I am using the SDfat library to log 4 analog inputs and an IMU (MPU6050).
I am looking to get a stable logging frequency of around 100 Hz. Currently I am sending 40 data samples to the buffer before flushing to the SD card and without the delay of 5 milli seconds I am able to log up to around 800 Hz.
The problem I am having is the time taken to flush values to the SD. It takes approx. 14 ms to flush the values meaning I miss capturing data during that period. When sending and flushing 1 value per loop the maximum frequency I can get is only around 60Hz.
I wonder if anyone knows of a more efficient way of flushing the values to the card?
Please see code below.
Thanks.
//--------------Include Libraries----------------------
#include <SdFat.h> // SD card library
#define CHIP_SELECT SS // SD chip select pin
#include "I2Cdev.h"
#include "MPU6050.h"
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include "Wire.h"
#endif
//-----------------Declerations-----------------------
// class default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for InvenSense evaluation board)
// AD0 high = 0x69
MPU6050 accelgyro;
//MPU6050 accelgyro(0x69); // <-- use for AD0 high
int16_t ax, ay, az;
int16_t gx, gy, gz;
// uncomment "OUTPUT_READABLE_ACCELGYRO" if you want to see a tab-separated
// list of the accel X/Y/Z and then gyro X/Y/Z values in decimal. Easy to read,
// not so easy to parse, and slow(er) over UART.
#define OUTPUT_READABLE_ACCELGYRO
// uncomment "OUTPUT_BINARY_ACCELGYRO" to send all 6 axes of data as 16-bit
// binary, one right after the other. This is very fast (as fast as possible
// without compression or data loss), and easy to parse, but impossible to read
// for a human.
//#define OUTPUT_BINARY_ACCELGYRO
// Create file system object
SdFat sd;
// Define text file for logging
ofstream logfile;
// Create a buffer variable
char buffer[6700];
// join I2C bus (I2Cdev library doesn't do this automatically)
Wire.begin();
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
Fastwire::setup(400, true);
#endif
accelgyro.initialize();
// initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
// breadboards. use SPI_FULL_SPEED for better performance.
if (!sd.begin(CHIP_SELECT, SPI_FULL_SPEED )) sd.initErrorHalt();
// Create a new file in the current working directory
// and generate a new name if the file already exists
char fileName[13] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 150; i++)
fileName[6] = i/10 + '0';
fileName[7] = i%10 + '0';
if (sd.exists(fileName)) continue;
logfile.open(fileName);
// Connect the buffer to the variable buffer
obufstream bout(buffer, sizeof(buffer));
// Write a line for the headers
bout << pstr("time_milli_gps");
bout << pstr(",Lat");
bout << pstr(",Long");
bout << pstr(",Date");
bout << pstr(",GPS_Time");
bout << pstr(",Altitude_m");
bout << pstr(",Course_Deg");
bout << pstr(",Speed");
bout << pstr(",time");
bout << pstr(",accel_x");
bout << pstr(",accel_y");
bout << pstr(",accel_z");
bout << pstr(",Gyro_x");
bout << pstr(",Gyro_y");
bout << pstr(",Gyro_z");
bout << pstr(",pot_1");
bout << pstr(",pot_2");
bout << pstr(",pot_3");
bout << pstr(",pot_4");
bout << pstr(",Emergency_Stop");
bout << pstr(",Button_of_Choice");
bout << endl;
logfile << buffer << flush;
// read raw accel/gyro measurements from device
accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
// Use buffer stream to format line
// Create a loop to read a block of data and send them to the RAM
for (uint8_t ii = 0; ii < 40; ii++)
// Acquire data and copy on buffer
bout << ',' << micros();
bout << ',' << ax; // FLz
bout << ',' << ay; // FRz
bout << ',' << az; // RLz
bout << ',' << gx; // RRz
bout << ',' << gy; // RRz
bout << ',' << gz; // RRz
bout << ',' << analogRead(A0);
bout << ',' << analogRead(A1);;
bout << ',' << analogRead(A2);
bout << ',' << analogRead(A3);
bout << pstr(",E_stop_s");
bout << pstr(",button_s");
bout << endl;
delay(5); // 5 msec = 200 Hz
