Scrolling all text before starting over MD_MAX7219
I can't seem to figure out how to scroll a complete message all the way across my led matrix before starting a new message. For example I have 16 8x8 LED for a total of 128 columns. I'm displaying my IP address as 192:168:001:125 and I'd like that to run completely off the left hand side before it starts over on the right hand side of the display. How do I accomplish this? Thanks in advance. This is my code and currently "2:168:001:128" is displayed on the left hand side when the "1" appears on the right hand side. Thanks in advance.
#include <ESP8266WiFi.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
#define	PRINT_CALLBACK	0
#define DEBUG 0
#define LED_HEARTBEAT 0
#if DEBUG
#define	PRINT(s, v)	{ Serial.print(F(s)); Serial.print(v); }
#define PRINTS(s)   { Serial.print(F(s)); }
#else
#define	PRINT(s, v)
#define PRINTS(s)
#endif
#if LED_HEARTBEAT
#define HB_LED  D2
#define HB_LED_TIME 500 // in milliseconds
#endif
// Define the number of devices we have in the chain and the hardware interface
/ NOTE: These pin numbers will probably not work with your hardware and may
// need to be adapted
#define	MAX_DEVICES	4
#define	CLK_PIN		D5 // or SCK
#define	DATA_PIN	D7 // or MOSI
#define	CS_PIN		D8 // or SS
// SPI hardware interface
//MD_MAX72XX mx = MD_MAX72XX(CS_PIN, MAX_DEVICES);
#define HARDWARE_TYPE MD_MAX72XX::FC16_HW  //edit this as per your LED matrix hardware type
MD_MAX72XX mx = MD_MAX72XX(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
// Arbitrary pins
//MD_MAX72XX mx = MD_MAX72XX(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
// WiFi login parameters - network name and password
const char* ssid = "wifi SSID";                   // edit your wifi SSID here
const char* password = "wifi password";            // edit your wifi password here
// WiFi Server object and parameters
WiFiServer server(80);
// Global message buffers shared by Wifi and Scrolling functions
const uint8_t MESG_SIZE = 255;
const uint8_t CHAR_SPACING = 1;
const uint8_t SCROLL_DELAY = 75;
char curMessage[MESG_SIZE];
char newMessage[MESG_SIZE];
bool newMessageAvailable = false;
char WebResponse[] = "HTTP/1.1 200 OK\nContent-Type: text/html\n\n";
char WebPage[] =
"<!DOCTYPE html>" \
"<html>" \
"<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">" \
"<title>MYTECTUTOR ESP8266 AND MAX7219</title>" \
"<style>" \
"html, body" \
"font-family: Helvetica; "\
"display: block;"\
"margin: 0px auto;"\
"text-align: center;"\
"background-color: #cad9c5;" \
"#container " \
"width: 100%;" \
"height: 100%;" \
"margin-left: 5px;" \
"margin-top: 20px;" \
"border: solid 2px;" \
"padding: 10px;" \
"background-color: #2dfa53;" \
"</style>"\
"<script>" \
"strLine = \"\";" \
"function SendText()" \
"  nocache = \"/&nocache=\" + Math.random() * 1000000;" \
"  var request = new XMLHttpRequest();" \
"  strLine = \"&MSG=\" + document.getElementById(\"txt_form\").Message.value;" \
"  request.open(\"GET\", strLine + nocache, false);" \
"  request.send(null);" \
"</script>" \
"</head>" \
"<body>" \
"<H1><b>ESP8266 and MAX7219 LED Matrix WiFi Control</b></H1>" \
"<div id=\"container\">"\
"<form id=\"txt_form\" name=\"frmText\">" \
"<label>Message:<input type=\"text\" name=\"Message\" maxlength=\"255\"></label>%ltbr><br>" \
"</form>" \
"<br>" \
"<input type=\"submit\" value=\"Send Text\" onclick=\"SendText()\">" \
