Is there a way I can send values from an HTML webpage to my Arduino Uno, similar to sending a value from the Serial monitor to the Arduino. Basically, I will use the webpage to control the speed and direction of two servo motors connected to my Arduino Uno. I am fairly new to this kind of stuff and was wondering if this was possible
See this project on Arduino Project Hub
Is there a way to do it without a wifi shield, and just the Arduino? or do I need some kind of wifi device to connect it with the webpage?
ForestSkis98:
You HAVE TO use WiFi or Ethernet to let Arduino be accessed via webpage
I'm currently trying to do the opposite: When my arduino calls a function (idk which), it sends a message to a client. This one will be waiting and will refresh the info showed when the data is received. The message will be simply a text
So it is simple. You only need to read HTTP payload under HTTP header after connection. For instance there is php webserver that is sending VYP text as variable.
I am using it for my web based autonomous heating system.
Idk if i understand you correctly... You want to send datas from server to client? No, it is not possible.
Server can only send datas to client when client is connected to him.
