Schematic/Code help
Hi guy and girls,
New to using Arduino, I've had this board in my cupboard for a few years so thought i finally use it.
I'm planing to make a temp control unit using 2 relays and a temp sensor but unsure if my schematic is correct, could someone have a look and see if i have made a mistake please.
I'm stilll waiting for parts to arrive so i cannot test it.
Heres the code i wrote aswell
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(9, 8, 7, 6, 5, 4);
const int LED_RED=10; //Red LED
const int LED_GREEN=11; //Green LED
int RELAY1 = A1; // Heater
int RELAY2 = A2; // Fan
float Range = 3 // Unused
//Key connections with arduino
const int up_key=3;
const int down_key=2;
int SetPoint=30;
//                  SETUP
void setup(){
  pinMode(LED_RED,OUTPUT);
  pinMode(LED_GREEN,OUTPUT);
  pinMode(RELAY1,OUTPUT);
  pinMode(RELAY2, OUTPUT);
  pinMode(up_key,INPUT_PULLUP);
  pinMode(down_key,INPUT_PULLUP);
   // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("Temp Controller v1");
  lcd.setCursor(0,1); //Move coursor to second Line
  lcd.print("Temp. Controller");
  digitalWrite(LED_GREEN,HIGH);  //Green LED Off
  digitalWrite(LED_RED,LOW);     //Red LED On
  digitalWrite(RELAY1,LOW);      //Turn off Heater Relay
  digitalWrite(RELAY2,LOW);		//Turn off Fan Relay
  delay(2000);
//                  LOOP
void loop(){
  double Temperature = ((5.0/1024.0) * analogRead(A0)) * 100;  //10mV per degree 0.01V/C. Scalling
  lcd.setCursor(0,0);
  lcd.print("Temperature:");    //Do not display entered keys
  lcd.print(Temperature);
//Get user input for setpoints
  if(digitalRead(down_key)==LOW)
    if(SetPoint>0)
      SetPoint--;
  if(digitalRead(up_key)==LOW)
    if(SetPoint<150)
      SetPoint++;
//Display Set point on LCD
  lcd.setCursor(0,1);
  lcd.print("Set Point:");
  lcd.print(SetPoint);
  lcd.print("C   ");
//Check Temperature is in limit
if(Temperature == SetPoint)
   digitalWrite(RELAY1,LOW);    //Turn off heater
   digitalWrite(LED_RED,LOW);	  //Turn off Red LED
   digitalWrite(LED_GREEN,HIGH);  //Turn on Green LED
// If temp is over limit turn on fan
if(Temperature > SetPoint)
   digitalWrite(RELAY2,HIGH);    //Turn on fan
//if temp is below limt turn on heater / turn off fan
if(Temperature < SetPoint )
  digitalWrite(RELAY1,HIGH);    //Turn on heater
  digitalWrite(RELAY2,LOW);    //Turn off fan
  digitalWrite(LED_GREEN,LOW); //Turn off Green LED
  digitalWrite(LED_RED,HIGH);  //Turn on RED LED
  delay(100); //Update at every 100mSeconds
= is not the same as ==
ah thank you always miss something lol
Welcome!
Thanks for posting your code in code tags, very nice for a new resident.
One thing, before grabbing the code to post, ctrl-T is your friend in the IDE. It formats your code, and the indentation it provides gives lots of hints when you're looking for bugs...
The way that your switches are wired, you should use
pinMode(pin, INPUT_PULLUP); // enable the internal pullup resistor
Unless the wires are long and you have trouble with noise. If that is the case you may need a lower value (start with 10K) external resistor for a stronger pullup.
A 0.1uF cap across each switch can also help with noise and provide hardware debounce.
Although it's archaic, I think this is what it's doing, but you're right, INPUT_PULLUP is the way to go.
Thanks.
Drat, I actually looked for that but somehow still managed to miss it.
Not sure, the order might matter, might have to write the ones before declaring input, not sure. I never paid much attention, INPUT_PULLUP was available when I jumped into this pool.
One would write HIGH to the pin after setting the pinMode.
But since the pins are inputs (with the internal pullups disabled) by default you don't actually have to set the input to INPUT, just do the digitalWrite(pin, HIGH);
The pinMode(pin, INPUT_PULLUP); is preferred for readability nowadays, though.
Thanks guys, i was looking up other peoples designs for reference so probably was looking at very old info,
do i just change this
pinMode(up_key,INPUT);
pinMode(down_key,INPUT);
to this
or do i have to change other bits?
You won't need those lines any more.
You may find that the setpoint changes more rapidly than you want when you hold the buttons to change the setpoint down. You can use the state change detection method to only increment or decrement once per button press.
Ok, i've changed the code in my original post, is that better?
Thank you i'll see what i can make of the state change detection.
