SD Card Module
I'm currently trying to use a SD Card Module and a Arduino Mega to save data collected from a sensor on a txt file, but it doesn'y save the text on the txt file.
Here's the code:
#include <SD.h>
#include <SPI.h>
// On the Ethernet Shield, CS is pin 4. Note that even if it's not
// used as the CS pin, the hardware CS pin (10 on most Arduino boards,
// 53 on the Mega) must be left as an output or the SD library
// functions will not work.
const int chipSelect = 4;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("Initializing SD card...");
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(chipSelect, OUTPUT);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
  Serial.println("card initialized.");
  // make a string for assembling the data to log:
  String dataString = "";
  int sensor = analogRead(0);
  dataString = String(sensor);
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  File dataFile = SD.open("datalog.txt", FILE_WRITE);
  // if the file is available, write to it:
  if (dataFile) {
    dataFile.println(dataString);
    dataFile.close();
    // print to the serial port too:
    Serial.println(dataString);
  // if the file isn't open, pop up an error:
  else {
    Serial.println("error opening datalog.txt");
I got the following on serial monitor:
card initialized
value from the sensor (just one time)
Any advices on what's wrong?
Thanks in advance,
José Coelho
try addig this:
pinMode(10, OUTPUT); // in setup
The SPI library sets the SS pin to an output already:
 * Copyright (c) 2010 by Cristian Maglie <c.maglie@bug.st>
 * SPI Master library for arduino.
 * This file is free software; you can redistribute it and/or modify
 * it under the terms of either the GNU General Public License version 2
 * or the GNU Lesser General Public License version 2.1, both as
 * published by the Free Software Foundation.
#include "pins_arduino.h"
#include "SPI.h"
SPIClass SPI;
void SPIClass::begin() {
  // Set SS to high so a connected chip will be "deselected" by default
  digitalWrite(SS, HIGH);
  // When the SS pin is set as OUTPUT, it can be used as
  // a general purpose output port (it doesn't influence
  // SPI operations).
  pinMode(SS, OUTPUT);
  // Warning: if the SS pin ever becomes a LOW INPUT then SPI
  // automatically switches to Slave, so the data direction of
  // the SS pin MUST be kept as OUTPUT.
  SPCR |= _BV(MSTR);
  SPCR |= _BV(SPE);
  // Set direction register for SCK and MOSI pin.
  // MISO pin automatically overrides to INPUT.
  // By doing this AFTER enabling SPI, we avoid accidentally
  // clocking in a single bit since the lines go directly
  // from "input" to SPI control.
  // http://code.google.com/p/arduino/issues/detail?id=888
  pinMode(SCK, OUTPUT);
  pinMode(MOSI, OUTPUT);
I'm not sure where to find the link from Mega pin 53 to SS; setting 53 to an output in setup so the Mega is SPI master wouldn't hurt:
pinMode (53, OUTPUT);
You do have 5V to 3.3V converters for SCK, MOSI, and CS in the design someplace? (such as cd74HC4050) And a 200-250mA capable 3.3V source? The Mega 3.3V regulator is only good for 150mA.
knut_ny:
try addig this:
I added that and still not working.
CrossRoads:
I though the module was ready to convert 5v to 3.3v. I saw some videos where they use the same module without any voltage converters or external sources. I'll try using a voltage converter and a better source (a capacitor will do the job or it's better to get one source)?
josecoelho:
I though the module was ready to convert 5v to 3.3v. I'll try using a voltage converter and a better source
You are probably right, I think most SD modules are good for 5v, and it will pay to check before you do anything. It should be clear enough, with a pin labelled 5v. If it doesn't have a 5v pin, it might be simpler to pay up another $2.50 and get a module that does..
My module has 3.3v and 5v pins.
In that case, looking to check was a good idea, and using a converter isn't.
The next thing to try is ignore reply#1, delete
and use
pinMode(53, OUTPUT);
which is standard procedure for a Mega, and clearly shown as comment in the code you already have. Your code seems to be otherwise OK, although keeping the redundant line
while (!Serial) {
can't be a good idea.
All this assumes you are using the the standard wiring for Mega
** MISO - 50
** MOSI - 51
** CLK - 52
** CS - 4
or the ICSP pins, which are common to Uno and Mega. You can, of course use any pin for CS, so long as you identify it in the code. A shield I have for a Mega uses pin 53, and this is probably common practice
const int chipSelect = 53;
void setup(){
  Serial.print("\nInitializing SD card...");
