Serial communication issue ATMEGA2560 to V-REP
Hello,
I can send seamlessly data/commands from vrep to atmega2560 arduino, but can't receive anything back from arduino to vrep using same serial USB communication used for sending. There is a history of this problem, caused by autoreset of atmega by the software package. And a simple solution is either to use 110ohms resistor between 5V and RESET or 220ohms resistor between 5V and RESET or 10microfarad capacitor between GND(-ve) and RESET(+ve).
Guess what? Tried all this, doesnt work!!
I am using serial communication via USB pins 0 and 1 of atmega2560, the problem is similar to this post:
http://forum.arduino.cc/index.php?topic=50266.0
but guess what? solution isn't. This is starting to frustrate me now.
Here is a simple code in arduino that i am trying to execute:
Dropbox - File Deleted - Simplify your life
No issues on the vrep side i assure as i can send data seamlessly from vrep.
Any suggestions would be a great help.
Thanks,
Dixit
What is V-REP? Post a link to its datasheet?
The Mega has 3 spare HardwareSerial ports - why use pins 0 and 1?
Post your code here to make it easy for people to help you.
And please use the code button </> so your code looks like this and is easy to copy to a text editor
...R
Vrep is a software package same as many others like gazebo, labview etc. Here is the link:-
http://www.coppeliarobotics.com/helpFiles/en/apiFunctionListCategory.htm
I am using VREP to send commands to arduino and get feedback. I am able to send commands to arduino, but not receive. The problem on searching i figure out should be because of auto-reset functionality of ATMEGa.
VREP has a forum for users, i have put up same issue there:- Link here:
http://www.forum.coppeliarobotics.com/viewtopic.php?f=9&t=4845&sid=fd2f8548d07be84f749afdca272b0188&p=20629#p20629
I am just send command "R" from vrep and want to receive number 20 from arduino to vrep using below:
Serial.begin(9600); // baud rate
	while(!Serial)
		;		//wait for serial port to connect
if (Serial.available())
		char inp;
                // get commands to run
		inp = Serial.read();
		if (inp == 'R')
			int count=20;
			Serial.println(count);
On vrep side, i send command "R", then i wait for 100 ms or '\n' to receive this 20, but doesnt come.
On starting serial port, i have tried all kinds of delays too.
What can you suggest?
I don't have a Atmega 2560, but I have no problems sending and receiving from an Arduino Uno.
My LabVIEW opens the serial port to the Arduino Uno.
Then whenever someone clicks a button on the LabVIEW front panel, the text in a text box is sent to the Arduino Uno.
The Arduino Uno's sketch is written to echo each character + 1 so that if LabVIEW sends a 'ACD' then 'BDE' is sent back.
Your code uses the variable inp but it is never set.
It is an ATMEGA issue mostly, it has a history of it. I have posted one such issue in my 1 st post.
Could you tell if my code should work?
(I missed the setting of inp in the code i posted..actually the code is big and i am concerned with only with this part, i have updated the code i posted)
Thanks,
Dixit
dnahar:
Good to know, did you do anything for auto-reset of ATMEGA or you are using it as it is(no addition of 110 resistor or capacitor).
Could you share your code?
Thanks,
Dixit
I did nothing about the auto-reset, because by the time someone pushes the button a lot of time would have passed.
I have already told you the bug in your code.
thats not the bug, i have updated the code in the post. The issue is with ATMEGA 2560 auto-reset mostly. I need more suggestions on how to solve this.
Thanks,
Dixit
There was a question about the Auto Reset, and the suggestion in the past is to have the Arduino spit out a "Arduino ready".
probably you dint get my problem,, i cant receive anything on vrep sent from arduino...Its all nil, even if i send anything in setup or the recursive loop.
I am telling you, mostly this is ATMEGA related issue and the workover is around it...Which several of i tried and unfortunately dint work...
Thanks,
Dixit
Perhaps you could try this Python - Arduino demo to see if two communication works. It should work on Windows if you put in the appropriate Serial port reference.
If it works you might then usefully compare the way it is structured with the way your VREP program is structured.
In particular your VREP program should keep the serial port open until it is completely finished talking to the Arduino.
...R
dnahar:
Thanks,
Dixit
You could try just a simple terminal program to try to talk to your Atmega.
