Hello all,
I have a few questions on a project I am attempting to complete. I have looked up quite a few tutorials and think I am aware of what I need for the project just I should do my due diligence and double check with you guys since you definitely know more than I.
The sketch I have come up with is attached for you to see. So I am looking to run a 12V max current 2.2A water pump. Is it feasible to say I could run this pump at 10 or 20 second intervals every 10 minutes for 24 hours? I only need to turn the pump on and off so was probably going to use the digital pin but could use the PWM pin number 9 in case I want to ease the pump down.
I am pretty sure I need a flyback diode to counteract the reverse current from the pump shutting off I just don't know which one would be appropriate and successful. I also don't really understand how to set it up making sure the polarity is correct.
The MOSFET I am using is a RFP30N06LE 30A 60V 0.047Ohm Logic Level N-Channel Power Mosfet TO-220 ESD which I think will work as I looked at the spec sheet.
Any insight or suggestions you may have is greatly appreciated. Also any questions you may have feel free to write back. Thanks!
