system
1
Hello
Can someone explain to me how the thing with the serial connections on YUN works.
The Problem I have an Programm witch is use the Bridge.
When I now try to initial the Serial Connection with:
Serial.begin(38400);/code]
or
[code]Serial1.begin(38400);
the Sketch stops in the Setup Void.
When I try to use Software Serial I can not transfer any Datas.
The same Sketch with an UNO works (without Bridge)
Thank you for the Help[/code]
system
2
I have now disabled the bridge and there are data on the Hardware Serial PIN DO and PIN D1.
But I do not get to run an software serial!?
Can you post the entire sketch?
system
4
Here the Code.
Allfunctions without the Bridge are functionality.
It is possible to use the Hardware Seriel on D0 an D1?
Thank you for the help
wall24_AquaControl_V01_00_00.ino (8.84 KB)
You can use d0 and d1 although doing so will interrupt the communication between the 32u4 and the ar9331
