rc6 and previous rc's. I have noticed that Save As does not function like version 1.8 does. I ran the following test:
Preferences set Autosave Off
File:New
Make a comment line like //Rev Orig
Save As Test sketch Rev Orig (enter the name overwriting the suggested name). Location says 'Arduino'.
File is saved
Comment line is lost.
Type in another comment line: //Rev 1
Save as Test sketch Rev 1
Sketch on screen still shows original with no comment line
File: Open recent
Select Test sketch Original
Sketch shows no comment line
File Open recent
Select Test sketch rev 1
Sketch opens and shows no comment line.
If I set Autosave to Yes, the above process works but I don't get to keep an unchanged sketch to revert back to.
Question: Is this a bug waiting to be fixed, or am I supposed to set Autosave to on and do a save as prior to making any changes?
Hi @BenWeinberg. Thanks for giving the Arduino IDE 2.0.0 release candidate a try!
Yes:
No. It has already been fixed:
That fix was made after the Arduino IDE 2.0.0-rc6 release you are using so you should use the nightly build of the Arduino IDE instead. The download links are listed here:
