Problem with matrix display and scrolling text on it with Arduino Uno
Hello,
I have Arduino Uno and Max7219 8x32 matrix display. I connected them and then I tried to show text on display with no scrolling and it shows correct. But when I try to make scrolling text and use functions it starts scrolling, then start again, but never finish one scroll.Then it just stops at moment of scrolling and stay in this condition forever. I also tried to chacge cs pin from 8 to 10, but the result was same. How to solve this problem? Is it from the display or from where? I will be very thankfull if you help me, I have searched over internet but nowhere I find the solution.
Thank you!
This is my code for scrolling text:
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
#define HARDWARE_TYPE MD_MAX72XX::FC16_HW
#define MAX_DEVICES 4
#define CS_PIN      8
MD_Parola myDisplay = MD_Parola(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
  myDisplay.begin();
  myDisplay.setIntensity(0);
  myDisplay.displayClear();
  myDisplay.displayScroll("Hello World!", PA_CENTER, PA_SCROLL_LEFT, 100);
  if (myDisplay.displayAnimate()) {
    myDisplay.displayReset();
Why?
Without it the result is same.
You have to keep calling the function inside your loop like this:
if (!lmd.updateTicker()) lmd.stopTicker(); //Stop at end
Hello,
Thank you for your answer. But this library doesn't work with my matrix display and Arduino Uno. I tried the example in the library but it didn't show any text, only single dots shine and one is blinking. And the compiler in Arduino IDE says that the available memory is low and may cause problems. I don't know why.
I had problem with a 4 x 8x8 MAZ72xx display. After some frustration and some kind and helpful advice, my device's connections were not as per the Parola.h. I tried some other and heh bingo! all was good.
Try another device header file.
Can you give me example. I can't understand what I have to try. Sorry and thank for advice!
Hello,
I have problem with my matrix display. It is connected to Arduino Uno, but when I try to scroll text on it the display is not showing the text correct. Here is link with video to view how it scroll the text: Kapwing — The collaborative video editor for modern teams . How to solve this problem? I will be very thankfull, if you help me.
Thank you!
Here is my code:
#include <SPI.h>
#define CS_PIN      8
  myDisplay.begin();
  myDisplay.displayScroll("Hello World!", PA_CENTER, PA_SCROLL_LEFT, 200);
  myDisplay.displayAnimate();
Check out my clock project. It uses the same display and has code that works.
8x8x4 clock
I have merged your cross-posts @tgarmenliev.
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please take some time to pick the forum category that best suits the subject of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide you will find at the top of every forum category. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
I was unable to post the whole sketch of an example called MD_MAX72xx_Test that I downloaded from somewhere.
The salient lines are as below - if this uploads OK
// Define the number of devices we have in the chain and the hardware interface
// NOTE: These pin numbers will probably not work with your hardware and may
// need to be adapted
**#define HARDWARE_TYPE MD_MAX72XX::ICSTATION_HW**
#define CLK_PIN   13  // or SCK
#define DATA_PIN  11  // or MOSI
#define CS_PIN    10  // or SS
Whole sketch is:
// Program to exercise the MD_MAX72XX library
// Uses most of the functions in the library
// Turn on debug statements to the serial output
#define  DEBUG  1
#if  DEBUG
#define PRINT(s, x) { Serial.print(F(s)); Serial.print(x); }
#define PRINTS(x) Serial.print(F(x))
#define PRINTD(x) Serial.println(x, DEC)
#else
#define PRINT(s, x)
#define PRINTS(x)
#define PRINTD(x)
#endif
// SPI hardware interface
MD_MAX72XX mx = MD_MAX72XX(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
// Specific SPI hardware interface
