I want to make a little bot ( like an Alexa voice assistant ), so for that i used a little robot in kit that contains these pieces :
SD card reader
2 Speakers
Bluetooth ( BT16 4.0 )
1 mic module
So i need to pass my voice from the robot to the computer, then the audio response generated from my computer to the robot and since there is a bluetooth intagreted in it i will make with that
its impossible ( at least not wished ) to make thing like voice<--->text directly on the Arduino
So I need to have an audio file ( MP3, WAV or whatever ) on the arduino and no text
So my think is that :
I need to save my voice from mic module to SD card ( as temp) then send it by bluetooth to the computer
Then the computer need to transform thé answer as an audio file like mp3 then send it to the robot by Bluetooth and the robot will save it on the SD card then play it
But i think i need to send the MP3 as data like any kind of text data or whatever maybe creating some kind of bus
But i really dont know how to do that and the speed of the transfer ( think the speed will depend with the distance between robot and computer and also the size of the MP3 )
Also voice and answer dont need to be long files and there is no need to stream the sound i think with my actuals components its preferable to make the save on the SD then play it ( i plan to play some kind of elevator music to let the user wait )
Dont know if my Ask is clear, dont hesitate to ask me for more details if needed, thanks a lot at least for the read
You are not sending MP3 files, you are just sending bytes. make no difference where the bytes come from or where they go. Can you ready bytes from a file identified as being MP3?
Much simpler solution: bluetooth microphone to send audio to computer; bluetooth speaker on which the computer's answer is played back.
So far I don't see anything in your project description that needs to access the stored information on the Arduino after the one time playback.
Playing back mp3 that is sent to an Arduino via bluetooth is not trivial: you need an mp3 player for that (like the DF Player), and something like SD card storage to store it. So you'd need an mp3 player that can read from the SD card the Arduino can write stuff to. That's probably possible but appears very complex to me.
Thanks a lot I will try it, did you think the transfer will be long ? And if yes what could be a better way to transfer stuff like that ( short MP3 file ) ?
Bluetooth Low Energy (BLE) is optimized for low power consumption, not speed. It has a maximum rate of 1mBit/second, so a 100kB file would take 1 second at best.
However, if all you're doing is transferring audio back and forth, there is already a BLE protocol for that which is already supported by ESP32 arduino: A2DP. I would suggest researching it and seeing if it's more suitable for what you want to do.
Oh okay thanks in fact 1S for 100kb IS perfectly reasonable since I Can compress the audio and lost quality ( i do not stream music only sentences )
I will test with that first and next will see about the A2DP protocol, since I use an Arduino nano and a bluetooth module included in the robot kit I will check if its possible
I don't want to change the nano for an esp32 but its nice to see that there is a preferable way with that if i change my mind
Thanks a lot for your help I will come back after my attempt to let you know if things work well with classic bluetooth data transfering
In fact I didnt see well but my robot kit only allow BLE as wireless connection
And After checking the datasheet better of the module, it Say :
Packet of 280 byte
And 70ms between each
Its about 71second for a 290kb MP3/WAV
So since BLE isnt suited for large data transfering and since the data transfer IS relatively slow i will let the Idea behind for now,
What do you think about passing the MP3 file datas trough USB ( letting the robot always connected to my computer ) is this could be a better option ?
I think that if I cant find any solution I will replace everything with a Raspberry pi zero at the end ( and use wifi to avoid doing heavy computer on it )
Does the computer have a limited set of potential responses? Or are they generated on the fly?
In the first situation you can store all of them on an SD card on the robot, and simply have the computer tell the robot which one to play, rather than transfer the whole file.
In fact response are generated on the fly ( using chatgpt api )
So I can't do that, I think the best solution is to go for a little raspberry pi zero since the bluetooth is solded on the shell sell in the robot kit ( the kit is the elegoo penguin 2.0 )
I can change the Arduino nano provided for an esp32 like but this will need some additional work since replacing the board+shell with a Raspberry pi zero is simpler I think