Would this be the way to implement state change detection?
// this constant won't change:
const byte  down_key = 2;    // the pin that the pushbutton is attached to
const byte  up_key = 3;
//Led connections with arduino
// Variables will change:
int Range = 3; // Temp +/- Range
int SetPoint=30; // Default temp
int buttonPushCounter_down_key = 0;   // counter for the number of button presses
boolean ButtonState_down_key = 0;         // current state of the button
boolean lastButtonState_down_key = 0;     // previous state of the button
int buttonPushCounter_up_key = 0;   // counter for the number of button presses
boolean ButtonState_up_key = 0;         // current state of the button
boolean lastButtonState_up_key = 0;     // previous state of the button
//                  SETUP
void setup(){
 // initialize the button pin as a input:
  pinMode(down_key, INPUT_PULLUP);
  pinMode(up_key, INPUT_PULLUP);
  lcd.begin(16, 2);
  //lcd.setCursor(0,1); //Move coursor to second Line
  //lcd.print("Temp. Controller");
  delay(2000);
//                  LOOP
void loop(){
  lcd.setCursor(0,0);
  static unsigned long timer = 0;
  unsigned long interval = 20;
  if (millis() - timer >= interval)
    timer = millis();
    // read the pushbuttons input pin:
    ButtonState_down_key = digitalRead(down_key);
	ButtonState_up_key = digitalRead(up_key);
    // compare the ButtonState_down_key to its previous state
    if (ButtonState_down_key != lastButtonState_down_key)
     // if the state has changed, increment the counter
        if (ButtonState_down_key == LOW)
        // if the current state is LOW then the button went from off to on:
        buttonPushCounter_down_key++;
		if(SetPoint>0)
				SetPoint--;
        lastButtonState_down_key = ButtonState_down_key;
	// compare the ButtonState_up_key to its previous state
    if (ButtonState_up_key != lastButtonState_up_key)
        if (ButtonState_up_key == LOW)
        buttonPushCounter_up_key++;
			if(SetPoint<150)
				SetPoint++;
    lastButtonState_up_key = ButtonState_up_key;
  lcd.setCursor(0,1);
  lcd.print("C   ");
	// If temp is over limit turn on fan /Turn off heater
	if(Temperature > (SetPoint+Range))
	if(Temperature < (SetPoint-Range))
Looks good. Does it work the way that you want?
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) to format your code for readability. All of the loop code is inside the millis() timer, including the 100 ms delay. Is that the structure that you want?
Thats a nice feature :slight_smile: Pretty sure i've sorted it now using wokwi.com
const int LED_RED = 10; //Red LED
const int LED_GREEN = 11; //Green LED
const float BETA = 3950; // should match the Beta Coefficient of the thermistor
float Range = 3.00; // Temp +/- Range
int SetPoint = 30; // Default temp
//                  SETUP
  pinMode(LED_RED, OUTPUT);
  pinMode(LED_GREEN, OUTPUT);
  pinMode(RELAY1, OUTPUT);
  lcd.begin(16, 2);
  lcd.print("Temp Controller");
  lcd.setCursor(0, 1); //Move coursor to second Line
  lcd.print("Version 1");
  digitalWrite(LED_GREEN, HIGH); //Green LED Off
  digitalWrite(LED_RED, LOW);    //Red LED On
  digitalWrite(RELAY1, LOW);     //Turn off Heater Relay
  digitalWrite(RELAY2, LOW);   //Turn off Fan Relay
  delay(2000);
//                  LOOP
  int analogValue = analogRead(A0);
  float Temperature = 1 / (log(1 / (1023. / analogValue - 1)) / BETA + 1.0 / 298.15) - 273.15;
  lcd.setCursor(0, 0);
    timer = millis();
        if (SetPoint > 0)
          SetPoint--;
        if (SetPoint < 100)
          SetPoint++;
  lcd.print("C   ");
  if (Temperature == SetPoint)
    digitalWrite(RELAY1, LOW);   //Turn off heater
    digitalWrite(LED_RED, LOW);   //Turn off Red LED
    digitalWrite(LED_GREEN, HIGH); //Turn on Green LED
  if (Temperature > (SetPoint + Range))
    digitalWrite(RELAY2, HIGH);   //Turn on fan
  if (Temperature < (SetPoint - Range) || Temperature < SetPoint)
    digitalWrite(RELAY1, HIGH);   //Turn on heater
    digitalWrite(RELAY2, LOW);   //Turn off fan
    digitalWrite(LED_GREEN, LOW); //Turn off Green LED
    digitalWrite(LED_RED, HIGH); //Turn on RED LED
Your diagram was designed by using a common anode.
Example:
NOTE: Deadband and Timer-ON for Alarm may consider applying.
