After picking some speed self balance robot fell down.i have attached batteries beneath.
Your topic was MOVED to its current forum category as it is more suitable than the original
If it’s stable at rest and at low speeds, - that suggests the software is overwhelmed as the calculation burden increases.
The solution could be that you need tighter/faster code, or a faster processor l
Thanks for reply
Please i am begginer with that just hobbiest,here is the code kindly
File name: AdeeptSelfBalancingRobotCode.ino
Description:
Three working modes after the car is power on:
Mode No.1: Remote control via Bluetooth
You can control the car to go forward and backward and turn left and right by commands via
Bluetooth. At the same time, you can switch between the modes and control the buzzer to beep.
Mode No.2: Obstacle avoidance by ultrasonic
Under this mode, the car can detect and bypass the obstacles in front automatically.
Mode No.3: Following
Under this mode, the car will follow the object ahead straight. When it's 30-50cm to the
object, the light onside will light up and the car will follow the object to move forward;
when it's 5-20cm, the light turns into green, and the car will move backward.
Website: www.adeept.com
E-mail: support@adeept.com
Author: Tom
Date: 2017/10/12
#include "PinChangeInt.h"
#include "MsTimer2.h"
#include "Adeept_Balance2WD.h"
#include "Adeept_KalmanFilter.h"
#include "Adeept_Distance.h"
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#include "Wire.h"
MPU6050 mpu; //Instantiate an MPU6050 object with the object name mpu
Adeept_Balance2WD balancecar;//Instantiate an balance object with the object name balancecar
Adeept_KalmanFilter kalmanfilter;//Instantiate an KalmanFilter object with the object name kalmanfilter
Adeept_Distance Dist;//Instantiate an distance object with the object name Dist
//mode = 0:Remote control via Bluetooth mode
//mode = 1:Obstacle avoidance by ultrasonic mode
//mode = 2:Following mode
int mode = 0;
int motorRun = 0;//0:Stop; 1:Go ahead; 2;Backwards; 3:Turn left; 4:Turn right;
int16_t ax, ay, az, gx, gy, gz;
//TB6612FNG Drive module control signal
#define IN1M 7
#define IN2M 6
#define IN3M 13
#define IN4M 12
#define PWMA 9
#define PWMB 10
#define STBY 8
//Speed PID control is realized by using speed code counting
#define PinA_left 2 //Interrupt 0
#define PinA_right 4 //Interrupt 1
const int RPin = A0; //RGB LED Pin R
const int GPin = A1; //RGB LED Pin G
const int BPin = A2; //RGB LED Pin B
/***********Declare a custom variable/
int time;
byte inByte; //The serial port receives the byte
int num;
double Setpoint; //Angle DIP setpoint, input, and output
double Setpoints, Outputs = 0; //Speed DIP setpoint, input, and output
double kp = 30, ki = 0.1, kd = 0.58;//kp = 38, ki = 0, kd = 0.58;//Need you to modify the parameters kp = 30, ki = 0.1, kd = 0.58;
double kp_speed = 3.6, ki_speed = 0.1058, kd_speed = 0.0; // Need you to modify the parameters kp_speed = 3.6, ki_speed = 0.1058, kd_speed = 0.0;
double kp_turn = 28, ki_turn = 0, kd_turn = 0.29; //Rotate PID setting
//Steering PID parameters
double setp0 = 0, dpwm = 0, dl = 0; //Angle balance point, PWM difference, dead zone, PWM1, PWM2
float value;
/angle data*/
float Q;
float Angle_ax; //The angle of inclination calculated from the acceleration
float Angle_ay;
float K1 = 0.05; // The weight of the accelerometer
float angle0 = 0.00; //Mechanical balance angle
int slong;
/Kalman_Filter******/
float Q_angle = 0.001, Q_gyro = 0.005; //Angle data confidence, angular velocity data confidence
float R_angle = 0.5 , C_0 = 1;
float timeChange = 5; //Filter method sampling time interval milliseconds
float dt = timeChange * 0.001; //Note: The value of dt is the filter sampling time
/******************* speed count ************/
volatile long count_right = 0;//Use the volatile long type to ensure that the value is valid for external interrupt pulse count values used in other functions
volatile long count_left = 0;//Use the volatile long type to ensure that the value is valid for external interrupt pulse count values used in other functions
