Hello,
For a project I want to connect 2 slave Dues to 1 master Due.
The schematic is attached to this post.
The sketch for the master:
Serial2.begin(38400);
Serial3.begin(38400);
Serial.println("Master started ...");
int start=0;
int counter=0;
if (counter++ % 2) {
start = millis();
Serial2.println("data");
while (!Serial2.available())
Serial.print("Serial2: ");
Serial.println(Serial2.readString());
Serial.println(millis()-start);
start = millis();
Serial3.println("data");
while (!Serial3.available())
Serial.print("Serial3: ");
Serial.println(Serial3.readString());
The sketch for the 2 slaves:
int number = 0;
if (Serial2.available()) {
Serial2.readString();
Serial2.print(number++);
The output is:
Master started ...
Serial3: 0
2001
Serial2: 0
2001
Serial3: 1
2001
Serial2: 1
2001
Serial3: 2
2001
Serial2: 2
2001
Serial3: 3
2001
Serial2: 3
2000
Serial3: 4
2001
To my understanding, the master should output new numbers from both slaves at a high rate, however, sending and waiting for reception takes 2 seconds, resulting in very poor performance.
jurs
July 7, 2016, 1:18pm
2
he Arduino Due has two USB ports available, each of them can establish ONE serial port, so with a DUE you can use Serial and Serial1, but Serial2 and Serial3 is bullshit. The MEGA2560 is aboard with 4 serial ports(Serial, Serial1, Serial2, Serial3).
readString has to timeout. Why use it? Can you use read?
Maybe it is readString causing you the problem. Normally strings are terminated with a 0 byte. If it doesn't get a 0, it will wait, then time out(?). I use read, but you should be able to use readStringUntil('\n'). edit: ...if the slaves use println.
I now updated the sketches to use readStringUntil, no success, still slow.
Master:
int start=0;
int counter=0;
start = millis();
Serial2.println("d");
Serial.println(Serial2.readStringUntil('\n'));
start = millis();
Serial.println(Serial3.readStringUntil('\n'));
Slave:
int number = 0;
Serial2.readStringUntil('\n');
Any advice?
You must use Serial2.println on the slave. Like this:
Serial2.println(number++);
SurferTim:
Thank you SurferTim, now it is working as expected, stupid mistake
Use either example 2 or 3 from Serial Input Basics . Simple reliable and non-blocking .
If you want to receive from 2 ports use two separate copies of the function - with suitably modified variable names.
...R
