After some investigations I saw SD initialization for fast data logging looks like:
// initialize the SD card at SPI_FULL_SPEED for best performance.
// try SPI_HALF_SPEED if bus errors occur.
if (!sd.begin(chipSelect, SPI_FULL_SPEED)) {
sd.initErrorHalt();
// delete possible existing file
sd.remove("RawWrite.txt");
// create a contiguous file
if (!file.createContiguous(sd.vwd(), "RawWrite.txt", 512UL*BLOCK_COUNT)) {
error("createContiguous failed");
// get the location of the file's blocks
if (!file.contiguousRange(&bgnBlock, &endBlock)) {
error("contiguousRange failed");
According to my SD storage experience I have some difficulties to integrate it.
Thanks to a moderator who makes my sketches usable without all the sensors, hence you can find it attached with the associated library. You just need a SD board.
I am actually using a 16 Gb SanDisk Extreme Plus whose the bench.ino test gives:
Type any character to start
FreeStack: 6699
Type is FAT32
Card size: 15.93 GB (GB = 1E9 bytes)
Manufacturer ID: 0X3
OEM ID: SD
Product: SP16G
Version: 8.0
Serial number: 0XD46709D8
Manufacturing date: 8/2015
File size 5 MB
Buffer size 512 bytes
Starting write test, please wait.
write speed and latency
speed,max,min,avg
KB/Sec,usec,usec,usec
262.80,120024,1484,1941
259.44,192484,1488,1966
Starting read test, please wait.
read speed and latency
speed,max,min,avg
484.56,2040,996,1050
483.90,2040,1000,1051
The attached sketch perfectly illustrates the timing problem when the recording file is extended leading inevitably to missing writings.
With the real sketch I get:
With the "sensor simulated" sketch which is attached I obtain:
Press 1 to start logging, 0 to stop
Initializing SD card...
SD card initialized.
Writing to data_03.txt
W5330396=5
S5330828=5
I5331352=6
W18860092=2
S18860568=2
I18867564=2
W18946268=2
S18946744=2
I18947312=2
I18974124=3
W26022492=2
S26022976=2
I26033992=4
W47646692=2
S47647176=2
I47652068=3
I47670404=2
W69255272=2
S69255752=2
I69259712=3
I75820696=2
W101575040=2
S101575568=2
I101577560=3
W101595128=2
S101595660=2
I101599992=3
I102401784=2
I102488544=2
W102568180=2
S102568704=2
I102569336=2
W102641836=2
S102642356=2
I102648856=3
Each line is a missing writing. The letter corresponds to the sensor's name (I=IMU, S=Steering sensor, W=Wheel speed sensor) and then the time in micros when it happens.
I would be grateful if someone could help me. It's the last part of a 2-month project.
Thank you very much,
Pm
simple.zip (157 KB)