"<p><b>Visit link for more: </b>" \
"<a href=\"https://www.mytectutor.com\">www.mytectutor.com</a></p>" \
"</div>" \
"</body>" \
"</html>";
char *err2Str(wl_status_t code)
  switch (code)
  case WL_IDLE_STATUS:    return("IDLE");           break; // WiFi is in process of changing between statuses
  case WL_NO_SSID_AVAIL:  return("NO_SSID_AVAIL");  break; // case configured SSID cannot be reached
 case WL_CONNECTED:      return("CONNECTED");      break; // successful connection is established
  case WL_CONNECT_FAILED: return("CONNECT_FAILED"); break; // password is incorrect
  case WL_DISCONNECTED:   return("CONNECT_FAILED"); break; // module is not configured in station mode
  default: return("??");
uint8_t htoi(char c)
  c = toupper(c);
  if ((c >= '0') && (c <= '9')) return(c - '0');
  if ((c >= 'A') && (c <= 'F')) return(c - 'A' + 0xa);
  return(0);
boolean getText(char *szMesg, char *psz, uint8_t len)
  boolean isValid = false;  // text received flag
  char *pStart, *pEnd;      // pointer to start and end of text
  // get pointer to the beginning of the text
  pStart = strstr(szMesg, "/&MSG=");
  if (pStart != NULL)
    pStart += 6;  // skip to start of data
    pEnd = strstr(pStart, "/&");
    if (pEnd != NULL)
      while (pStart != pEnd)
        if ((*pStart == '%') && isdigit(*(pStart+1)))
          // replace %xx hex code with the ASCII character
          char c = 0;
          pStart++;
          c += (htoi(*pStart++) << 4);
          c += htoi(*pStart++);
          *psz++ = c;
          *psz++ = *pStart++;
      *psz = '\0'; // terminate the string
      isValid = true;
  return(isValid);
void handleWiFi(void)
  static enum { S_IDLE, S_WAIT_CONN, S_READ, S_EXTRACT, S_RESPONSE, S_DISCONN } state = S_IDLE;
static char szBuf[1024];
  static uint16_t idxBuf = 0;
  static WiFiClient client;
  static uint32_t timeStart;
  switch (state)
  case S_IDLE:   // initialise
    PRINTS("\nS_IDLE");
    idxBuf = 0;
    state = S_WAIT_CONN;
  case S_WAIT_CONN:   // waiting for connection
      client = server.available();
      if (!client) break;
      if (!client.connected()) break;
#if DEBUG
      char szTxt[20];
      sprintf(szTxt, "%03d:%03d:%03d:%03d", client.remoteIP()[0], client.remoteIP()[1], client.remoteIP()[2], client.remoteIP()[3]);
 PRINT("\nNew client @ ", szTxt);
#endif
      timeStart = millis();
      state = S_READ;
  case S_READ: // get the first line of data
    PRINTS("\nS_READ");
    while (client.available())
      char c = client.read();
      if ((c == '\r') || (c == '\n'))
        szBuf[idxBuf] = '\0';
        client.flush();
        PRINT("\nRecv: ", szBuf);
        state = S_EXTRACT;
        szBuf[idxBuf++] = (char)c;
    if (millis() - timeStart > 1000)
      PRINTS("\nWait timeout");
      state = S_DISCONN;
  case S_EXTRACT: // extract data
    PRINTS("\nS_EXTRACT");
    // Extract the string from the message if there is one
    newMessageAvailable = getText(szBuf, newMessage, MESG_SIZE);
    PRINT("\nNew Msg: ", newMessage);
    state = S_RESPONSE;
  case S_RESPONSE: // send the response to the client
    PRINTS("\nS_RESPONSE");
    // Return the response to the client (web page)
    client.print(WebResponse);
    client.print(WebPage);
    state = S_DISCONN;
 case S_DISCONN: // disconnect client
    PRINTS("\nS_DISCONN");
    client.flush();
    client.stop();
    state = S_IDLE;
  default:  state = S_IDLE;