//MD_MAX72XX mx = MD_MAX72XX(HARDWARE_TYPE, SPI1, CS_PIN, MAX_DEVICES);
// Arbitrary pins
//MD_MAX72XX mx = MD_MAX72XX(HARDWARE_TYPE, DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
// We always wait a bit between updates of the display
#define  DELAYTIME  500  // in milliseconds
void scrollText(const char *p)
  uint8_t charWidth;
  uint8_t cBuf[8];  // this should be ok for all built-in fonts
  PRINTS("\nScrolling text");
  mx.clear();
  while (*p != '\0')
    charWidth = mx.getChar(*p++, sizeof(cBuf) / sizeof(cBuf[0]), cBuf);
    for (uint8_t i=0; i<=charWidth; i++)	// allow space between characters
      mx.transform(MD_MAX72XX::TSL);
      if (i < charWidth)
        mx.setColumn(0, cBuf[i]);
      delay(DELAYTIME);
void zeroPointSet()
// Demonstrates the use of setPoint and
// show where the zero point is in the display
  PRINTS("\nZero point highlight");
  mx.clear();
  if (MAX_DEVICES > 1)
    mx.setChar((2*COL_SIZE)-1, '0');
  for (uint8_t i=0; i<ROW_SIZE; i++)
    mx.setPoint(i, i, true);
    mx.setPoint(0, i, true);
    mx.setPoint(i, 0, true);
    delay(DELAYTIME);
  delay(DELAYTIME*3);
void rows()
// Demonstrates the use of setRow()
  PRINTS("\nRows 0->7");
  mx.clear();
  for (uint8_t row=0; row<ROW_SIZE; row++)
    mx.setRow(row, 0xff);
    delay(2*DELAYTIME);
    mx.setRow(row, 0x00);
void checkboard()
// nested rectangles spanning the entire display
  uint8_t chkCols[][2] = { { 0x55, 0xaa }, { 0x33, 0xcc }, { 0x0f, 0xf0 }, { 0xff, 0x00 } };
  PRINTS("\nCheckboard");
  mx.clear();
  for (uint8_t pattern = 0; pattern < sizeof(chkCols)/sizeof(chkCols[0]); pattern++)
    uint8_t col = 0;
    uint8_t idx = 0;
    uint8_t rep = 1 << pattern;
    while (col < mx.getColumnCount())
      for (uint8_t r = 0; r < rep; r++)
        mx.setColumn(col++, chkCols[pattern][idx]);   // use odd/even column masks
      idx++;
      if (idx > 1) idx = 0;
    delay(10 * DELAYTIME);
void columns()
// Demonstrates the use of setColumn()
  PRINTS("\nCols 0->max");
  mx.clear();
  for (uint8_t col=0; col<mx.getColumnCount(); col++)
    mx.setColumn(col, 0xff);
    delay(DELAYTIME/MAX_DEVICES);
    mx.setColumn(col, 0x00);
void cross()
// Combination of setRow() and setColumn() with user controlled
// display updates to ensure concurrent changes.
  PRINTS("\nMoving cross");
  mx.clear();
  mx.control(MD_MAX72XX::UPDATE, MD_MAX72XX::OFF);
  // diagonally down the display R to L
    for (uint8_t j=0; j<MAX_DEVICES; j++)
      mx.setColumn(j, i, 0xff);
      mx.setRow(j, i, 0xff);
    mx.update();
    delay(DELAYTIME);
      mx.setColumn(j, i, 0x00);
      mx.setRow(j, i, 0x00);
  // moving up the display on the R
  for (int8_t i=ROW_SIZE-1; i>=0; i--)
      mx.setRow(j, ROW_SIZE-1, 0xff);
    mx.update();
    delay(DELAYTIME);
      mx.setRow(j, ROW_SIZE-1, 0x00);
  // diagonally up the display L to R
      mx.setRow(j, ROW_SIZE-1-i, 0xff);
    mx.update();
    delay(DELAYTIME);
      mx.setRow(j, ROW_SIZE-1-i, 0x00);
  mx.control(MD_MAX72XX::UPDATE, MD_MAX72XX::ON);
void bullseye()
// Demonstrate the use of buffer based repeated patterns
// across all devices.
  PRINTS("\nBullseye");
  mx.clear();
  for (uint8_t n=0; n<3; n++)
    byte  b = 0xff;
    int   i = 0;
    while (b != 0x00)
      for (uint8_t j=0; j<MAX_DEVICES+1; j++)
        mx.setRow(j, i, b);
        mx.setColumn(j, i, b);
        mx.setRow(j, ROW_SIZE-1-i, b);
        mx.setColumn(j, COL_SIZE-1-i, b);
      mx.update();
      delay(3*DELAYTIME);
        mx.setRow(j, i, 0);
        mx.setColumn(j, i, 0);
        mx.setRow(j, ROW_SIZE-1-i, 0);
        mx.setColumn(j, COL_SIZE-1-i, 0);
      bitClear(b, i);
      bitClear(b, 7-i);
      i++;
    while (b != 0xff)
        mx.setRow(j, i, b);
      mx.update();
      delay(3*DELAYTIME);
        mx.setRow(j, i, 0);
      i--;
      bitSet(b, i);
      bitSet(b, 7-i);
void stripe()
// Demonstrates animation of a diagonal stripe moving across the display
// with points plotted outside the display region ignored.
