SD Card formatting weirdly
Random issue annoying me, trying to save sensor data to a sd card,
when I'm saving it in CSV format it saves the first two data points correctly but on the third
it takes a new line. see below images of output and code.
any help would be appreciated.
Regards,
Dav
looks like your var   inputString   has  \n   at the end
try to trim it using
inputString.trim();
or
inputString.replace("\n","");
I assume inputString is of a String type
thank you.
There is no good reason to use Strings with Serial.print. On an AVR you should avoid using Strings entirely, because they cause program malfunctions and outright crashes.