int speedcc = 0;
/**Pulse calculation/
int lz = 0;
int rz = 0;
int rpluse = 0;
int lpluse = 0;
/Turn the parameters of rotation**/
int turncount = 0; //转向介入时间计算
float turnoutput = 0;
/Bluetooth control volume***/
int front = 0;//Forward variable
int back = 0;//Backward variables
int turnl = 0;//Turn left mark
int turnr = 0;//Turn right
int spinl = 0;//Left rotation mark
int spinr = 0;//Right turn mark
/Ultrasonic velocity***/
int distance;
int detTime=0;
const int buzzerPin = 11; // define pin for buzzer
/Pulse calculation/
void countpluse(){
lz = count_left;
rz = count_right;
count_left = 0;
count_right = 0;
lpluse = lz;
rpluse = rz;
if ((balancecar.pwm1 < 0) && (balancecar.pwm2 < 0)){//Car movement direction to determine: back when (PWM is the motor voltage is negative) pulse number is negative
rpluse = -rpluse;
lpluse = -lpluse;
}else if ((balancecar.pwm1 > 0) && (balancecar.pwm2 > 0)){//Car movement direction to determine: forward (PWM is the motor voltage is positive) pulse number is negative
rpluse = rpluse;
lpluse = lpluse;
}else if ((balancecar.pwm1 < 0) && (balancecar.pwm2 > 0)){////Car movement direction to determine: right rotation, the right pulse number is positive, the number of left pulse is negative.
rpluse = rpluse;
lpluse = -lpluse;
}else if ((balancecar.pwm1 > 0) && (balancecar.pwm2 < 0)){//Car movement direction to determine: left rotation, the right pulse number is negative, the number of left pulse is positive.
rpluse = -rpluse;
lpluse = lpluse;
//To judge
balancecar.stopr += rpluse;
balancecar.stopl += lpluse;
//Every 5ms into the interruption, the number of pulses superimposed
balancecar.pulseright += rpluse;
balancecar.pulseleft += lpluse;
/Angle PD/
void angleout(){
balancecar.angleoutput = kp * (kalmanfilter.angle + angle0) + kd * kalmanfilter.Gyro_x;//PD angle loop control
/Interrupt timing 5ms timer interrupt/
void inter(){
sei();
countpluse(); //Pulse superposition of sub - functions
mpu.getMotion6(&ax, &ay, &az, &gx, &gy, &gz); //IIC gets MPU6050 six axis data ax ay az gx gy gz
kalmanfilter.angleTest(ax, ay, az, gx, gy, gz, dt, Q_angle, Q_gyro,R_angle,C_0,K1); //Get angle and Kaman filter
angleout(); //Angle loop PD control
speedcc++;
if (speedcc >= 8){ //50ms into the speed loop control
Outputs = balancecar.speedPiOut(kp_speed,ki_speed,kd_speed,front,back,setp0);
speedcc = 0;
turncount++;
if (turncount > 2){ //10ms into the rotation control
turnoutput = balancecar.turnSpin(turnl,turnr,spinl,spinr,kp_turn,kd_turn,kalmanfilter.Gyro_z); //Rotary subfunction
turncount = 0;
balancecar.posture++;
balancecar.pwma(Outputs,turnoutput,kalmanfilter.angle,kalmanfilter.angle6,turnl,turnr,spinl,spinr,front,back,kalmanfilter.accelz,IN1M,IN2M,IN3M,IN4M,PWMA,PWMB);//car total PWM output
if(mode!=0&&detTime>=100){
distance = Dist.getDistanceCentimeter();
detTime++;
if(detTime>100){detTime=0;}
// TB6612FNGN drive module control signal initialization
pinMode(IN1M, OUTPUT);//Control the direction of the motor 1, 01 for the forward rotation, 10 for the reverse
pinMode(IN2M, OUTPUT);
pinMode(IN3M, OUTPUT);//Control the direction of the motor 2, 01 for the forward rotation, 10 for the reverse
pinMode(IN4M, OUTPUT);
pinMode(PWMA, OUTPUT);//Left motor PWM
pinMode(PWMB, OUTPUT);//Right motor PWM
pinMode(STBY, OUTPUT);//TB6612FNG enabled
//Initialize the motor drive module
digitalWrite(IN1M, 0);
digitalWrite(IN2M, 1);
digitalWrite(IN3M, 1);
digitalWrite(IN4M, 0);
digitalWrite(STBY, 1);
analogWrite(PWMA, 0);
analogWrite(PWMB, 0);
pinMode(PinA_left, INPUT); //Speed code A input
pinMode(PinA_right, INPUT); //Speed code B input
pinMode(RPin, OUTPUT); // set RPin to output mode
pinMode(GPin, OUTPUT); // set GPin to output mode
pinMode(BPin, OUTPUT); // set BPin to output mode
Dist.begin(5,3);//begin(int echoPin, int trigPin)
//Initialize the I2C bus
Wire.begin();
//Turn on the serial port and set the baud rate to 9600
//Communicate with the Bluetooth module
delay(150);
//Initialize the MPU6050
mpu.initialize();
delay(2);
//5ms timer interrupt setting. Use timer2. Note: Using timer2 will affect the PWM output of pin3 and pin11.
