SD card benchmark with ESP32
after some issues with some of my old and new SD cards I looked for a benchmark script for ESP32. Since I didn't found one I used the bench.ino and modified it for using with the ESP32.
There are two possibilities to connect a SD card to the ESP:
  1. using a single wire / 1 bit SPI connection and the "SD.h" library
  2. using four wires / 4 bit SPI connection and the "SD_MMC.h" library
Depending on the available I/O pins and the free memory and also the required speed for read and write (usually you do not need the highest speed) you have to select one of them. And depending on the SD card (micro SD cards also). With my tests not all of the cards support both connections which is weird as I read that 1 bit mode should be available for all of them.
However, using the 1 bit mode we have the possibility to change the SPI speed which is limited in the SD.h library package to max. 25 mHz. For the 4 bit mode I did not find how to modify this frequency, of course, but I did not took a very deep look into the library.
SDCardBenchmark-SPI.ino:
// Title: SD Card Benchmark for ESP2 using 1Bit SPI
// Description:
// SD Card Benchmark is based on "bench.ino" from "SdFat 2.1.2".
// Because there are many differences and SdFat does no support ESP32 this is almost a rewrite.
// Includes
// SD Card library, usually part of the standard installation
#include "SD.h"
// Defines
// Digital I/O used for SD card
#define SD_CS          5          // SD Card chip select
#define SPI_MOSI      23
#define SPI_MISO      19
#define SPI_SCK       18
// Constants
// Array of frequencies to be tested for connection
//const uint32_t frequencies[] =
//   1000000,  2000000,  4000000,  8000000,
//  10000000, 12000000, 14000000, 16000000,
//  18000000, 20000000, 21000000, 22000000,
//  23000000, 24000000, 25000000
  4000000, 16000000, 25000000
// Set SKIP_FIRST_LATENCY true if the first read/write to the SD can
// be avoid by writing a file header or reading the first record.
const bool SKIP_FIRST_LATENCY = true;
// Size of read/write.
const size_t BUF_SIZE = 512;
// File size in MB where MB = 1,000,000 bytes.
const uint32_t FILE_SIZE_MB = 5;
// Write pass count.
const uint8_t WRITE_COUNT = 5;
// Read pass count.
const uint8_t READ_COUNT = 5;
// Structures and also variables
// File size in bytes.
const uint32_t FILE_SIZE = 1000000UL * FILE_SIZE_MB;
// Ensure 4-byte alignment.
uint32_t buf32[ ( BUF_SIZE + 3 ) / 4 ];
uint8_t* buf = (uint8_t*)buf32;
// Test file
File file;
  Serial.begin( 115200 );
  // Wait for USB Serial
  while( !Serial )
    delay( 100 );
  delay( 1000 );
  Serial.println( "Use a freshly formatted SD for best performance." );
  Serial.println( "FILE_SIZE_MB = " + String( FILE_SIZE_MB ) );
  Serial.println( "BUF_SIZE = " + String( BUF_SIZE ) + " bytes" );
  for( uint8_t numfreq = 0; numfreq < sizeof( frequencies ) / sizeof( uint32_t ); numfreq++ )
    Serial.println( "" );
    if( SDCardInit( frequencies[ numfreq ] ) )
      // Open file for write access.
