unprecise description.
You are not telling if you need this data online = available through internet or not.
A local solution with sending UDP-messages to a computer that is connected to the same network as the ESP32 is this.
If you want better support. Post better = much more detailed information.
// start of macros dbg and dbgi
#define dbg(myFixedText, variableName) \
Serial.print( F(#myFixedText " " #variableName"=") ); \
Serial.println(variableName);
// usage: dbg("1:my fixed text",myVariable);
// myVariable can be any variable or expression that is defined in scope
#define dbgi(myFixedText, variableName,timeInterval) \
do { \
static unsigned long intervalStartTime; \
if ( millis() - intervalStartTime >= timeInterval ){ \
intervalStartTime = millis(); \
Serial.println(variableName); \
} while (false);
// end of macros dbg and dbgi
// I wrote some basic documentation about receiving the UDP-messages with python at the end of the file
#include <WiFi.h>
#include <SafeString.h>
#define MaxMsgLength 1024
createSafeString(UDP_Msg_SS,MaxMsgLength);
uint8_t UDP_Msg_uint8_Buffer[MaxMsgLength + 1]; // for some strange reasons on ESP32 the udp.write-function needs an uint8_t-array
#define MaxHeaderLength 32
createSafeString(Header_SS,MaxHeaderLength);
#define MaxTimeStampLength 64
createSafeString(TimeStamp_SS,MaxTimeStampLength);
char HeaderDelimiter = '$'; // must match the delimiter defined in the python-code
const char *ssid = "";
const char *password = "";
IPAddress remoteIP (192, 168, 178, 160); // receiver-IP
unsigned int remotePort = 4210; // receiver port to listen on must match the portnumber the receiver is listening to
WiFiUDP Udp;
const char* ntpServer = "fritz.box";
const long gmtOffset_sec = 0;
const int daylightOffset_sec = 7200;
#include <time.h> // time() ctime()
time_t now; // this is the epoch
tm myTimeInfo; // the structure tm holds time information in a more convient way
boolean TimePeriodIsOver (unsigned long &expireTime, unsigned long TimePeriod) {
if ( currentMillis - expireTime >= TimePeriod )
expireTime = currentMillis; // set new expireTime
return true; // more time than TimePeriod) has elapsed since last time if-condition was true
else return false; // not expired
const byte OnBoard_LED = 2;
int BlinkTime = 500;
void BlinkHeartBeatLED(int IO_Pin, int BlinkPeriod) {
static unsigned long MyBlinkTimer;
pinMode(IO_Pin, OUTPUT);
if ( TimePeriodIsOver(MyBlinkTimer, BlinkPeriod) ) {
digitalWrite(IO_Pin, !digitalRead(IO_Pin) );
unsigned long TestTimer;
unsigned long UDP_SendTimer;
int myCounter = 0;
int HeaderNr = 0;
void PrintFileNameDateTime()
Serial.print("Code running comes from file ");
Serial.println(__FILE__);
Serial.print(" compiled ");
Serial.print(__DATE__);
Serial.println(__TIME__);
void showTime() {
time(&now); // read the current time
localtime_r(&now, &myTimeInfo); // update the structure tm with the current time
Serial.print("year:");
Serial.print(myTimeInfo.tm_year + 1900); // years since 1900
Serial.print("\tmonth:");
Serial.print(myTimeInfo.tm_mon + 1); // January = 0 (!)
Serial.print("\tday:");
Serial.print(myTimeInfo.tm_mday); // day of month
Serial.print("\thour:");
Serial.print(myTimeInfo.tm_hour); // hours since midnight 0-23
Serial.print("\tmin:");
Serial.print(myTimeInfo.tm_min); // minutes after the hour 0-59
Serial.print("\tsec:");
Serial.print(myTimeInfo.tm_sec); // seconds after the minute 0-61*
Serial.print("\twday");
Serial.print(myTimeInfo.tm_wday); // days since Sunday 0-6
if (myTimeInfo.tm_isdst == 1) // Daylight Saving Time flag
Serial.print("\tDST");
Serial.print("\tstandard");
void StoreTimeStampIntoSS(SafeString& p_RefToSS, tm p_myTimeInfo) {
//p_RefToSS = " ";
p_RefToSS = myTimeInfo.tm_year + 1900;
p_RefToSS += ".";
// month
if (p_myTimeInfo.tm_mon + 1 < 10) {
p_RefToSS += "0";
p_RefToSS += myTimeInfo.tm_mon + 1;
p_RefToSS += ".";
// day
if (p_myTimeInfo.tm_mday + 1 < 10) {
p_RefToSS += "0";
p_RefToSS += myTimeInfo.tm_mday;
p_RefToSS += "; ";
// hour
if (p_myTimeInfo.tm_hour < 10) {
p_RefToSS += "0";
p_RefToSS += myTimeInfo.tm_hour;
p_RefToSS += ":";
// minute
if (p_myTimeInfo.tm_min < 10) {
p_RefToSS += "0";
p_RefToSS += myTimeInfo.tm_min;
p_RefToSS += ":";
// second
if (p_myTimeInfo.tm_sec < 10) {
p_RefToSS += "0";
p_RefToSS += myTimeInfo.tm_sec;
//p_RefToSS += ",";
void connectToWifi() {
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.persistent(false);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