void scrollDataSink(uint8_t dev, MD_MAX72XX::transformType_t t, uint8_t col)
// Callback function for data that is being scrolled off the display
#if PRINT_CALLBACK
  Serial.print("\n cb ");
  Serial.print(dev);
  Serial.print(' ');
  Serial.print(t);
  Serial.print(' ');
  Serial.println(col);
#endif
uint8_t scrollDataSource(uint8_t dev, MD_MAX72XX::transformType_t t)
// Callback function for data that is required for scrolling into the display
  static enum { S_IDLE, S_NEXT_CHAR, S_SHOW_CHAR, S_SHOW_SPACE } state = S_IDLE;
  static char		*p;
  static uint16_t	curLen, showLen;
  static uint8_t	cBuf[8];
  uint8_t colData = 0;
  // finite state machine to control what we do on the callback
  switch (state)
  case S_IDLE: // reset the message pointer and check for new message to load
    PRINTS("\nS_IDLE");
    p = curMessage;      // reset the pointer to start of message
    if (newMessageAvailable)  // there is a new message waiting
      strcpy(curMessage, newMessage); // copy it in
    state = S_NEXT_CHAR;
  case S_NEXT_CHAR: // Load the next character from the font table
    PRINTS("\nS_NEXT_CHAR");
    if (*p == '\0')
      state = S_IDLE;
      showLen = mx.getChar(*p++, sizeof(cBuf) / sizeof(cBuf[0]), cBuf);
      curLen = 0;
      state = S_SHOW_CHAR;
 case S_SHOW_CHAR:	// display the next part of the character
    PRINTS("\nS_SHOW_CHAR");
    colData = cBuf[curLen++];
    if (curLen < showLen)
    // set up the inter character spacing
    showLen = (*p != '\0' ? CHAR_SPACING : (MAX_DEVICES*COL_SIZE)/2);
    curLen = 0;
    state = S_SHOW_SPACE;
    // fall through
  case S_SHOW_SPACE:	// display inter-character spacing (blank column)
    PRINT("\nS_ICSPACE: ", curLen);
    PRINT("/", showLen);
    curLen++;
    if (curLen == showLen)
default:
    state = S_IDLE;
  return(colData);
void scrollText(void)
  static uint32_t	prevTime = 0;
  // Is it time to scroll the text?
  if (millis() - prevTime >= SCROLL_DELAY)
    mx.transform(MD_MAX72XX::TSL);	// scroll along - the callback will load all the data
    prevTime = millis();			// starting point for next time
#if DEBUG
  PRINTS("\n[MD_MAX72XX WiFi Message Display]\nType a message for the scrolling display from your internet browser");
#endif
#if LED_HEARTBEAT
  pinMode(HB_LED, OUTPUT);
  digitalWrite(HB_LED, LOW);
#endif
  // Display initialisation
  mx.begin();
  mx.setShiftDataInCallback(scrollDataSource);
  mx.setShiftDataOutCallback(scrollDataSink);
  curMessage[0] = newMessage[0] = '\0';
  // Connect to and initialise WiFi network
  PRINT("\nConnecting to ", ssid);
 WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    PRINT("\n", err2Str(WiFi.status()));
  PRINTS("\nWiFi connected");
  // Start the server
  server.begin();
  PRINTS("\nServer started");
  // Set up first message as the IP address
  sprintf(curMessage, "%03d:%03d:%03d:%03d", WiFi.localIP()[0], WiFi.localIP()[1], WiFi.localIP()[2], WiFi.localIP()[3]);
  PRINT("\nAssigned IP ", curMessage);
#if LED_HEARTBEAT
  static uint32_t timeLast = 0;
  if (millis() - timeLast >= HB_LED_TIME)
    digitalWrite(HB_LED, digitalRead(HB_LED) == LOW ? HIGH : LOW);
    timeLast = millis();
#endif
  handleWiFi();
  scrollText();
Finally figured it out. Changed the following:
showLen = ( * p != '\0' ? CHAR_SPACING : (MAX_DEVICES * COL_SIZE) / 2);
to
showLen = ( * p != '\0' ? CHAR_SPACING : (MAX_DEVICES * COL_SIZE) );