  const uint16_t maxCol = MAX_DEVICES*ROW_SIZE;
  const uint8_t	stripeWidth = 10;
  PRINTS("\nEach individually by row then col");
  mx.clear();
  for (uint16_t col=0; col<maxCol + ROW_SIZE + stripeWidth; col++)
    for (uint8_t row=0; row < ROW_SIZE; row++)
      mx.setPoint(row, col-row, true);
      mx.setPoint(row, col-row - stripeWidth, false);
    delay(DELAYTIME);
void spiral()
// setPoint() used to draw a spiral across the whole display
  PRINTS("\nSpiral in");
  int  rmin = 0, rmax = ROW_SIZE-1;
  int  cmin = 0, cmax = (COL_SIZE*MAX_DEVICES)-1;
  mx.clear();
  while ((rmax > rmin) && (cmax > cmin))
    // do row
    for (int i=cmin; i<=cmax; i++)
      mx.setPoint(rmin, i, true);
    rmin++;
    // do column
    for (uint8_t i=rmin; i<=rmax; i++)
      mx.setPoint(i, cmax, true);
    cmax--;
    // do row
    for (int i=cmax; i>=cmin; i--)
      mx.setPoint(rmax, i, true);
    rmax--;
    // do column
    for (uint8_t i=rmax; i>=rmin; i--)
      mx.setPoint(i, cmin, true);
    cmin++;
void bounce()
// Animation of a bouncing ball
  const int minC = 0;
  const int maxC = mx.getColumnCount()-1;
  const int minR = 0;
  const int maxR = ROW_SIZE-1;
  int  nCounter = 0;
  int  r = 0, c = 2;
  int8_t dR = 1, dC = 1;	// delta row and column
  PRINTS("\nBouncing ball");
  mx.clear();
  while (nCounter++ < 200)
    mx.setPoint(r, c, false);
    r += dR;
    c += dC;
    mx.setPoint(r, c, true);
    delay(DELAYTIME/2);
    if ((r == minR) || (r == maxR))
      dR = -dR;
    if ((c == minC) || (c == maxC))
      dC = -dC;
void intensity()
// Demonstrates the control of display intensity (brightness) across
// the full range.
  uint8_t row;
  PRINTS("\nVary intensity ");
  mx.clear();
  // Grow and get brighter
  row = 0;
  for (int8_t i=0; i<=MAX_INTENSITY; i++)
    mx.control(MD_MAX72XX::INTENSITY, i);
    if (i%2 == 0)
      mx.setRow(row++, 0xff);
    delay(DELAYTIME*3);
  mx.control(MD_MAX72XX::INTENSITY, 8);
void blinking()
// Uses the test function of the MAX72xx to blink the display on and off.
  int  nDelay = 1000;
  PRINTS("\nBlinking");
  mx.clear();
  while (nDelay > 0)
    mx.control(MD_MAX72XX::TEST, MD_MAX72XX::ON);
    delay(nDelay);
    mx.control(MD_MAX72XX::TEST, MD_MAX72XX::OFF);
    delay(nDelay);
    nDelay -= DELAYTIME;
void scanLimit(void)
// Uses scan limit function to restrict the number of rows displayed.
  PRINTS("\nScan Limit");
  mx.clear();
  for (int8_t s=MAX_SCANLIMIT; s>=0; s--)
    mx.control(MD_MAX72XX::SCANLIMIT, s);
    delay(DELAYTIME*5);
  mx.control(MD_MAX72XX::SCANLIMIT, MAX_SCANLIMIT);
void transformation1()
// Demonstrates the use of transform() to move bitmaps on the display
// In this case a user defined bitmap is created and animated.
  uint8_t arrow[COL_SIZE] =
    0b00001000,
    0b00011100,
    0b00111110,
    0b01111111,
    0b00011100,
    0b00011100,
    0b00111110,
    0b00000000
  MD_MAX72XX::transformType_t  t[] =
    MD_MAX72XX::TSL, MD_MAX72XX::TSL, MD_MAX72XX::TSL, MD_MAX72XX::TSL,
    MD_MAX72XX::TFLR,
    MD_MAX72XX::TSR, MD_MAX72XX::TSR, MD_MAX72XX::TSR, MD_MAX72XX::TSR,
    MD_MAX72XX::TRC,
    MD_MAX72XX::TSD, MD_MAX72XX::TSD, MD_MAX72XX::TSD, MD_MAX72XX::TSD,
    MD_MAX72XX::TFUD,
    MD_MAX72XX::TSU, MD_MAX72XX::TSU, MD_MAX72XX::TSU, MD_MAX72XX::TSU,
    MD_MAX72XX::TINV,
    MD_MAX72XX::TRC, MD_MAX72XX::TRC, MD_MAX72XX::TRC, MD_MAX72XX::TRC,
    MD_MAX72XX::TINV
  PRINTS("\nTransformation1");
  mx.clear();
  // use the arrow bitmap
  for (uint8_t j=0; j<mx.getDeviceCount(); j++)
    mx.setBuffer(((j+1)*COL_SIZE)-1, COL_SIZE, arrow);
  delay(DELAYTIME);
  // run through the transformations
  mx.control(MD_MAX72XX::WRAPAROUND, MD_MAX72XX::ON);
  for (uint8_t i=0; i<(sizeof(t)/sizeof(t[0])); i++)
    mx.transform(t[i]);
    delay(DELAYTIME*4);
  mx.control(MD_MAX72XX::WRAPAROUND, MD_MAX72XX::OFF);
void transformation2()
// In this case font characters are loaded into the display for animation.