      // Random access is not possible with SD.h
      file = SD.open( "/bench.dat", FILE_WRITE );
      if( !file )
        Serial.println( "File open failed." );
        if( WriteTest() )
          delay( 500 );
          if( CheckFileContent() )
            ReadTest();
      SDCardUnmount();
    delay( 5000 );
  Serial.println( "Done" );
  esp_deep_sleep_start();
// Initialize SD card
bool SDCardInit( uint32_t frequency )
  bool init = false;
  // Configure SD ChipSelect pin as output
  pinMode( SD_CS, OUTPUT );
  // SD card chips select, must use GPIO 5 (ESP32 SS)
  digitalWrite( SD_CS, HIGH );
  Serial.println( "Trying to connect to SD card with " + String( frequency / 1000000 ) + " MHz." );
  // Depending on the SD card a higher frequency might help to get data fast enough
  if( !SD.begin( SD_CS, SPI, frequency ) )
    Serial.println( "Error talking to SD card!" );
    Serial.println( "SD card initialized successfull" );
    Serial.print( "SD card type=" );
    switch( SD.cardType() )
      case CARD_NONE:
        Serial.println( "None" );
      case CARD_MMC:
        Serial.println( "MMC" );
      case CARD_SD:
        Serial.println( "SD" );
      case CARD_SDHC:
        Serial.println( "SDHC" );
      case CARD_UNKNOWN:
        Serial.println( "Unknown" );
      default:
    Serial.print( "Card size:   " ); Serial.print( SD.cardSize() / 1000000 ); Serial.println( "MB" );
    Serial.print( "Total bytes: " ); Serial.print( SD.totalBytes() / 1000000 ); Serial.println( "MB" );
    Serial.print( "Used bytes:  " ); Serial.print( SD.usedBytes() / 1000000 ); Serial.println( "MB" );
    init = true;
  return init;
// Unmount SD card
void SDCardUnmount()
  Serial.print( "Unmounting SD card..." );
  // Unmount SD card
  SD.end();
  Serial.println( "done." );
// Start write test
bool WriteTest()
  float s;
  uint64_t t, m;
  uint64_t maxLatency;
  uint64_t minLatency;
  uint64_t totalLatency;
  uint32_t avgLatency;
  bool skipLatency;
  uint32_t n = FILE_SIZE / BUF_SIZE;
  Serial.println( "Starting write test, please wait." );
  // First fill buffer "buf" with known data that can be checked later
  if( BUF_SIZE > 1 )
    for( size_t i = 0; i < ( BUF_SIZE - 2 ); i++ )
      buf[ i ] = 'A' + ( i % 26 );
    buf[ BUF_SIZE - 2 ] = '\r';
  buf[ BUF_SIZE - 1 ] = '\n';
  Serial.println( "write speed and latency" );
  Serial.println( "speed,max,min,avg" );
  Serial.println( "KB/Sec,usec,usec,usec" );
  for( uint8_t nTest = 0; nTest < WRITE_COUNT; nTest++ )
    file.seek( 0 );
    maxLatency = 0;
    minLatency = 9999999;
    totalLatency = 0;
    skipLatency = SKIP_FIRST_LATENCY;
    t = micros();
    for( uint32_t i = 0; i < n; i++ )
      m = micros();
      if( file.write( buf, BUF_SIZE ) != BUF_SIZE )
        Serial.println( "write failed" );
        file.close();
        return false;
      m = micros() - m;
      totalLatency += m;
      if( skipLatency )
        // Wait until first write to SD, not just a copy to the cache.
        skipLatency = file.position() < 512;
        if( maxLatency < m )
          maxLatency = m;
        if( minLatency > m )
          minLatency = m;
    file.flush();
    t = micros() - t;
    s = file.size();
    if( SKIP_FIRST_LATENCY )
      avgLatency = (uint32_t)( totalLatency / ( n - 1 ) );
      avgLatency = (uint32_t)( totalLatency / n );
    Serial.println( String( (uint32_t)( s * 1000 / t ) ) + ',' + String( (uint32_t)maxLatency ) + ',' + String( (uint32_t)minLatency ) + ',' + String( avgLatency ) );
  file.close();
  Serial.println( "Write test finished successfully." );
  return true;
// Check the file content
bool CheckFileContent()
  // Open fie for reading
  file = SD.open( "/bench.dat", FILE_READ );
  if( !file )
    return false;
  Serial.println( "Checking file content, please wait." );
    int32_t nr = file.read( buf, BUF_SIZE );
    if( nr != BUF_SIZE )
      Serial.println( "read failed, bytes read: " + String( nr ) );
