Hi!
I used some time to get this to work, so I thought I should share it with the community. There is a old ISP that is called TinyISP that replaces Arduino ISP and enables serial debugging of the ATtiny.
You can download it here:
TinyISP replacement
To get debugging to work, you also need the this library:
TinyDebugKnockBang-library
The problem is that this was made for an older Arduino version. I am currently running 2.3.5, so to get it to work you need to apply these fixes:
Insert “TinyDebugKnockBangClass_AssemblyMacros();” in two places in TinyDebugKnockBang.cpp (use notepad or alike):
bool TinyDebugKnockBangClass::knockHello(void) {
attribute((noinline))
void TinyDebugKnockBangClass::sendByte(uint8_t v) {
And it should compile without errors. This can also be done for TinyISP by inserting the same line in “KnockBangReceiver.cpp“:
ISR(KBR_PCINT_VECT)
asm volatile (
/* uses DELAY_FINE, etc. */
Recompile and upload and it should work. PS: You may want to set:
RELAY_KNOCK_BANG_USE_ALTERNATE_PIN = 0
in the “_TinyISP_BuildOptions.h” file in TinyISP to make it use the same pin for debugging as programming (if not you need a 1kOhm resistor to D7). There are also serial commands to start/stop debugging (Entering “#” in serial monitor starts debugging):
Other useful monitor keys (send while monitor is running):
!— stop monitoring (return to programmer) -
@— toggle “hold in reset after programming” -
#— reset target and run -
$— hold target in reset -
\— print receiver debug/stats (see §4)
