Sorry if I'm asking another retarded question, but I'm trying to create a library to control a DVR and am having some prgramming issues in setting up the constants.
Its fine if I only need to send a command such as 0x20, but cant understand how to contruct the rest of it to incorporate a string of commands such as 0x20 0x02 0x22. I used the code as below but get errors:
const unsigned char RECSTART = 0x20 0x02 0x22;
but no luck, even if I encapsulate it in brackets. I have a huge lis tof these commands and have so far just been doing some testing to see how they get sent out..Ideally I need to send those 3 bytes as if I was entering 20 02 22 into the RS232 terminal program..
Sorry for the confusion as I dont think I have explained myself correctly.
I need to send a range of commands over the serial link to a device according to its protocol listing. For instance, for me to intialise a record on this DVR I need to send 0x20 0x02 0x22 together for it to carry out the operation.
If I use the code as I showed earlier:
and I call it later in the code using:
Serial1.print(RECSTART);
but it throws up errors. I have tried the string theory (:P) but it also throws up errors. So far the only way I can get it to work is to split the command in to 3 different variables and indiviually send them over the port, which seems long winded but is the only way, with my limited knowledge it seems to work. i.e.
I am looking for a better way to do this, as there are other commands later on which are much longer than just 3 bytes, and I cant be doing it like this.
Thanks in advance.
P.S. Does anybody of a decent book I could buy on the Arduino?
Yes and I told you why.
You can use a string to output all the commands in one instruction.
I have tried the string theory but it also throws up errors.
That is because you are doing it wrong, the errors tell you what the compiler doesn't like. That is what they are for.
How are you constructing the string?