      file.close();
      return false;
      if( buf[ i ] != ( 'A' + ( i % 26 ) ) )
        Serial.println( "data check error" );
        file.close();
        return false;
    if( buf[ BUF_SIZE - 2 ] != '\r' )
      file.close();
      return false;
    if( buf[ BUF_SIZE - 1 ] != '\n' )
      file.close();
      return false;
  file.close();
  Serial.println( "File content correct." );
  return true;
// Read test
bool ReadTest()
  float s;
  uint64_t t, m;
  bool skipLatency;
  if( !file )
    return false;
  Serial.println( "Starting read test, please wait." );
  Serial.println( "read speed and latency" );
  for( uint8_t nTest = 0; nTest < READ_COUNT; nTest++ )
    file.seek( 0 );
    maxLatency = 0;
    totalLatency = 0;
    t = micros();
      buf[ BUF_SIZE - 1 ] = 0;
      m = micros();
        file.close();
        return false;
      m = micros() - m;
      totalLatency += m;
      if( skipLatency )
        skipLatency = false;
          maxLatency = m;
          minLatency = m;
    t = micros() - t;
    s = file.size();
  file.close();
  Serial.println( "Read test finished successfully." );
  return true;
SDCardBenchmark-SDMMC.ino:
// Title: SD Card Benchmark for ESP2 using 4Bit SDMMC
// Description:
// Includes
// SD-MMC Card library, usually part of the standard installation
 * Connect the SD card to the following pins:
 * SD Card | ESP32
 *    D2       12
 *    D3       13
 *    CMD      15
 *    VSS      GND
 *    VDD      3.3V
 *    CLK      14
 *    VSS      GND
 *    D0       2
 *    D1       4
#include "FS.h"
#include "SD_MMC.h"
// Read pass count.
// Test file
File file;
  Serial.begin( 115200 ); // Used for info/debug
  while( !Serial )
    delay( 100 );
  delay( 1000 );
  if( SDCardInit() )
    file = SD_MMC.open( "/bench.dat", FILE_WRITE );
    if( !file )
      if( WriteTest() )
        delay( 500 );
          ReadTest();
    SDCardUnmount();
  while( 1 );
bool SDCardInit()
  bool init = false;
  Serial.println( "Trying to connect to SD card" );
  if( !SD_MMC.begin() )
    switch( SD_MMC.cardType() )
      case CARD_NONE:
      case CARD_MMC:
      case CARD_SD:
      case CARD_SDHC:
      case CARD_UNKNOWN:
      default:
    Serial.print( "Card size:   " ); Serial.print( (uint32_t)( SD_MMC.cardSize() / 1000000 ) ); Serial.println( "MB" );
    Serial.print( "Total bytes: " ); Serial.print( (uint32_t)( SD_MMC.totalBytes() / 1000000 ) ); Serial.println( "MB" );
    Serial.print( "Used bytes:  " ); Serial.print( (uint32_t)( SD_MMC.usedBytes() / 1000000 ) ); Serial.println( "MB" );
    init = true;
  return init;
// Unmount SD card
  // Unmount SD card
  SD_MMC.end();
// Start write test
bool WriteTest()
  float s;
  uint64_t t, m;
  bool skipLatency;
  if( BUF_SIZE > 1 )
    file.seek( 0 );
    maxLatency = 0;
    totalLatency = 0;
    t = micros();
      m = micros();
        file.close();
        return false;
      m = micros() - m;
      totalLatency += m;
      if( skipLatency )
          maxLatency = m;
          minLatency = m;
    file.flush();
    t = micros() - t;
    s = file.size();
  file.close();
  return true;
  file = SD_MMC.open( "/bench.dat", FILE_READ );
  if( !file )
    return false;
      file.close();
      return false;
        file.close();
        return false;
      file.close();
      return false;
      file.close();
      return false;
  file.close();
  return true;
// Read test
bool ReadTest()
  float s;
  uint64_t t, m;
  bool skipLatency;
  if( !file )
    return false;
    file.seek( 0 );
    maxLatency = 0;
    totalLatency = 0;
    t = micros();
      m = micros();
        file.close();
        return false;
      m = micros() - m;
      totalLatency += m;
      if( skipLatency )
          maxLatency = m;
          minLatency = m;
    t = micros() - t;
    s = file.size();
  file.close();
  return true;
You can find some pages on the internet if you are not sure how to connect the SD card reader to your ESP32.
Regards
Nils