    MD_MAX72XX::TINV,
    MD_MAX72XX::TINV,
    MD_MAX72XX::TSL, MD_MAX72XX::TSL, MD_MAX72XX::TSL, MD_MAX72XX::TSL, MD_MAX72XX::TSL,
    MD_MAX72XX::TSR, MD_MAX72XX::TSR, MD_MAX72XX::TSR, MD_MAX72XX::TSR, MD_MAX72XX::TSR,
    MD_MAX72XX::TSR, MD_MAX72XX::TSR, MD_MAX72XX::TSR, MD_MAX72XX::TSR, MD_MAX72XX::TSR, MD_MAX72XX::TSR, MD_MAX72XX::TSR, MD_MAX72XX::TSR,
    MD_MAX72XX::TSL, MD_MAX72XX::TSL, MD_MAX72XX::TSL, MD_MAX72XX::TSL, MD_MAX72XX::TSL, MD_MAX72XX::TSL, MD_MAX72XX::TSL, MD_MAX72XX::TSL,
    MD_MAX72XX::TSD, MD_MAX72XX::TSU, MD_MAX72XX::TSD, MD_MAX72XX::TSU,
    MD_MAX72XX::TFLR, MD_MAX72XX::TFLR, MD_MAX72XX::TFUD, MD_MAX72XX::TFUD
  PRINTS("\nTransformation2");
  mx.clear();
  // draw something that will show changes
    mx.setChar(((j+1)*COL_SIZE)-1, '0'+j);
  delay(DELAYTIME*5);
  // run thru transformations
    mx.transform(t[i]);
    delay(DELAYTIME*3);
void wrapText()
// Display text and animate scrolling using auto wraparound of the buffer
  PRINTS("\nwrapText");
  mx.clear();
  mx.wraparound(MD_MAX72XX::ON);
  for (uint16_t j=0; j<mx.getDeviceCount(); j++)
    mx.setChar(((j+1)*COL_SIZE)-1, (j&1 ? 'M' : 'W'));
  delay(DELAYTIME*5);
  for (uint16_t i=0; i<3*COL_SIZE*MAX_DEVICES; i++)
    delay(DELAYTIME/2);
    mx.transform(MD_MAX72XX::TSR);
    delay(DELAYTIME/2);
    mx.transform(MD_MAX72XX::TSU);
    delay(DELAYTIME*2);
    mx.transform(MD_MAX72XX::TSD);
    delay(DELAYTIME*2);
  mx.wraparound(MD_MAX72XX::OFF);
void showCharset(void)
// Run through display of the the entire font characters set
  mx.clear();
  mx.update(MD_MAX72XX::OFF);
  for (uint16_t i=0; i<256; i++)
    mx.clear(0);
    mx.setChar(COL_SIZE-1, i);
    if (MAX_DEVICES >= 3)
      char hex[3];
      sprintf(hex, "%02X", i);
      mx.clear(1);
      mx.setChar((2*COL_SIZE)-1,hex[1]);
      mx.clear(2);
      mx.setChar((3*COL_SIZE)-1,hex[0]);
    mx.update();
    delay(DELAYTIME*2);
  mx.update(MD_MAX72XX::ON);
  mx.begin();
#if  DEBUG
  Serial.begin(57600);
#endif
  PRINTS("\n[MD_MAX72XX Test & Demo]");
//  scrollText("MD_MAX72xx Test  ");
#if 1
  scrollText("Graphics");
  zeroPointSet();
  rows();
  columns();
  cross();
  stripe();
  checkboard();
  bullseye();
  bounce();
  spiral();
#endif
#if 1
  scrollText("Control");
  intensity();
  scanLimit();
  blinking();
#endif
#if 1
  scrollText("Transform");
  transformation1();
  transformation2();
#endif
#if 1
  scrollText("Charset");
  wrapText();
  showCharset();
#endif
