Hello,
We are currently doing a project recording accelerometer data onto an SD card, this works fine when the Arduino is plugged the computer via the USB. However, when the Arduino is powered by a 9V battery no data is put onto the SD card.
It is seen that other people have ran into a similar problem before but none of those threads were resolved.
Below you can see the code we are using.
Any help would be appreciated
Here is a picture of our circuit with the battery plugged in.
#include "Arduino_BMI270_BMM150.h"
#include <SD.h>
#include <SPI.h>
const int buttonPin = 7; // Pin for button input
const int ledPin = 9; // Pin for LED (to indicate data collection)
bool lastButtonState = HIGH; // Previous button state (for debounce)
unsigned long lastDebounceTime = 0; // Last debounce time
unsigned long debounceDelay = 50; // Debounce delay
// Number of readings and rate (can be adjusted)
const int numberOfReadings = 100; // 100 readings
const float rateOfReadings = 10.0; // 10 readings per second
// SD card settings
const int chipSelect = 10; // Pin for CS (Chip Select)
// File object for SD card
File dataFile;
Serial.begin(115200); // Start serial communication
pinMode(buttonPin, INPUT_PULLUP); // Set the button pin as input with internal pull-up resistor
pinMode(ledPin, OUTPUT); // Set the LED pin as an output
while (!Serial); // Wait for serial port to open
if (!IMU.begin()) { // Initialize IMU (accelerometer and magnetometer)
Serial.println("Failed to initialize IMU!");
while (1); // Halt if IMU initialization fails
// Initialize the SD card
Serial.println("Initializing SD card...");
if (!SD.begin(chipSelect)) {
Serial.println("SD card initialization failed!");
while (1); // Halt the program if SD initialization fails
Serial.println("SD card initialized successfully!");
Serial.println("SD card initialized!");
Serial.println("Ready to collect data! Press the button to start.");
int buttonState = digitalRead(buttonPin); // Read button state
// Debounce logic to prevent multiple triggers on button press
if (buttonState != lastButtonState) {
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
if (buttonState == LOW) { // LOW when the button is pressed
Serial.println("Button Pressed! Starting data collection...");
// Turn on the LED to indicate data collection is starting
digitalWrite(ledPin, HIGH);
// Start data collection
collectData();
// Turn off the LED after data collection completes
digitalWrite(ledPin, LOW);
lastButtonState = buttonState; // Update last button state
// Function to collect sensor data
void collectData() {
unsigned long dataT[numberOfReadings]; // Array to store time of readings
float dataX[numberOfReadings], dataY[numberOfReadings], dataZ[numberOfReadings]; // Arrays to store accelerometer data
// Calculate delay time between readings based on the specified rate
double delayTime = 1000.0 / rateOfReadings;
// Start time of data collection
unsigned long startTime = millis();
// Open the file on the SD card
dataFile = SD.open("data.csv", FILE_WRITE);
if (dataFile) {
// Write the header to the CSV file
dataFile.println("Time(ms), X, Y, Z");
// Collect data
for (int n = 0; n < numberOfReadings; n++) {
unsigned long elapsedTime = millis() - startTime; // Calculate elapsed time
dataT[n] = elapsedTime;
// Read accelerometer data
float x, y, z;
IMU.readAcceleration(x, y, z); // Read data from accelerometer
dataX[n] = x * 100; // Scale the x-axis data
dataY[n] = y * 100; // Scale the y-axis data
dataZ[n] = z * 100; // Scale the z-axis data
// Write the data to the SD card
dataFile.print(dataT[n]); // Time of reading
dataFile.print(",");
dataFile.print(dataX[n]); // x-axis data
dataFile.print(dataY[n]); // y-axis data
dataFile.println(dataZ[n]); // z-axis data
// Wait for the next reading based on the rate
while (millis() - startTime < (n + 1) * delayTime) {
// Wait until it's time for the next reading
// Close the file after writing
dataFile.close();
Serial.println("Data collection complete! Data saved to SD card.");
Serial.println("Error opening file on SD card!");
