Select a platform for JIGTEST
Hello,
I would like to build a test jig for my device under test (DUT). That is a display unit, high speed with FPGA, DSP, CPU,... components on main board. The connector of this DUT has: ADRR (0-23), DATA (0-31) and other control signals GPIOs (see photo) connected to an DSP component (Texas Instrument PN: TMS320C31PQA50, some pins have frequency ~ 32MHz)
I would like to select a board with CPU or FPGA built-in to test this DUT through this connector. Any Arduino platform I can use ?
Could you please advice ?
Thanks,
V5D
The only Arduino with an FPGA on board is the MKR Vidor 4000
Look at this page for getting started:-
Getting started with mkr vidor 4000
Thanks for replying.
I need ADRR (0-23), DATA (0-31), is that enough ?
Thanks
I'm looking for this drawing mechanical to know the dimension of this header connector for this probe:
what is the distance between 2 pins ?
This is probe for Keysight U4203A cable.
Thanks,
VD5
From this website
single ended 34 channel flying lead
It looks like it is "normal" 0.1 inch pitch.
Well you won't get that many on a mkr vidor, but all the normal ways of getting extra I/O will work. That is shift registers, port extenders and analogue / digital multiplexing.
As the IC (PN: TMS320C31PQA50) has 24bits addresses and 32bits data on my DUT.
I want to increase binary the addresses from 0 to max. value binary to see the data out of this IC. Is it possible ?
Do you have any Arduino code examples to do this task ?
Thanks.
That is a digital signal processing chip, how are you going to connect it to your Arduino?
As I said in my last post:-
No, I do not.
Maybe basing on this demo ?
