(future.year(), DEC);
Serial.print('/');
Serial.print(future.month(), DEC);
Serial.print('/');
Serial.print(future.day(), DEC);
Serial.print(' ');
Serial.print(future.hour(), DEC);
Serial.print(':');
Serial.print(future.minute(), DEC);
Serial.print(':');
Serial.print(future.second(), DEC);
delay(3000);
This code works on my RTC. the time of day comes up on the serial monitor. now i need to add a LED
“i want my LED to flash every 30 seconds by the time of day. ”
What does flash mean?
Did you mean toggle state?
When seconds change, then when seconds is 0 or 30 you can do your stuff.
delay(3000); This is not a good thing to do as it freezes normal program execution for that amount of time.
i just mean i want it to turn on and off every 30 seconds at first by the time of day
Yes but how long is the LED to be ON.
time = 0 LED goes ON
time = 0 + 30sec LED goes OFF
time = 0 + 60sec LED goes ON
etc.
OR
time = 0 + 1sec LED goes OFF
time = 0 + 30sec LED goes ON
time = 0 + 31sec LED goes OFF
etc.
LED only needs to be on for 5 seconds total. then off for 30 then on for 5
Does that make sense i need help adding the LED in my program for my RTC DS3231. i just need the LED to come on every 30 seconds for 5 seconds.
Take what you need from this example:
#include <DS3232RTC.h>    //http://github.com/JChristensen/DS3232RTC
#include <Time.h>         //http://www.arduino.cc/playground/Code/Time
#include <Wire.h>         //http://arduino.cc/en/Reference/Wire (included with Arduino IDE)
byte lastSecond;
byte currentSecond;
const byte LEDpin = 13;
void setup(void)
  pinMode(LEDpin, OUTPUT);
  setSyncProvider(RTC.get);
  if (timeStatus() != timeSet)
    Serial.println("Unable to sync with the RTC");
    Serial.println("RTC has set the system time");
} //END of setup()
void loop(void)
  currentSecond = second();
  if (lastSecond != currentSecond)
    lastSecond = currentSecond;
    processLED();
    Serial.println(second());
} //END of loop()
void processLED()
  switch (currentSecond)
    case 0:
      digitalWrite(LEDpin, HIGH); //turn on LED
    case 5:
      digitalWrite(LEDpin, LOW); //turn off LED
    case 30:
    case 35:
} //END of processLED()
im not sure at all what you mean by take what i need? can you be more specific? i just want to add on my program, im really a weak programmer. i have my LED hooked to pin 13, i just dont know what code i need to make it work.
I am only using 2 libraries in conjunction with my RTC which are, #include <Wire.h>
#include "RTClib.h" i dont want to add or change these. i just want to add the LED which i dont know how to do.
Add these lines to your original sketch:
void loop ()
  //your old loop() code goes here
  //delay(3000) //remove this line in your old code
  //  Add the following lines of code to your original sketch
  currentSecond = now.second();
    processLED();
} //END of loop()
void processLED()
    case 0:
    case 5:
    case 30:
    case 35:
my first error is now 'current second' does not name a type
You have to define your variables.
Add these 3 lines in-front of the setup() function.
This will make them global variables.
byte lastSecond;
byte currentSecond;
Next you will have to add this line inside the setup() function.
i did add the variables and it still says the same thing about the currentSecond part
Show us what you have done.
#include <Wire.h>
#include "RTClib.h"
byte lastSecond;
byte currentSecond;
const byte LEDpin = 7;
RTC_DS3231 rtc;
void setup ()
delay(3000); // wait for console opening
while (1);
if (rtc.lostPower()) {
Serial.println("RTC lost power, lets set the time!");
// Comment out below lines once you set the date & time.
// Following line sets the RTC to the date & time this sketch was compiled
// Following line sets the RTC with an explicit date & time
// for example to set January 27 2017 at 12:56 you would call:
// rtc.adjust(DateTime(2017, 1, 27, 12, 56, 0));
void loop ()
Serial.print('/');
Serial.print('/');
Serial.print(" (");
Serial.print(") ");
Serial.print(':');
Serial.print(':');
Serial.print('/');
Serial.print('/');
Serial.print(' ');
Serial.print(':');
Serial.print(':');
processLED();
} //END of loop()
void processLED()
case 0:
case 5:
case 30:
case 35:
I redid the program and it will now run. But, without the delay i cant even read whats on the serial monitor screen. and i am hooking up a LED with a breadboard. when i use this program my board has no delay the TX light stays lit up. I need to see the time delay and i also need to be able to read the serial monitor screen
i see now what im thinking wrong but i still need the delay for the serial monitor screen but when i add it i have an error. anyway to fix this?
Your RTC library is different from the one I have but this should work:
Note: a HIGH on the LED anode turns it on.
#include <Wire.h>
#include "RTClib.h"
//RTC_DS1307 rtc;
RTC_DS3231 rtc;
byte lastSecond;
byte currentSecond;
void setup ()
  //Wire.begin();
  //rtc.begin();
  if (! rtc.begin())
    while (1);
    rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
void loop ()
    processLED();
    Serial.println(now.second());
} //END of loop()
void processLED()
    case 0:
    case 5:
    case 30:
    case 35:
also can you tell me what these lines all represent? so i can change them as i want and i know what im changing.
void processLED()
case 0:
case 5:
case 30:
case 35:
#include <Wire.h>
#include "RTClib.h"
byte lastSecond;
byte currentSecond;
RTC_DS3231 rtc;
void setup ()
while (1);
void loop ()
Serial.println("Current Date & Time: ");
Serial.print('/');
Serial.print('/');
Serial.print(" (");
Serial.print(") ");
Serial.print(':');
Serial.print(':');
Serial.println("Unix Time: ");
Serial.print("elapsed ");
Serial.print(" seconds/");
Serial.println(" days since 1/1/1970");
// calculate a date which is 7 days & 30 seconds into the future
DateTime future (now + TimeSpan(7,0,0,30));
Serial.println("Future Date & Time (Now + 7days & 30s): ");
Serial.print('/');
Serial.print('/');
Serial.print(' ');
Serial.print(':');
Serial.print(':');
processLED();
} //END of loop()
void processLED()
case 0:
case 5:
case 30:
case 35:
Using this code it still is so fast on the serial monitor that i cant read the time stamps.
Try
EDIT: Updated sketch
#include <Wire.h>
#include "RTClib.h"
byte lastSecond;
byte currentSecond;
unsigned long lastMillis;
DateTime now;
RTC_DS3231 rtc;
void setup ()
  if (! rtc.begin())
    while (1);
void loop ()
  now = rtc.now();
  //has a second gone by?
    processLED(currentSecond);
    //Serial.println(now.second());
  //is it time to print to the serial monitor?
  if (millis() - lastMillis >= 3000)  //every 3 seconds
    lastMillis = millis();
    printStuff();
} //END of loop()
//This is run every 3 seconds
void printStuff()
  Serial.print('/');
  Serial.print('/');
  Serial.print(" (");
  Serial.print(") ");
  Serial.print(':');
  Serial.print(':');
  DateTime future (now + TimeSpan(7, 0, 0, 30));
  Serial.print('/');
  Serial.print('/');
  Serial.print(' ');
  Serial.print(':');
  Serial.print(':');
} //END of printStuff()
void processLED(byte Second)
  switch (Second)
    case 0:
    case 5:
    case 30:
    case 35:
