Hi, why it come out this error with all the libraries installed?Can anyone help me to solve it?Much appreciate
The error message
class WiFiClientSecure' has no member named 'setTrustAnchors
'X509List' does not name a type; did you mean 'xList'?
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include <UniversalTelegramBot.h>
const char* ssid = "";// Enter your WIFI SSID
const char* password = ""; // Enter your WIFI Password
#define BOTtoken "" // Enter the bottoken you got from botfather
#define CHAT_ID "" // Enter your chatID you got from chatid bot
X509List cert(TELEGRAM_CERTIFICATE_ROOT);
WiFiClientSecure client;
UniversalTelegramBot bot(BOTtoken, client);
int const trigPin = 34;
int const echoPin = 35;
int const buzzPin = 25;
const int LED1 = 13;
configTime(0, 0, "pool.ntp.org");
client.setTrustAnchors(&cert);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
int a = 0;
Serial.print(".");
a++;
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(buzzPin, OUTPUT);
pinMode(LED1 , OUTPUT);
Serial.println("");
Serial.println("WiFi connected");
Serial.print("IP address: ");
bot.sendMessage(CHAT_ID, "Wifi Connected!", "");
bot.sendMessage(CHAT_ID, "System has Started!!", "");
int duration, distance;
digitalWrite(trigPin, HIGH);
delay(1);
digitalWrite(trigPin, LOW);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
if (distance <= 10 && distance >= 0) {
digitalWrite(buzzPin, HIGH);
//digitalWrite(LED1, HIGH);
bot.sendMessage(CHAT_ID, "ALERT! MOTION DETECTED!!", "");
digitalWrite(buzzPin, LOW);
//digitalWrite(LED1, LOW);
Your code is not compatible with the included library. Either correct the code, or use the appropriate library.
#define BOTtoken "6653814493:AA
s/b
#define BOT_TOKEN "6653814493:AA
Universal-Arduino-Telegram-Bot/examples/ESP8266/SendMessageFromEvent/SendMessageFromEvent.ino at master · witnessmenow/Universal-Arduino-Telegram-Bot · GitHub
// attempt to connect to Wifi network:
Serial.print("Connecting to Wifi SSID ");
Serial.print(WIFI_SSID);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
secured_client.setTrustAnchors(&cert); // Add root certificate for api.telegram.org
secured_client
vs
client (??)
so which library should i include?
I have a related question --
is the Telegram app trustworthy?
Are you using an ESP8266 or ESP32 ?
Will the example in the link work ?
(I'm reluctant to d/l the library.)
Im nt sure
do i need to include this with esp32?
it shows the same error when i used secured_client
'secured_client' was not declared in this scope
It is not in the ESP32 example (link, Post No.8)
Did you copy & paste that (and add your credentials) ?
If you have reason to believe that the code is correct, then the correct library will have the missing member.
If you did not write the code, ask the author, or go to the web site where you found the code, and determine which library should be used.
It works!! Thank you so much
but i hv one question
can telegram bot able to send picture also?
mikb55
December 12, 2023, 4:27am
15
Would you trust an app that has a loss making business model?
Therein lies the problem, it's great while it works, but one day the investors will want their money back and at that point the unprofitable bits of the service may just disappear.
There aren't many paid push notification services. I use Pushbullet and it seems to work reliably.
It's a tough market to compete in when competitors are trying to drive you out of business by running at a loss.
Can you explain what you did to make it work
I have esp 8266 and everything I don't do doesn't work.
error: 'X509List' does not name a type
system
Closed
June 20, 2024, 12:49pm
19