BlinkHeartBeatLED(OnBoard_LED, 333);
delay(332);
Serial.print(".");
Serial.print("\n connected.");
Serial.println(WiFi.localIP() );
void synchroniseWith_NTP_Time() {
Serial.print("configTime uses ntpServer ");
Serial.println(ntpServer);
configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
Serial.print("synchronising time");
while (myTimeInfo.tm_year + 1900 < 2000 ) {
BlinkHeartBeatLED(OnBoard_LED, 100);
delay(100);
Serial.print(".");
Serial.print("\n time synchronsized \n");
showTime();
Serial.println("\n Setup-Start \n");
PrintFileNameDateTime();
Serial.print("InitSensor() done \n");
connectToWifi();
synchroniseWith_NTP_Time();
Header_SS = "Header";
void PrintMsg() {
Serial.print("UDP_Msg_SS #");
Serial.print(UDP_Msg_SS);
Serial.println("#");
BlinkHeartBeatLED(OnBoard_LED, BlinkTime);
if (TimePeriodIsOver(UDP_SendTimer, 2000) ) {
Serial.print("Send Message to #");
Serial.print(remoteIP);
Serial.print(":");
Serial.println(remotePort);
UDP_Msg_SS = "";
UDP_Msg_SS = Header_SS;
UDP_Msg_SS += HeaderDelimiter;
StoreTimeStampIntoSS(TimeStamp_SS,myTimeInfo);
UDP_Msg_SS += TimeStamp_SS;
UDP_Msg_SS += ",my Testdata1,";
UDP_Msg_SS += 123;
UDP_Msg_SS += ",my Testdata2,";
UDP_Msg_SS += 789;
UDP_Msg_SS += ",";
UDP_Msg_SS += myCounter++;
dbg("Send UDP_Msg #",UDP_Msg_SS);
dbg("length:",UDP_Msg_SS.length());
Udp.beginPacket(remoteIP, remotePort);
Udp.write((const uint8_t*)UDP_Msg_SS.c_str(), UDP_Msg_SS.length() );
Udp.endPacket();
This is a democode that demonstrates how to send TCP/UDP-messages with a timestamp
The time is synchronized using a NTP-server. Most local routers like Fritz!Box can be used as the NTP-timer-server
The message has a userdefinable header which could be used for identifying the sender on the recieverside
There is a user-definable Header-delimiter that can be used to identify which characters of the
UDP-message belong to the header and which to the userdata
The code makes use of the SafeString-library. SafeStrings don't cause memory-problems like datatype "Strings"
and are easier to use than arrays of char. Example adding an integer to a SafeString-variable is as easy as
MySafeString = myInteger;
The userdata has commas between each data so you can import the textfile
into table-calculation-software or databases as CSV-file comma separated values
the code has some additional useful functions as there are
- PrintFileNameDateTime() printing the path and filename of sourcecode file this program was generated with
- boolean TimePeriodIsOver a non-blocking timing-function based on millis which is suitable for
timed execution in a regular manner (repeat every n milliseconds)
- BlinkHeartBeatLED() blinks the onboard-LED of ESP32 nodeMCU-boards. Gives visual feedback if the code is running
The lines of code are grouped by functionality into several functions
The functions name says what the function does
I use this code for easy datalogging on a computer with a python-code that acts as the UDP-listener for
incoming messages. Inside your ESP32-code you have to adjust the IP-adress to the receiver
and the portnumber must be the same on sender (ESP32) and receiver-side
In the python-code The header is used to create a file with the header as filename and extension ".txt" or if file
is already existant to append the actual received UDP-message at the end of the file.
here is the python-code that does this. I tested it with python 3.9.2 for windows
#Start of python-code
# very simple and short upd-receiver based on python-code I found here
# https://www.studytonight.com/network-programming-in-python/working-with-udp-sockets#
import socket
sock = socket.socket(socket.AF_INET,socket.SOCK_DGRAM) # For UDP
udp_host = socket.gethostname() # Host IP
udp_port = 4210 # specified port to connect
sock.bind((udp_host,udp_port))
print ("Waiting for client...")
HeaderDelimitChar = "$"
while True:
data,addr = sock.recvfrom(1024) #receive data from client
print("data #",data,"#")
Msg = data.decode('utf-8')
print ("Received Message: #",Msg,"# from",addr)
EndOfHeader = Msg.find(HeaderDelimitChar)
HeaderBytes = Msg[0:EndOfHeader]
FileName = HeaderBytes + ".txt"
print("Filename #",FileName,"#")
myFile = open(FileName, "a+")
EndOfStr = data.find(0)
MsgToWrite = Msg[EndOfHeader + 1 :1024] + '\r'
myFile.write(MsgToWrite);
myFile.close()
print ("Data #",MsgToWrite,"#")
#End of python-code
For learning more about python just google with keyword "python" "your keyword of interest"
