Sd datalogger Error opening file after working for a bit
so my SD datalogger for temperature and humidity was working for a bit, but after some time, it always stops working and has an error opening file.
The code is almost the same as some other code I copied from online somewhere.
This is what the Serial Monitor says
card is initialized. Ready to go
Time,Humidity,Temperature_C,Heat_index
0:0:0, 65.00, 20.70, 15.52
File Saved..
14:55:01.795 -> 0:0:10, 65.00, 20.80, 15.64
14:55:01.795 -> File Saved..
14:55:11.848 -> 0:0:20, 65.00, 20.70, 15.52
14:55:11.848 -> File Saved..
14:55:21.880 -> 0:0:30, 65.00, 20.60, 15.41
14:55:21.914 -> File Saved..
14:55:31.946 -> 0:0:40, 65.00, 20.60, 15.41
14:55:31.946 -> File Saved..
14:55:41.989 -> 0:0:50, 66.00, 20.50, 15.35
14:55:42.023 -> File Saved..
14:55:51.969 -> File closed..
14:56:01.971 -> error opening file
14:56:12.004 -> error opening file
14:56:22.003 -> error opening file
14:56:32.013 -> error opening file
The code looks like this
#include <SD.h>
#include <SPI.h>
#include "DHT.h"
#define DHTPIN 2
#define DHTTYPE DHT11
long seconds=00;
long minutes=00;
long hours=00;
int CS_pin = 10;
DHT dht(DHTPIN, DHTTYPE);
File sd_file;
void setup()  {
  pinMode(CS_pin, OUTPUT);
  dht.begin();
  // SD Card Initialization
  if (SD.begin())  {
    Serial.println("SD card is initialized. Ready to go");
  else  {
    Serial.println("Failed");
    return;
  sd_file = SD.open("data.txt", FILE_WRITE);
  if (sd_file)  {
    Serial.print("Time");
    Serial.print(",");
    Serial.print("Humidity");
    Serial.print(",");
    Serial.print("Temperature_C");
    Serial.print(",");
    Serial.println("Heat_index");
    sd_file.print("Time");
    sd_file.print(",");
    sd_file.print("Humidity");
    sd_file.print(",");
    sd_file.print("Temperature_C");
    sd_file.print(",");
    sd_file.println("Heat_index");
  sd_file.close(); //closing the file
void loop()  {
  if (sd_file)  {
    senddata();
  // if the file didn't open, print an error:
  else  {
    Serial.println("error opening file");
  delay(10000);
void senddata()  {
  for(long seconds = 00; seconds < 60; seconds=seconds+10)  {
    float temp = dht.readTemperature(); //Reading the temperature as Celsius and storing in temp
    float hum = dht.readHumidity();     //Reading the humidity and storing in hum
    float heat_index = dht.computeHeatIndex(temp, hum);
    sd_file.print(hours);
    sd_file.print(":");
    sd_file.print(minutes);
    sd_file.print(":");
    sd_file.print(seconds);
    sd_file.print(",  ");
    sd_file.print(hum);
    sd_file.print(temp);
    sd_file.println(heat_index);
    Serial.print(hours);
    Serial.print(":");
    Serial.print(minutes);
    Serial.print(":");
    Serial.print(seconds);
    Serial.print(",  ");
    Serial.print(hum);
    Serial.print(",    ");
    Serial.print(temp);
    Serial.print(",      ");
    Serial.println(heat_index);
    if(seconds>=50)  {
      minutes= minutes + 1;
    if (minutes>59)  {
      hours = hours + 1;
      minutes = 0;
    sd_file.flush(); //saving the file
      Serial.println("File Saved..");
    delay(10000);
  Serial.println("File closed..");
**This is what it looks like ** There is extra wires in there, because in the past I tried it with a RTC and a MQ135 co2 sensor, but It was having problems, so I have removed them to make it more simple. to try to find out what the problem is.
When I look at the Micro SD card it has some weird characters on there at the end like this
0:0:0, 65.00, 18.10, 12.66
0:0:10, 65.00, 18.20, 12.77
0:20, 65.00, 18.20, 12.77
0:30, 65.00, 18.20, 12.77
0:0:40, 65.00, 18.10, 12.66
0:50, 65.00, 18.10, 12.66
0:0:0, 65.00, 18.20, 12.77
0:0:10, 65.00, 18.10, 12.66
65.00, 18.20, 12.77
0:40, 65.00, Bý¶"•—€*Z×ü’
Ø
X¢uK«éÊ¿5WÖB®è•Ž5$$]¥®Iÿ“zù«.EPˆaaÎ— {Ò[W°Šº
\Ÿo;o;Ÿp(„A!_@:jhI-¾ÊÏ»°†D-•¤«ÔR/é(Õ¥%µ¨¡W@W@CKjQõU~Þ=(m zP<Úy®ëé­«=ç=ú_åç]Q¬!’t•º’þ'õù«.E(ă0€®€®QCKj*?ïúR/éÔ•¤«D-°†p]Ï+5´¤ttZR‹®ëyHÔk]¥®$½¤ÿI@ƒ«¢.¬…é­«==úç]Ï+pC¢X%é*uýOê%]ŠòWaPˆaHçK ôÖÕžQÖB €ÁUû|Ûùùû|ÛR”¿êƒB<@:_ó¿ý®¯òóx´õ <ÚzPë«ü¼ÿëÑ?W@W@…x”¿êRâÑÖƒ ëAñh¯òó®ü¯GÿK Hç–Ô¢†U~Þõ^Òÿ¤}¾íü(pp]Ï+¤5´tt‹ZRùy×WP<Úz]¥®$€ÁU ¡¨kuµ'½«=é­^ëz
‰Z`UêJÒþ'õ’üU—¢0:0:0, 65.00, 20.70, 15.52
Does anyone have any ideas about what could be causing this?
Delete the file close command in setup, and get rid of the file open / file close commands in the loop.
This statement allocates memory on the heap to create/return the file in the 'standard' SD library.
Which may/is the source of your problems.
Bill Greiman's SdFat library appears to be better in this regard.
BUT in any case as noted above, no need to open/close in every loop. flush() should force updates to the SD so that when you remove power the last record has been written.