//Because the PWM is used to control the duty cycle timer, so when using the timer should pay attention to
//see the corresponding timer pin port.
MsTimer2::set(5, inter);
MsTimer2::start();
//The main function of the cycle of detection and superposition of pulse, the determination of car speed.
//Use the level change both into the pulse superposition, increase the number of motor pulses to ensure
//the accuracy of the car.
attachInterrupt(0, Code_left, CHANGE);
attachPinChangeInterrupt(PinA_right, Code_right, CHANGE);
//Bluetooth control
if(Serial.available() > 0){//Receive serial(Bluetooth) data
switch(Serial.read()){//Save the serial(Bluetooth) data received
case 'a': motorRun = 3;break;//go ahead
case 'b': motorRun = 1;break;//turn right
case 'c': motorRun = 2;break;//turn left
case 'd': motorRun = 4;break;//backwards
case 'e': mode = 0; motorRun = 0;break;
case 'f': mode = 1; break;
case 'g': mode = 2; break;
case 'h': digitalWrite(buzzerPin, HIGH);break;
case 'i': digitalWrite(buzzerPin, LOW); break;
if(mode==0){//Remote control via Bluetooth mode
switch(motorRun){
case 0: front = 0; back = 0; turnl = 0; turnr = 0; spinl = 0; spinr = 0; turnoutput = 0; // control steering and reversing smart car
digitalWrite(RPin, LOW);digitalWrite(GPin, HIGH);digitalWrite(BPin, HIGH);//red led
case 1: turnr = 1; // control smart 2WD balance turn right
digitalWrite(RPin, HIGH);digitalWrite(GPin, LOW); digitalWrite(BPin, HIGH);
case 2: turnl = 1;// control smart 2WD balance turn left
case 3: back = 50;// control 2WD balance car backwards
case 4: front = -50;// control 2WD balance car go ahead
default:break;
if(mode==1){//Obstacle avoidance by ultrasonic mode
if(distance<30){
digitalWrite(RPin, HIGH);digitalWrite(GPin, HIGH); digitalWrite(BPin, LOW);
}else if(distance<60&&distance>30){
turnl = 1; // control smart 2WD balance turn left
front = 0; back = 0; turnr = 0; spinl = 0; spinr = 0; turnoutput = 0;
digitalWrite(RPin, HIGH);digitalWrite(GPin, LOW); digitalWrite(BPin, LOW);
}else{
front = 0; turnl = 0; turnr = 0; spinl = 0; spinr = 0; turnoutput = 0;
if(mode==2){//Following mode
if(distance>=30&&distance<50){
if(distance<20&&distance>5){
}else{
front = 0; back = 0; turnl = 0; turnr = 0; spinl = 0; spinr = 0; turnoutput = 0; // control 2WD balance car stop
digitalWrite(RPin, LOW);digitalWrite(GPin, HIGH); digitalWrite(BPin, HIGH);
/Left speed chart/
void Code_left() {
count_left ++;
/Right speed chart count/
void Code_right() {
count_right ++;
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Looking at the code as is, I’d question why you feel the need to attach the interrupts every time through loop().
Plz help
Can any one give me self balancing code with bluetooth that control motor speed via app because the code i am using earlier is when my robot picks some speed it fell down.thanks
You wish to pay for someone to write the code for you? ![]()
As you wish
Kindly suggest the board.(faster one)
I suppose you can use the esp boards like the esp8266 or esp32 , and even if someone were to give you the code it might not work because when using PID you need to test and correct the values as you experience it
Thanks
Bless you Sir,
Dear sir
Is it possible to upload arduino uno supported codes to arduino iot 33
